Old 4th November 2006, 08:57   #1
GTS
Default Front windshield fully frosted in the Baleno
Good folks, I have a query....when I took out my baleno this evening, the a/c was on and the front windshield got fully frosted on the outside and i had to use the wiper intermittently, if I didnt, the whole thing got blocked so badly that I couldnt see at all.
The a/c settings:
A/C on
Circulation mode
Cool mode
The a/c control switch was set to ventilation mode so that air comes out through the centre and side outlets(the left extreme switch)
Regards.
GTS
This query may sound dumb, but I am at my wits end. What to do, 'I am like this only no' !
GTS is offline   Reply With Quote
Old 4th November 2006, 11:35   #2
aZa
aZa's Avatar
Thanked: 17 Times
This is normal GTS! try not to put the blower on the Windsheild to avoid this...
Old 4th November 2006, 12:07   #3
nitrous's Avatar
Thanked: 285 Times
Doc, It took me elementary science to understand this phenomenon.
Basically whats happening is, the water-vapour(gas) is coming in contact with a cool surface(ur windshield) and condensing to water(frost).
So, the solution to this problem is to heat up the windshield.
Old 4th November 2006, 12:29   #4
Shan2nu's Avatar
Thanked: 89 Times
Just try and keep direct A/C flow away from the windshield. Lower the cooling a bit if that doesn't work.
Shan2nu
Old 4th November 2006, 14:19   #5
Try keeping the A/C in "fresh air" mode and the vents in the "face" mode.
hrag is offline   Reply With Quote
Old 4th November 2006, 22:43   #6
baleno's flapper motors which direct air to different vents tends to get spoilt happened in a friends car, so even after you direct all the air to face and feet mode the air still pops up below the windshield..
Kinetik is offline   Reply With Quote
Old 4th November 2006, 22:54   #7
bayuin2004's Avatar
nitrous is correct,when the air from the a/c vent hits the winsheild then a patch is formed out side the windsheild...
bayuin2004 is offline   Reply With Quote
Old 5th November 2006, 02:05   #8
danlalan's Avatar
Thanked: 135 Times
well i had this same problem in my ikon too...on both the passengers side and drivers side....so i took a some electrical tape and taped the slits(vent) on the drivers side on the dashboard....so now its ALL Clear....no more frosting....
danlalan is offline   Reply With Quote
Old 5th November 2006, 23:30   #9
esteem_lover's Avatar
Thanked: 451 Times
keep the blower in the minimum speed & direct all the vents towards the floor. this should keep your windshields clear for an hour or so. also make a habit of switching off your ac when your car is idling, as in waiting at a signal or in traffic jams. hope that helps
Old 6th November 2006, 08:22   #10
GTS
Default Thanks folks!
Phew, am I relieved! Though common sense told me that this could be very normal, being a new owner, I was a tad worried that some part of the a/c had conked.
Thanks folks for all your reassurances. Saves me a trip to the mechanic!
Shan2nu: I have noticed a lot of threads wherein you are one of the first persons to respond with a suggestion or being helpful. You truly are a distinguished Bhp-ian! Hats off to the mods!
Crack in front windshield a4_attitude Technical Stuff 52 29th May 2012 12:04
CAUTION!!! Swift Owners installing Front Windshield Sunfilm Pace in Blood Modifications & Accessories 95 23rd June 2011 11:33
Zen Vxi – front windshield broken help req ! nicejits Modifications & Accessories 18 11th February 2010 12:35
How to access the inside of the Vents below the Front windshield glass? rajdoll Technical Stuff 6 5th December 2008 13:49
Honda City ZX - Broken front windshield alabjarus Technical Stuff 2 3rd October 2007 18:28
