Old 19th July 2012, 08:11   #466
ghodlur's Avatar
Thanked: 2,263 Times
Smile re: The fuel additives thread
Originally Posted by Athani View Post
Can someone please list a few places where System G is available in Mumbai - especially the city and western suburbs. Thanks.
You should be able to find it at any BPCL petrol pump or at any authorized Ford dealer/workshop (IMO).
By any chance if you are in Thane, you will definitely find one at the BPCL pump at Majiwade.
ghodlur is offline   (1) Thanks Reply With Quote
Old 19th July 2012, 08:14   #467
condor's Avatar
Thanked: 4,569 Times
Default re: The fuel additives thread
Check Ford A.S.S - they normally have it.
condor is offline   (1) Thanks Reply With Quote
Old 19th July 2012, 09:34   #468
sgiitk's Avatar
Thanked: 3,814 Times
If the effect is so positive, then why do they clearly recommend against the use of these things in the modern Crdi engines? I understood it is because it leaves a sticky gummy deposit in and around the fuel injectors which has a detrimental effect!
Clarifications welcome!
What I am told is that many CRDI engines tend to smoke on acceleration with Premium Diesel and maybe System D. Hence Premium Diesel was also not recommended.
I am not sure whether it was a effect of the clean up or did it persist. I will suggest what I do (with G) - add it once every few fills.
Old 19th July 2012, 15:03   #469
shankar.balan's Avatar
Thanked: 5,334 Times
Thanks but I don't think I will risk these additives in my Yeti.
Don't want to gum up the works, quite literally!
Old 19th July 2012, 15:31   #470
Thanked: 88 Times
The quality of Iftex is not as good as its supposed to be. I do not recommend use of G or D in any car. If at all someone wants to use an additive, use a dependable product that has been brought in from abroad by some marketers.
I used Redex in the old days in carb engines and it did wonders. In modern fuel injection and with metallurgy changed for the valves and seats, and design for unleaded, these additives are really not required. Maybe once in a few months a little spray of carb cleaner thru the intake should clean the throttle body, injectors and valve body etc of deposits.
scooby05 is offline   Reply With Quote
Old 24th August 2012, 15:28   #471
Thanked: 572 Times
I've been using Iftex System-D in my Xylo mEagle, but not very regularly. Once I buy the bottle, I use it consecutively for 3-4 tank fulls and then leave the bottle aside for another 8-10 tank fulls. Then again repeat the process. Also, while going on long trips, most of the times I have added. My dosage is always bit less than 1ml / litre. Its been quite long that I've just been on normal diesel; Premium diesel isnt available easily on my regular routes.
My observations: after adding, in most cases, the DIS console generally shows an increase in mileage (fuel economy) by +1 (decimals not shown) and the actual mileage (tank-full method) also shows 0.3-0.8 increase. Noteworthy, my route remained exactly same before and after this additive, in city roads where speeds varies between 0! to 60, and average speed as in DIS shows 30-40! Though long trips are not very frequent, but whenever done every few months, I do get a chance to accelerate beyond 100, which ofcourse breaks the mileage. But, I read somewhere that sometimes spirited drives will help “cough-out” and kinda automatically decarbs the system. I can safely assume a positive impact of having combination of such drives and system-d.
FYI, at different intervals, I did try 2-3 times adding 2T oil to diesel tank (~0.8ml/litre), but was always worried of negative effect, and also wasn’t able to gauge a positive impact (engine smoothness, mileage) in actual.
Since, system-d hasn’t shown a direct negative impact (havnt seen, so don’t know of the engine internals!), I would not mind continuing my process. Experts and Xylo users can pour their valuable comments.
thanks,
pcpranav is offline   Reply With Quote
Old 24th August 2012, 16:15   #472
SR71A's Avatar
Thanked: 72 Times
Dear Motorists,
I have some info on this as I am working for an Oil company.
1. Fuel additives are generally detergents with some lubricating properties. They work by cleaning the gumming left by fuel as it polymerizes under heat and pressure at injector nozzles, valves etc.
2. System G & D and other additives meant for Petrol & Diesel are designed to clean polymers left by these two differing Hydrocarbon mixtures. Diesel additives are generally stronger as Diesel contains more aromatics, and branched hydrocarbons.
3. Oil Companies generally do not manufacture these additives but endorse them to earn some revenue.
4. OEMs do not endorse these additives as it is expensive to study the effects of these additives over long terms on an engines performance. No additive manufacturer is willing to foot the bill for such testing. Also the effects these external additives have on your Catalytic converter and other Exhaust Gas quality sensors are undocumented.
5. Additives were important when we were getting plain Vanilla Petrol & Diesel as the specifications of these products was very wide and Oil companies could play with the composition resulting in large amounts of aromatics & branched hydrocarbons (which polymerize easily), not to mention sulphur passing into both fuels.
