Old 9th May 2017, 07:16   #1
motorguy's Avatar
Thanked: 44 Times
Default Foam pieces coming out of A/C vents!
I have an Eon D-lite+ that I bought brand new in Kerala in Feb 2014. This car is kept in Kerala and used only when I am there which is about every 2 months. However, the car is started by the driver and driven around a couple of kilometers 3 days a week.
When I was there last month (April), I noticed a lot of foam pieces (about 5 or 6 making up a square like piece) in the leftmost AC vent (near the front passenger window). Seems like the foam pieces had come from the AC internals. To take it out, brought it to the Hyundai Service Center in Kottayam (Popular). They took the pieces out using a twig (jugaad!)
Since the car was under extended warranty, I asked them "now what?" . They said "Sir, we will have to take out the entire dashboard and stick some more foam pieces - anyway it is under warranty". I refused, having seen the quality of their mechanics in previous services (where I myself had advised them on service procedures). And, I know whenever a dashboard is removed, rattling and other problems can surface (since even the AC lines have to be disconnected).
Brought it to friendly AC guy outside the service center and he said it the pieces were coming from the heating coil inside due to the glue drying up and the pieces coming off, but said not to worry since the AC was cooling very well anyway.
Incidentally, on another note, a single piece came out of my 7 year old i10 when travelling to Kannur (hot weather). Brought it to Trident in Bangalore, and they said do not bother to do anything.
Has anyone else experienced this ? Seems the quality of Hyundai cars and material like glue, foam etc is getting poorer (have not encountered this abroad in my experience)?
Also can any Tbhpians share any advice?
P.S. I have also an Elite i20, which I picked up 4 months back and hope that this doesnt happen in that car.
motorguy is offline   Reply With Quote
Old 9th May 2017, 10:11   #2
prithm's Avatar
Thanked: 239 Times
Default Re: Foam pieces coming out of A/C vents!
In my Maruti DZire I got only residues of old paper filter element which was destroyed due to condensation on it. But the quality of paper element was really bad and Non-MGP product.
After changing to MGP product, I haven't had this issue.
But my question is, how can they dislodge unless something scraps them off their place ?
The vents are usually moulded conduits.
prithm is offline   (1) Thanks Reply With Quote
Old 9th May 2017, 11:31   #3
deehunk's Avatar
Thanked: 546 Times
P.S. I have also an Elite i20, which I picked up 4 months back and hope that this doesn't happen in that car.
This is the insulation material which is coming off, better to get it fixed rather than wait till A/C is rendered useless.
deehunk is offline   (1) Thanks Reply With Quote
Old 9th May 2017, 11:54   #4
motorguy's Avatar
Thanked: 44 Times
These are pieces from inside the AC. The Trident guy told me (for my i10), that these are materials to ensure that the heating coil does not rattle - so if 1 piece only goes it is ok.
I guess if more pieces come out, then I will look at having the foam replaced (still have the extended warranty for 1 more year). At present I am scared that the Popular Hyundai guys (given the quality of their mechanics will do more damage than good).
Old 10th May 2017, 19:28   #5
Thanked: 299 Times
Are you sure a rat hasnt gotten inside the ducts and has chewed up the insulation material ? Please double check as a rat in the car can do a lot more damage. Anyways get the repairs done by the ASS as it will be covered under warranty and you can blame them for any issues that crop up later
Mortis is offline   Reply With Quote
Old 10th May 2017, 20:02   #6
createrkid's Avatar
Thanked: 282 Times
Classic case of a rat finding its way into the vents. The same thing happened to my Getz and the damn rats chewed up all the foam and it used to blow into the cabin whenever outside circulation was selected.
createrkid is offline   Reply With Quote
Old 10th May 2017, 20:38   #7
Leoshashi's Avatar
Thanked: 7,162 Times
There are foam pieces(called as padding) inside the blower assembly, for preventing rattles and also for improving cooling efficiency.
Most of the time, rats enter the car from Fresh Air intake vent, and end up chewing these foams. So request you all to keep the car in recirculation mode when parking. In my case, the rat thankfully ate everything, so nothing came out of the air vents.
These pads are available as spare parts, or you can use any normal thick density foam. I got them replaced when recently my dashboard was removed for some work
The OEM adhesive was pretty weak, so I asked the mechanic to use some extra adhesive.
Foam pieces coming out of A/C vents!-blower-foam.jpg
More details posted here: http://www.team-bhp.com/forum/long-t...ml#post4107603 (The love of my life: A 2000 Maruti 800 DX 5-Speed)
In older cars, the foam can get damaged due to age and condensation. That also causes it to disintegrate into small pieces and come out of the air vent.
Shashi
PS: For more inquisitive souls, this is the purpose of foam which is widely used around heat exchangers and AC systems, explained by Late Behram Dhabar. He once told me that the foam is used in AC systems for the very same reason, while ensuring a sealed system:
Let me tell you something about the "foam"! The fan pulls air through the radiator. The unit of measurement is mass flow in cubic meters per second. Reverse flow of air is not good as it creates eddies. Due to the micro-pressure differential in this area, reverse flow tends to take place. The foam is the member which blocks the path of reverse flow. In TD test (in R&D, we call it temperature difference or delta-T) maximum effectiveness on TD due to eddies prevention is around 2 degrees.
Link (Understanding wheel alignment)
Leoshashi is offline   (6) Thanks Reply With Quote
Old 11th May 2017, 07:21   #8
motorguy's Avatar
Thanked: 44 Times
This is not a rat - there are not droppings or smell. Also, the pieces are not chewed up - they are square pieces that have clearly come out due to the glue being week. I always keep the recirc on and have also checked the recirc filter (which would have droppings) if a rat had gone in.
The same thing happened on my i10 but the A** clearly said that it was pieces coming out from the insulation of the heating coil to prevent rattles.
Air-con: Center vents throwing out warmer air than side vents? 90Horses Technical Stuff 82 7th July 2015 16:03
Replacement for Foam filter oil heavy_foot Technical Stuff 1 3rd May 2011 14:28
Car made out of PU-Foam Sarvodaya The International Automotive Scene 7 7th October 2009 07:18
RACTIVE SF400 Foam Air Filter eagle_f1 Shifting gears 5 29th October 2007 20:39
pre charger or foam pre-cleaner for K&n Universal filter warchild Modifications & Accessories 6 13th August 2007 10:42
