Old 28th January 2009, 14:10   #196
Try and find Elf DALF, use it sparingly at 40ml for every 40L, this is one of the few products that remove crud as well as carbon deposits from head. Use it sparingly on need to use basis and no more than 4000km gaps. If you can't find that, STP diesel injector cleaner is another product that truly cleans the cowebs off dirtly system.
Gurkha is offline   Reply With Quote
Old 28th January 2009, 15:56   #197
greenhorn's Avatar
Thanked: 1,491 Times
i use 10 ml / 500 bucks worth diesel ~14.1L now . its a bit less than their recommended dosage.
Old 16th February 2009, 10:52   #198
Narencar's Avatar
I have purchased a new Santro in December 2008 so can i use the System G in my car as i read through this forum that in new car we should not use the System G.
Please suggest me as i have already purchased the same but still not use it.
Narencar is offline   Reply With Quote
Old 16th February 2009, 11:01   #199
greenhorn's Avatar
I'd suggest you wait until 1000~5000Kms to start using them
Old 16th February 2009, 20:20   #200
Raccoon's Avatar
Thanked: 105 Times
What is the rationale behind not using System G for 1 - 5 K Km??
I suggest you start using it immediately, to keep your engine clean right from the begining!
Old 16th February 2009, 20:23   #201
greenhorn's Avatar
i thought a new engine would be clean in the first place
Old 16th February 2009, 23:25   #202
Raccoon's Avatar
Thanked: 105 Times
Ya, so better to keep it clean to begin with...
Old 7th March 2009, 13:10   #203
Where in Bangalore can i buy System D??
I checked with BP stations, they dont sell system G, he said BPCL has stopped it.
keyank is offline   Reply With Quote
Old 7th March 2009, 17:16   #204
Raccoon's Avatar
Thanked: 105 Times
Contact IFTEX and ask them!
Old 7th March 2009, 17:50   #205
Thanked: 42 Times
Incase you do not get System G at fuel stations..check with the Ford dealers in Bangalore..they should have it.
zen91 is offline   Reply With Quote
Old 7th March 2009, 17:53   #206
Raccoon's Avatar
Thanked: 105 Times
I'v seen it stocked at oil dealers and auto-spare parts shops also.
Old 7th March 2009, 18:08   #207
greenhorn's Avatar
and car acessories shops too. the pumps would rather sell Premium fuel than these additives
Old 8th March 2009, 08:42   #208
dilipkumar7278's Avatar
Thanked: 23 Times
Default Fuel for Swift
Guys
I have bought a used 4 month old swiftVDI(6400 kms).Can I fill xtrapremium or Hi-Speeed diesel or you guys recommend normal diesel? The experience filling premium diesel in my lancer is that the car is more smoother to drive.Here in cochin no pumps stock STP or other additives.Only sonax diesel treatment available in emperor.Should I use it in my swift?Please I need your suggestions..
Dilip Kumar
dilipkumar7278 is offline   Reply With Quote
Old 8th March 2009, 08:53   #209
greenhorn's Avatar
I dont think folks have seen much difference using system D on the MJD engine. It doesnt hurt to try though
Old 8th March 2009, 09:19   #210
Thanked: 54 Times
I usually get System-G in the petrol pump (HP, I think) that's a stone's throw from Leela Palace on airport road. If they are stocking system-G, then they must be keeping the D variant also.
floyd is offline   Reply With Quote
A Comparison of (Fuel/Oil/Engine) Additives ibm_jennifer Technical Stuff 152 20th October 2016 18:03
STANADYNE Diesel Fuel Additives dadu Technical Stuff 61 15th April 2016 15:21
Fuel additives and octane boosters....do they really work? Shan2nu Technical Stuff 25 5th September 2015 08:09
Fuel with additives ? Are they good for NEW cars ?? Venkatr Shifting gears 6 23rd February 2009 14:30
Fuel Additives nosfreak Motorbikes 1 14th November 2007 07:22