6. With the advent of Euro III (Available pan India) & Euro IV fuels (available in Metros, and will be available pan India by 2013), external additives are not very useful, as these fuels already have a “keep clean” dose of Approved & Tested additives in them. Also Euro IV fuels have an extremely tight specification range and mostly have straight chain hydrocarbons, therefore have lesser concentration of Hydrocarbons that will gum/ polymerize under heat and pressure.
7. Unless you have had a brush with adulterated fuel and your injectors are getting clogged, external additives are not required. Any such defect can easily be corrected at the ***.
Hope the above Helps.
Happy & safe Motoring.
SR71A is offline   (10) Thanks Reply With Quote
Old 27th August 2012, 02:45   #473
Athani's Avatar
Thanked: 7 Times
Originally Posted by swarnava.m View Post
I don't know whether this has already been discussed on this thread before, but today I discovered a major discrepancy in the measurement nozzle on the System G bottle.
For those who have used it, you must have seen that there are 5ml and 10ml markings on the nozzle at the top of the nozzle, and we squeeze the bottle until the liquid fills up till the desired level. I observed that the small mark above the 5ml engraving, which should be considered as the reference for measuring the quantity, is very much inaccurate. It is actually much closer to 15 ml.
5 ml is approximately filling up the lower conical part of the nozzle, till the point where the shape of the nozzle changes into a straight cylinder. I have measured it using a laboratory measuring bottle.
I am not sure why this discrepancy is, but it could be an unfair marketing strategy by IFTEX to ensure that the contents of the bottle are used up quicker than normal, thus boosting sales. I have had only 2 tankfills with System G before this, and am not sure whether the additional quantity I have added has caused any harm to my car. Touchwood!
If anyone else has observed anything similar, kindly share your views here.
This post seems to have gone unnoticed. It's a scandal, if true. Those guys deserve to have their pants sued off them :O
Athani is offline   Reply With Quote
Old 20th September 2012, 07:48   #474
condor's Avatar
.. but today I discovered a major discrepancy in the measurement nozzle on the System G bottle.
.. there are 5ml and 10ml markings on the nozzle at the top of the nozzle, . . I observed that the small mark above the 5ml engraving, .. is very much inaccurate. It is actually much closer to 15 ml.
Guys, please check before you post something like this. The markings on the bottle are very much Accurate. The 5ml is exactly at the mark on the bottle, and the 10ml is reached when the letters "10 ml" are covered. I did a double check by pouring 5 ml & 10 ml of fluid into a used bottle.
@Swarnava, I'm sure such measurements have to go by the weights & meaures dept. Also, this measure is easily verifiable, and the company would not do such a mistake.
Old 20th September 2012, 08:48   #475
swarnava.m's Avatar
Thanked: 256 Times
In that case, I have a doubt that what I received is not a genuine product. I will click some pictures and post them, to justify my claim. It can be easily seen how inaccurate the measurements are. In my opinion, it is not that the company is not aware that such measures can be verified, but its more along the lines of the company believing that very few people, if any at all, would go to verify these measurements.
swarnava.m is offline   Reply With Quote
Old 20th September 2012, 10:06   #476
sgiitk's Avatar
Now with Premium fuesl going through the roof, additives will become far more a topic of discussion.
I do not use them very regularly, but put System G in once every 4-5 fills on my Santro, and maybe once every 8-10 fills in the Civic (Honda does not recommend Premium Fuel for their cars, hence this extended interval).
Old 20th September 2012, 10:31   #477
condor's Avatar
SG sir, I would suggest 2 full tanks in succession, and then a break.
Why ? the company suggests that the difference can be seen in 2 tank-ful's.
Old 20th September 2012, 11:18   #478
sgiitk's Avatar
@condor; This is for a badly gummed up engine. Two points here - the refining process has been changed starting BSII (definitely BSIII) so the gumming is much less. I have seen some improvement in my Civic but none in the Santro. I will keep the idea in mind, but may stick with my current policy.
Old 20th September 2012, 13:54   #479
Thanked: 19 Times
Can anyone please help me in knowing where I can buy Iftex sys G in Pune? I have been trying to buy it for many months, but was not able to find a store/seller.
trave11er is offline   Reply With Quote
Old 20th September 2012, 15:10   #480
condor's Avatar
@Trave11er, try Ford A.S.S - they normally have some in stock.
A Comparison of (Fuel/Oil/Engine) Additives ibm_jennifer Technical Stuff 152 20th October 2016 18:03
STANADYNE Diesel Fuel Additives dadu Technical Stuff 61 15th April 2016 15:21
Fuel additives and octane boosters....do they really work? Shan2nu Technical Stuff 25 5th September 2015 08:09
Fuel with additives ? Are they good for NEW cars ?? Venkatr Shifting gears 6 23rd February 2009 14:30
Fuel Additives nosfreak Motorbikes 1 14th November 2007 07:22
