Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 13th December 2008, 20:31   #151 (permalink)
How is Servo's Addon petrol additive? Costs something like 100rs / 100ml. It was green in color! looked like diluted coolant liquid
__________________
Without a real car, you are only half a man!
null is offline   Reply With Quote
Old 6th January 2009, 04:59   #152 (permalink)
Default Diesel Fuel Additives(for SAFARI 2.2dicor)
Folks, im totally confused if i should opt for diesel additives available in india for my safari 2.2dicor. does it add life to the engine/performance ..... ???
if any one has used, may recommend for/against its use.....
thx
prits_moh is offline   Reply With Quote
Old 12th January 2009, 11:00   #153 (permalink)
hrishig's Avatar
Default Has anybody tried it with NHC idsi?
I am using the IFTEX for past few months and my results are mixed.
Getz -> millage increased by 1+ KM/L ( HP normal petrol )
Santro -> millage increased by 1+ KM/L ( BP normal petrol )
NHC -> milage Decreased by ~1.5 KM/L ( IOC normal )
So just wanted to know what is wrong in the last combination ?
The honda / IOC / the IFTEX?
hrishig is offline   Reply With Quote
Old 12th January 2009, 13:41   #154 (permalink)
Could be IOC. I too have been using System-D & System-G for quite some time, and noticed a slightly better performance with BP normal (both petrol & diesel).
Anyway, FE is secondary ; I know for sure that System-D/G has helped the engine stay in better shape. In fact, I haven't noticed any significant increase in FE when I use System-D/G, but you can feel the 'happy' engine.
cheers,
__________________
Safari Dicor 2.2 [2007] / Zen [2001]
ak-47 is offline   Reply With Quote
Old 14th January 2009, 13:41   #155 (permalink)
hrishig's Avatar
cheers,
Interesting , I will now try with other petrol pump and company..
Old 14th January 2009, 14:12   #156 (permalink)
sgiitk's Avatar
Just to recall my experience with the Cielo and Esteem (Carb). There were no premium fuels then. I had gone to Gwalior and my father in law complained about his Cielo having gone totally wooden. On the advice of a local accessories dealer I put some STP in the Cielo and found an almost immediate improvement. So on a hunch I added STP to by Esteem also. Driving back to Kanpur I found the car a totally different kettle of fish. More responsive, smoother, ... My son who was sitting next to me felt the same. So I have used additives (Iftex G) or Premium Fuels ever since they became avilable shortly thereafter. They keep the fuel delivery system clean and smoother.
Regular use will not show such a dramatic improvement since the fuel system will be kept in good shape to start with. However, if you have done something like 5000km on regular, then you should really feel the difference.
A colleague did an extended test between Premium and Regular fuels and found a 5% improvement with Premium. Using additives can be approximated to Premium fuels. I have been told by a dealer than reducing the Iftex addition by a factor of 2 should get the same results.
__________________
Life is short, do not make it shorter!
Accent GLS 2002
Santro Automatic 2005
Old 14th January 2009, 14:17   #157 (permalink)
humm's Avatar
Regular engine servicing and proper clean fuel keeps my car at its best. I don't prefer to use any mixtures or additive petrol with my swift.
__________________
YoYo... Live n Let Live! :D
humm is offline   Reply With Quote
Old 16th January 2009, 12:47   #158 (permalink)
I recently asked BP guy to add SYS G while i was refuelling. But the guy said no need to add SYS G when u refuel car with SPEED.
__________________
Warm Regards,
Aashutosh
Aashutosh is offline   Reply With Quote
Old 19th January 2009, 19:57   #159 (permalink)
ravi@64bhp's Avatar
I have regularly used System G for my Wagon-R and my car used to run very smooth. These days, the BP petrol stations are not selling the SystemG. Where do I get the System G now?
__________________
03 HH Splendor - 28,000km
06 Kinetic Blaze - 10,700km
07 Kinetic Flyte - 8500km
06 HH Zma - 39,550km
07 WagonR Lxi - 36,500km
ravi@64bhp is offline   Reply With Quote
Old 19th January 2009, 23:55   #160 (permalink)
Raccoon's Avatar
Not just no need, but you shouldn't use System G if you are using Speed. But given a choice between the 2, System G + ordinary petrol is probably the better choice.
Just go to the IFTEX site contact someone from the sales/mktg dept, and tell them about it. They will surely help.
Old 20th January 2009, 10:22   #161 (permalink)
hrishig's Avatar
and economical tooo
I have seen this at few BP pumps ( near garware collage ) in pune
Old 20th January 2009, 16:23   #162 (permalink)
sgiitk's Avatar
Agreed. I found System G in car spare / accesory shops. Once the premium between the standard and premium fuels cross Rs.3.50 the sales of Iftex went up.
You do not need additives with Premium Fuels.
__________________
Accent GLS 2002
Old 27th January 2009, 15:41   #163 (permalink)
I have no experience but System D is one of the additive which i know about. It claims to clean the fuel injectors and avoids gumming and clogging. Most petrol experts agree to using the additives so i thought it might be true for diesel also. If i were u i did use it for sure. It costs Rs 295 and lasts for long.
amit_purohit20 is offline   Reply With Quote
Old 27th January 2009, 19:27   #164 (permalink)
thx
This is extensively discussed on Safari 2.2 problems / solution thread.
System D helps to keep injectors clean and If you are driving continuously in bumper to bumper City traffic then you may observe slight loss of power for about 1 second with a puff of smoke at lower gears ( Gasp issue) probably due to EGR valve being choked , System D solves this problem.
Owners manual recommends to drive at high speed once in a while to clear the carbon deposits.
amitk26 is online now   Reply With Quote
Old 27th January 2009, 19:47   #165 (permalink)
greenhorn's Avatar
jkdas tried out systemD on his 2.2 and didnt find a big difference. i think it makes a big difference only with older engines
__________________
'07 Indica DLG - Almost a DLX
Thread Tools
Fuel with additives ? Are they good for NEW cars ?? Venkatr Shifting gears 6 23rd February 2009 14:30
System Purge - Iftex toiingg Technical Stuff 12 19th August 2008 12:25
Fuel Additives nosfreak Motorbikes 1 14th November 2007 07:22
IFTEX System G - Cleans the Jets? ramkya1 Technical Stuff 4 6th November 2005 18:22
Fuel additives amitoj The Indian Car Scene 9 8th November 2004 17:14
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
