Old 18th August 2010, 12:24   #361
funnyguru's Avatar
Has there been any considerable performance enhancement with IFTEX?. Any experiences'
funnyguru is offline   Reply With Quote
Old 18th August 2010, 13:30   #362
Thanked: 245 Times
Its not a Magic potion to enhance performance, its a mild additive that cleansthe fuel system, thats it. Now depending on your engine condition you might experience negligible to good improvements.
Old 18th August 2010, 16:29   #363
leadf00t's Avatar
Thanked: 12 Times
Originally Posted by ghodlur View Post
The price you have quoted is correct. I normally get the System G from the BPCL petrol pump where I normally refuel every time.
Which BPCL pump in Thane are you referring to?
I didnt get System G in any store in Thane .
leadf00t is offline   Reply With Quote
Old 19th August 2010, 08:29   #364
ghodlur's Avatar
Thanked: 2,263 Times
Smile
The one at Majiwade, I got IFTEX Clean System G yesterday for 299/- when I refuelled there. The cost of the bottle is for 200 ml.
ghodlur is offline   Reply With Quote
Old 19th August 2010, 09:22   #365
rapideffect's Avatar
I have finished a bottel(5 Tankfuls) and trust me there is no major difference you would notice, its all psychological. At least this is what i experienced in my case, my car is extremely well maintained, so no issues of car being bad and nothing works and i dont feel its "the magic portion" for your engine.
Pramod
Yeah, I have been using System G for more than a month by now and I couldn't feel any difference.
rapideffect is offline   Reply With Quote
Old 19th August 2010, 09:49   #366
condor's Avatar
Thanked: 4,569 Times
@pramodkumar & @Rapideffect - how much have your cars run ?
@RE, how many tank full's of fuel in 1 month ?
Old 19th August 2010, 17:31   #367
hi all,
i drive a Santro, Bharat Stage 3.
Is Sys G recommended?
I fill up, full tank once a week. 27 litres.
How much System G should I add?
Please help.
sameern.85 is offline   Reply With Quote
Old 19th August 2010, 17:46   #368
condor's Avatar
Sameer, you can use Sys-G.
First time : 40 ml ( assuming your tank capacity is 40 litres)
Next time : as many ml as the num of liters you fill
Same cycle each time you take a break from using Sys-G
Old 19th August 2010, 17:52   #369
Thanked: 21 Times
Originally Posted by sameern.85 View Post
hi all,
I am not sure about whether it is officially recommended for BS3, but logically BS4 impemented this year and the product is in market from long time. I have used it in my 2007 WagonR.
For your second query, Its recommended value is 1 ml to a litre of petrol, in the bottle is there are markers for 10, 20 & 30 ML, press the bottle the solution will come to appropriate mark/level and put in the tank before filling.
so app 30 ml for 27 ltr. I have seen Most of the pump attendent are aware of this product and they fill it accordingly.
shabahmad is offline   Reply With Quote
Old 19th August 2010, 18:16   #370
Thanks Condor...
Thanks Shabahhmad...
Appreciate it.
Old 19th August 2010, 18:34   #371
Gilead's Avatar
Thanked: 21 Times
Condor, does the engine become coarse or a little sluggish if System G is stopped after a period of usage? I have a Fiesta petrol and I am thinking of putting System G. My concern is what happens if the product is discontinued.
Gilead is offline   Reply With Quote
Old 19th August 2010, 20:52   #372
condor's Avatar
shabahmad : ... in the bottle is there are markers for 10, 20 & 30 ML,
No, the bottle has markers for only 5ml & 10 ml.
Gilead : .. does the engine become coarse or a little sluggish if System G is stopped after a period of usage?
When you are using it, your injectors etc are cleaned of any foreign particles .. and the engine feels smooth. When you stop using it, you will not feel a difference immediately. Gradually, the foreign particle deposits increase and the engine smoothness will also reduce at a gradual rate. You will not even notice it - Till you use Sys-G again.
I dont think it is harmful to use it intermittently. I feel using it intermittently actually optimizes the usage while retaining benefits of it's usage.
Old 19th August 2010, 21:08   #373
MX6
MX6's Avatar
Thanked: 210 Times
1 ml per litre of petrol. I've been using Sys G since last 1 year on my BSIII ikon. 31K kms driven till date. I've seen some excellent mileage. 13 - 13.5 in city and 17 - 18 in highways. Ofcourse, I'm lightfooted. Rarely exceed 100 kph on highways and never cross 3000 rpm.
Sys G is cool.
MX6 is offline   Reply With Quote
Old 19th August 2010, 21:19   #374
dhanushs's Avatar
Thanked: 4,155 Times
Can someone shed some insight on pumps which have System G/D (IFTEX) in northern part of Kerala?. I mean, in Thrissur, Calicut, Kannur, Wayanad districts.
Old 19th August 2010, 21:25   #375
condor's Avatar
@Dhanushs - check the Ford service centers. Or Tata service centers.
A Comparison of (Fuel/Oil/Engine) Additives ibm_jennifer Technical Stuff 152 20th October 2016 18:03
STANADYNE Diesel Fuel Additives dadu Technical Stuff 61 15th April 2016 15:21
Fuel additives and octane boosters....do they really work? Shan2nu Technical Stuff 25 5th September 2015 08:09
Fuel with additives ? Are they good for NEW cars ?? Venkatr Shifting gears 6 23rd February 2009 14:30
Fuel Additives nosfreak Motorbikes 1 14th November 2007 07:22
