| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Sorry if this has been discussed before. I tried the search function, but says there is a database problem right now. Anyways, I was on driving on this rough patch of road early morning today - it is a totally kuccha road, the kind more suited for a Mahindra Classic. The road is all small boulders/stones. My WagonR was having a rough ride...and I was in 2nd/3rd gear. Then when I step on the accelerator, I suddenly notice that the gear has gone to neutral! For a moment, I felt maybe I did not shift properly while changing gears, but on recall I think my gear shift went fine. Why the gear "jumping" to neutral then? Is something seriously wrong with my 6-month old car's transmission? On earlier incident - a few months back, I had a similar kind of situation in the middle of city traffic where I had problem shifting gears and the gear was sort of stuck at "neutral" it seemed. When I showed the car to the Maruti Service Center, they attributed it to a very "free clutch" and so the made that a little tight...and the problem did not recur. Now, I have just had my car's 2nd free service last week and the mechanics there had made the clutch too tight this time, so I told them to free it up, and it is back to the preservice state - what I would term "not too free" (like earlier). My questions: 1. Is the "jumping" to neutral because of the clutch being "loose/free?" 2. Is there something seriously wrong with the transmission/car? 3. I am sure a rough patch of road should not cause the gear to jump from 2nd/3rd gear to neutral - or can it? Comments awaited Thanks in advance. |
| | #2 (permalink) |
| BHPian Join Date: Jul 2004 Location: Madurai
| A really bad road could jolt your gear into neutral. Your gear shift is connected throught cables to your gearbox. A big jolt could knock you lever into neutral . A big hump could just graze your gear linkage and shift it into neutral too. A defective gearbox would slip its gears on any kind of road. i dont understand how your clutch could be loosened and tightened. Maybe they were just using pedal springs of various tensions??
__________________ Live Life King Size! |
| | #4 (permalink) | |
| Senior - BHPian | Quote:
as jyobeb says, a defective gearbox would cause issues on any surface, not just bad ones. | |
| | #5 (permalink) |
| BHPian | I am not sure of what I am talking, because it is hearsay. One of my friend had the similar issue, and it used to jump to neutral even in city traffic. Appearantly, the dealer, when contacted said said it is a problem with a perticular batch, and rectified the problem. His car is almost an year old. I can confirm it tomorrow when I get in touch with him.
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! |
| | #6 (permalink) | |
| Team-BHP Support ![]() | Quote:
@ Johy - Since yours has taken place only on one instance, I dont think you need to worry about it.
__________________ GTO Change the way you think, and watch the world change around you.
| | #7 (permalink) | ||
| BHPian | Thanks for your replies everyone. Quote:
All in all, I must say I did enjoy that stony patch of road! No wonder, people die for driving those 4x4s! | ||
| | #8 (permalink) |
| Team-BHP Support ![]() | I dont think you have to worry for a one off incident. Once I hit a big pothole at high speed. Apart from a bent rim, the gearshift jumped to neutral due to the jolt. This has never happened again. When this happened the car had done just around 20,000kms, not its at almost 70,000 with no problems.
__________________ Reclaiming.....! |
| | #9 (permalink) |
| Newbie Join Date: Nov 2006 Location: mumbai
| I had a similar problem with my maruti 800. The gear used to suddenly jump to neutral while in 3rd or 4th.... It was found that the Gear Oil was leaking. So when the oil level dropped down considerably the problem used to occur. It got rectified once the leak was fixed. This might or might not be the problem in your case but it is a possibility |
| Thread Tools | |
Similar Threads | ||||
| Which is your fav "Top Gear" video? | Shan2nu | Shifting gears | 16 | 29th November 2008 22:08 |
| Finally !! - Long awaited "BEFORE" & "AFTER" pics of my Avenger 200 !! | VSG12777 | Motorbikes | 23 | 16th June 2008 20:26 |
| Audi RS5 "M3 beater?" to be launched early next year "PICS" | highwayblaze | The International Automotive Scene | 9 | 18th May 2007 02:59 |
| Top Gear starts a new "Star in a reasonably priced car" chart. | Shan2nu | Shifting gears | 16 | 30th January 2006 02:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478
