Old 20th November 2009, 16:32   #271
condor's Avatar
Thanked: 4,554 Times
@vdiatech, try BP / (& esp) HP also and see which suits your car better.
Old 20th November 2009, 18:33   #272
Raccoon's Avatar
Thanked: 105 Times
^^^ I'd say you guys are going down the wrong route. Its not about which gas you use - BPCL/HP/Shell/etc. Its about the adulteration. Personally, I have found the fuel efficiency and feel the same between a BPCL COCO and Shell bunks. If I fill elsewhere, difference is immediately there.
Old 21st November 2009, 20:32   #273
I am facing a peculiar situation.
My Esteem was behaving as if it had asthma while climbing mild slopes. Used System G just to see if it made a differance. The car`s behaviour improved but when it when bottle finished its worse than before.
Any suggestions ?
dashoin is offline   Reply With Quote
Old 21st November 2009, 20:44   #274
vdiatech's Avatar
Thanked: 7 Times
Any suggestions ?
Hi , kms done, service history, oil used/change frequency, ?
cheers
vdiatech is offline   Reply With Quote
Old 24th November 2009, 18:35   #275
cheers
46 K, regularly serviced, regular mineral as I change every 6 months / 5k kms.
bought it 2nd hand with 30 K km the clock - previous owner was a retd defence officer - primarily because I wanted to convert to CNG. havent got round to doing that till now
No issues with the car otherwise.
Old 24th November 2009, 18:55   #276
Thanked: 397 Times
Any suggestions ?
Try changing Air filter first to start with
amitk26 is offline   Reply With Quote
Old 24th November 2009, 19:41   #277
Done about 6 K back - cleaned the air filter about a month back.
Old 24th November 2009, 22:44   #278
Jaguar's Avatar
Thanked: 149 Times
Originally Posted by bj96 View Post
Just got a bottle of each. System-G is 50% more expensive than System-D. Any reason why? Is it plain marketing or cost of manufacturing differentiates too?
-BJ
Is it just me or do you guys also feel that sizes of both the bottles are identical? If so, how come one is 250ml while the other is just 200ml?
Jaguar is online now   Reply With Quote
Old 25th November 2009, 05:57   #279
condor's Avatar
Why shouldnt the manufacturer use his old stock of bottles - as long as the correct quantity is mentioned on the label ?
It's the same bottle, but diff color.
The quantity in the System-G was reduced recently
Old 26th November 2009, 01:05   #280
Jaguar's Avatar
Thanked: 149 Times
So are you saying that the quantity is indeed less in-case of system-G? I thought it was either a mistake or cheating by the manufacturer.
Old 26th November 2009, 07:24   #281
condor's Avatar
This is a recent development :
1. Increase in price of System-D from 200 to 250 for the same 250 ml
2. Decrease quantity while increasing price (200 ml instead of 250 ml, and 300 Rs instead of 250 Rs).
We cannot call it outright cheating by the manufacturer since the quantity & MRP has been mentioned on the containers.
Now, the point about using the old 250 ml container in the above case (#2) is something I dont approve of, and definitely not in the long run. I hope they have the basic courtesy to change the bottle as soon as their current stock of 250 ml bottles are exhausted.
Old 28th November 2009, 23:23   #282
IndigoXLGrandDi's Avatar
Thanked: 160 Times
Mahindra & Mahindra has given in the Owner's Manual of Xylo "NEVER ADD FUEL SYSTEM ADDITIVES OR CLEANING AGENTS.THESE MAY DAMAGE THE SYSTEM".
That means ONLY Normal Diesel Conforming BSIII should be used.
Any Information in this matter?
IndigoXLGrandDi is offline   Reply With Quote
Old 28th December 2009, 12:53   #283
Thanked: 91 Times
Yesterday the aftermarket dealer asked me to go for a Pidilite Imported Formula 44 for my Fiesta, when i asked for System G.
i purchased the same but later had different thought to go for as recommended by ford only, so bought the thing for my older baby Wagon R (may be she needs a refreshment more than the fiesta)
ruchirtnt is offline   Reply With Quote
Old 28th December 2009, 14:16   #284
condor's Avatar
IndigoXLGrandDi : Mahindra & Mahindra has given in the Owner's Manual of Xylo "NEVER ADD FUEL SYSTEM ADDITIVES OR CLEANING AGENTS.THESE MAY DAMAGE THE SYSTEM".
Tata also advises against using additives - but only for the Dicor engines. But AFAIK, Ford doesnt say anything like that. So, it depends on the manufacturer.
Old 30th December 2009, 10:07   #285
Thanked: 91 Times
Got a Letter from Dealership where it was clearly written that Ford recommends use of Iftex system G for petrol and Iftex system D for diesel.
A Comparison of (Fuel/Oil/Engine) Additives ibm_jennifer Technical Stuff 152 20th October 2016 18:03
STANADYNE Diesel Fuel Additives dadu Technical Stuff 61 15th April 2016 15:21
Fuel additives and octane boosters....do they really work? Shan2nu Technical Stuff 25 5th September 2015 08:09
Fuel with additives ? Are they good for NEW cars ?? Venkatr Shifting gears 6 23rd February 2009 14:30
Fuel Additives nosfreak Motorbikes 1 14th November 2007 07:22
