Closed Thread
Thread Tools
Old 5th November 2006, 23:12   #1 (permalink)
narayan's Avatar
Default starting problem in OHC :URGENT
i had gone on a vacation for around 10 days and left my battery's black terminal disconnected. when i was back, the car just wouldnt start...
i checked the battery - it has the green ring which as per the sticker means battery is fully charged. finally i push started the car, but the car was giving out some visible amount of smoke...its been raining here in chennai last 10 days..wat do u guys think is the problem ?
is the battery dead depsite being disconnected ?
battery shows green glow which means full charge ( can there be a prbolem with the display ? )
are there any other systems that could have got damaged due to 10 day non usage ? ( car is in pristine condition otherwise )
want to chek out these things before taking the vehicle to the honda guys who would any way rip me giving various reasons...
pls help
narayan is offline
Old 6th November 2006, 00:44   #2 (permalink)
esteem_lover's Avatar
did your car crank when you tried starting it ?
did you tighten the terminals properly ? (mostly the reason)
even if your green glow is there, please take the car to the nearest battery centre & have the battery checked before you go to Sundaram Rippers.
__________________
Goodbye Dada, you made us proud.
esteem_lover is offline
Old 6th November 2006, 22:12   #3 (permalink)
narayan's Avatar
thanks ...checked out the battery. one of the cells was gone despite the green light glowing...
moderator pls close this thread..
narayan is offline
Closed Thread
Thread Tools
Indica starting problem fariborzpz Technical Stuff 13 29th September 2008 20:25
palio D starting problem garychopper Technical Stuff 7 19th August 2007 21:39
Palio starting problem amit Technical Stuff 29 28th February 2007 11:42
palio 1.2 starting problem. passionpurple Technical Stuff 8 9th June 2006 00:24
Starting Problem. zulfikar Technical Stuff 6 6th May 2005 11:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
