Old 2nd July 2017, 06:56   #31
Thanked: 672 Times
Infractions: 0/2 (14)
Default Re: Engine oil levels coming down, but there's no leak
Originally Posted by shashanka View Post
..... (https://www.scribd.com/doc/217856475...il-Calculation), which is a fair indication of how seriously lub oil consumption is taken in the marine industry.
After submitting the above post I found (when trying to study the above link in detail) that the site needs a subscription before the full document (33 pages apparently!) is allowed access. But I think I made my point that lub oil consumption is serious business, just like SFOC is!
shashanka is offline   Reply With Quote
Old 2nd July 2017, 08:06   #32
sudev's Avatar
Thanked: 2,320 Times
Originally Posted by blueaquan View Post
The car has already done 1.67Lakh. It has only been serviced in a MASS all these years.
Until 1.2Lakh or so, the engine was extremely smooth, but in the last 30K or so, I've had a rough noise emanating from the engine when I cross 80kmph-----
To use a popular Hindi film dialogue "bacche ki jaan loge?"
A car with that odo would have enough engine wear to warrant overhaul. Piston rings would be full carbon deposits and work. Valve stems and guides would have worn. All potential oil leakage points into the combustion. Corroborated by soot in exhaust.
Your SA is giving good advice. Overhaul can be many things including and up to half engine or fill engine replacement. MASS would typically do half engine replacement while FNG would probably rebuild engine replacing worn part with oversize one's.
sudev is offline   Reply With Quote
Old 2nd July 2017, 10:56   #33
sgiitk's Avatar
Thanked: 3,736 Times
At the end of the day, let us consider the oil cannot be vanishing into thin air. It must either be dropped/vented or being burned.If the first is ruled out then must be the latter. One point which is very tough to catch is the 'blow by'.
Old 2nd July 2017, 11:25   #34
Thanked: 6,141 Times
Lub oil consumption in IC engines does not seem to have such a detailed approach (at least I didn't find one after a cursory surf).
Yes, it does! If you look closely on page 2 of the link that you provided you will see that one of the main input parameters is SLOC= Specific Lubricating Oil Consumption.
Now, the question remains, is that calculated or derived from a testbed?
Jeroen
Jeroen is offline   Reply With Quote
Engine oil leak? fine69 Technical Stuff 54 24th August 2017 09:02
Honda Amaze: Oil leak, engine seized! A bad experience with Honda service parimal_g Technical Stuff 165 28th March 2017 22:45
Diesel Cars: Down, down, down! Market share = 34% S2!!! The Indian Car Scene 66 2nd June 2016 16:21
Maruti Ertiga VDi - Engine oil leak. EDIT : Issue resolved on Page 3 S5157 Technical Stuff 61 6th December 2015 17:55
Pulsar 220 engine oil leak ravi_23 Motorbikes 6 15th October 2013 13:22
