Old 22nd January 2015, 21:34   #571
Thanked: 372 Times
Default re: The fuel additives thread
What would be recommended for the 1.2 TSI engine?
I am using speed 97 right now.
STP petrol was available at BP, system G wasn't.
H_Dogg72 is offline   Reply With Quote
Old 23rd January 2015, 11:39   #572
Thanked: 657 Times
Look for "Servo Adon P" at IOC bunks only. Approximately Rs. 280 for 200 ml.
Motard_Blr is offline   (1) Thanks Reply With Quote
Old 24th January 2015, 20:04   #573
Thanked: 372 Times
I got 100ml for 175.
Did an Italian tuneup as well.
Is it suitable for direct injection or should I go for STP?
Old 25th January 2015, 11:48   #574
Thanked: 657 Times
Good price! I'm not sure about compatibility with direct injection (petrol, I presume). Here's the website for the product: http://www.neopetconindia.com/pro_ServoAddonP.html
Motard_Blr is offline   Reply With Quote
Old 20th April 2015, 22:55   #575
vnabhi's Avatar
Thanked: 1,300 Times
Guys
Anyone knows where I can buy system G and D? Ford dealerships and BP outlets are not having it in stock for the past 2 years or so.
Old 21st April 2015, 00:01   #576
Thanked: 420 Times
Originally Posted by vnabhi View Post
Guys
Try at an Tata A.S.S you can straight away walk to spare parts counter and ask.
Also they have Bardhal Injector cleaner which is really good it is not for regular use but for once in a while use to correct misfiring due to clogged injector.
amitk26 is offline   (1) Thanks Reply With Quote
Old 25th April 2015, 14:20   #577
Heavy Horse's Avatar
Thanked: 295 Times
My Experiments with ADON-D : Update 1 April 4, 2015
Key Result: Mileage improvement continues at 11% over baseline covering over 9000 Kms
Since my last post , I continue to use ADON-D as an additive on a regular basis at 0.5 ml per litre of diesel.
Since then, I have made highway trips to Goa, Bangalore, Puducherry, Nagarhole etc.
Mileage data updated till April 4, 2015 is as follows:
Heavy Horse is offline   Reply With Quote
Old 30th May 2015, 07:47   #578
PatienceWins's Avatar
Thanked: 282 Times
Any place where system G is available near Marathahalli/ Whitefield? I checked in the BP pump near cosmos mall and they did not have any idea.
PatienceWins is offline   Reply With Quote
Old 30th May 2015, 21:52   #579
Tazzy Boy's Avatar
Thanked: 7 Times
Not sure about marathahali and whitefield. But it's available in the BP bunk near brigade the one opp to imperial hotel
Tazzy Boy is offline   (1) Thanks Reply With Quote
Old 31st May 2015, 16:34   #580
dinu2506's Avatar
Thanked: 348 Times
Also seen it at BP, Tippasandra
dinu2506 is offline   (1) Thanks Reply With Quote
Old 1st June 2015, 10:11   #581
sgiitk's Avatar
Thanked: 3,867 Times
I will be surprised if the IOC ADON is very different. So might as well use that.
sgiitk is offline   (1) Thanks Reply With Quote
Old 1st June 2015, 12:42   #582
Thanked: 43 Times
Added the Abro Diesel Injector cleaner for my Swift VDI, odo @ 83K, last addition was 40k back. Totally took me by surprise, the way the engine pull had changed. Refinement has went up a notch & the turbo push in the 4th gear is awesome. Good product to use.
Adi22 is offline   Reply With Quote
Old 1st June 2015, 17:07   #583
Thanked: 115 Times
thats good. Did you pour the entire content at one go ? whats the bottle size ?
just to be sure , we need to mix it with the diesel tank, right ?
Amazing is offline   Reply With Quote
Old 1st June 2015, 17:12   #584
n_aditya's Avatar
Thanked: 2,755 Times
Gentlemen, please be cautious using these additives in your cars.
See this (Fuel additives and octane boosters....do they really work?).
On the safer side, stick to a reputed fuel bunk for clean fuel and get your car serviced regularly. Using good quality oil can also help in longevity of the engine and related parts.
Old 1st June 2015, 18:25   #585
sgiitk's Avatar
One should not lose one's common sense. I add once every four or five tankfuls, quality of bunks is a given.
A Comparison of (Fuel/Oil/Engine) Additives ibm_jennifer Technical Stuff 152 20th October 2016 18:03
STANADYNE Diesel Fuel Additives dadu Technical Stuff 61 15th April 2016 15:21
Fuel additives and octane boosters....do they really work? Shan2nu Technical Stuff 25 5th September 2015 08:09
Fuel with additives ? Are they good for NEW cars ?? Venkatr Shifting gears 6 23rd February 2009 14:30
Fuel Additives nosfreak Motorbikes 1 14th November 2007 07:22
