Old 10th August 2017, 07:03   #1
hserus's Avatar
Thanked: 2,701 Times
Default Mazda plans a new engine using both - compression & spark ignition
https://www.topgear.com/car-news/fut...bustion-engine
The engine fires using both compression (like diesels) and spark plug (like petrol mills), not sure just how they managed that.
I wonder just what fuel air mixture and compression ratio adjustment they worked out to manage this and not have the engine catch fire.
What do we have here, an engine that behaves like a diesel if you fill diesel and like a petrol if you fill petrol? One that runs on half petrol half diesel?
hserus is offline   (7) Thanks Reply With Quote
Old 10th August 2017, 08:20   #2
CrAzY dRiVeR's Avatar
Thanked: 19,917 Times
Default re: Mazda plans a new engine using both - compression & spark ignition
Quite interesting and thanks for sharing.
From what I understand, it's a petrol engine that runs with very high compression ratios as seen in diesel engines. Usually, petrol engines run much lower compression ratios, or need high octane fuel when the compression ratios are increased (But still way short of the diesels) for more performance.
Without the high octane fuel, the fuel will just pre-ignite before reaching the compression stroke and that is bad for the engine.
Now Mazda claims to have developed a system which can monitor and fire the spark plugs and create a pre-ignition (which is now a part of the cycle rather than unintended) before it ignites under the full compression. Benefits include high torque and efficiency typical of high compression diesel engines, but with cleaner petrol emissions.
Sounds complex when it comes to fueling requirements and longevity of the things. My biggest doubt is how they have overcome pre-ignition and made it desirable, so to speak. Hope Mazda cracks it right.
CrAzY dRiVeR is offline   (5) Thanks Reply With Quote
Old 10th August 2017, 08:52   #3
Sankar's Avatar
Thanked: 4,656 Times
Mazda is on a high with their Skyactiv Petrol and Skyactiv Diesels. They are thinking outside the box and have tumbled the box upside down so that their Diesels run lower compression and Petrols run higher compression But Skyactiv Diesels have/had a problem of engine oil dilution with Diesel and the oil level in the sump rising. Their solution was to change the dipstick Anyway hope the engines are reliable.
Sankar is offline   (1) Thanks Reply With Quote
Old 10th August 2017, 09:04   #4
reignofchaos's Avatar
Thanked: 1,303 Times
This tech is very similar to what Merc and Ferrari (probably renault? not sure!) are using in F1 - Homogenous Charge Compression Ignition. A pure HCCI engine does not require spark plugs. However the ones being developed right now are still hybrids that use spark plugs. HCCI is used for cruising at low speeds while it shifts to spark plugs when under load such as when accelerating or running at high speeds.
However here they are more optimized for longevity and efficiency than outright power (though both power and efficiency are in a sense interrelated).
The primary advantage over conventional GDI engines is that the fuel burns better and with efficiencies approaching 55% in the ideal case - very similar to the efficiency of a diesel engine.
Many companies are looking at this tech for its potential benefits - VW, GM, Hyundai and now Mazda as it offers better combustion of the fuel with far less NOx emissions. The latter is essential to reach emission targets imposed by governments around the world.
Just like we saw a large scale shift from EFI naturally aspirated engines to GDI turbos in the automotive world in the last few years, the next shift would be to HCCI. Unlike downsizing though, this might offer real benefits.
reignofchaos is offline   (6) Thanks Reply With Quote
Old 10th August 2017, 19:54   #5
Thanked: 2,407 Times
Default Re: Mazda plans a new engine using both - compression & spark ignition
First the Miller cycle, and now HCCI (when others seem to have given up on it).
Working with the Wankel must have really built character at Mazda.
Sutripta
Sutripta is offline   (3) Thanks Reply With Quote
Old 12th August 2017, 11:17   #6
Thanked: 843 Times
Thanks for the update, hserus - the dividing lines between compression ignition / spark ignition is getting increasingly blurred! For one, the compression ratios are getting inverted and so are the performance characteristics - with diesels going up to 5200 rpm (http://www.mazda.com/en/innovation/t...iv/skyactiv-d/), with the gasoline engines giving comparative torque/power outputs & calorific inefficiencies, while their diesel counterparts are claiming particulate emissions comparable to their gasoline stablemates!
The best of all possible worlds indeed. For diesel addicts like me, it is music to the ears that significant engine weight reductions are in the pipeline, due to the lighter scantlings all round, including smaller crank pin/main bearing sizes - the domino effect from that reduced comp. ratio, resulting in reduced stress thresholds!
Well, alright, so there are a few hiccups too - cold start niggles and warm-up misfiring being the ones highlighted in the media releases - but where's the harm in keeping fingers crossed & hoping for the best! In this Utopian world, one can just hope that M&M and TM-JLR try to catch up as best they can!
shashanka is offline   Reply With Quote
Old 12th August 2017, 11:32   #7
sgiitk's Avatar
Thanked: 3,884 Times
I still miss the Wankels. Pollution and fuel consumption killed these ultra compact and smooth mills.
sgiitk is offline   (1) Thanks Reply With Quote
Old 8th September 2017, 09:18   #8
hserus's Avatar
Lovely article - from a Jalopnik journalist who is a trained automotive engineer - on his trip to the Mazda plant and a preview of the Skyactiv+ engine.
http://jalopnik.com/mazda-s-holy-gra...opnik_facebook
hserus is offline   Reply With Quote
Old 10th September 2017, 08:24   #9
sumeethaldankar's Avatar
Thanked: 1,161 Times
Default Re: Mazda to Scrap Rotary Engines
Mazda has developed a new gas engine that's far more efficient than existing motors.
The Skyactiv-X engine uses compression rather than spark to ignite the fuel-air mixture.
It can be used quickly and easily in existing Mazda vehicle designs without adding costs.
https://www.yahoo.com/finance/news/w...183036367.html
Mazda has come with a new type of engine which works on compression similar to Diesel engines to improve their fuel efficiency and meet emission regulations. Looks like this might turn out to be a electric car fighter if it manages to get more FE from regular gas engines.
sumeethaldankar is offline   (3) Thanks Reply With Quote
Old 11th September 2017, 11:01   #10
navin's Avatar
Thanked: 4,286 Times
Here is a video on HCCI engines and Mazda's twist on it.
In effect there will be a spark plug but it wont be used except when required (too cold/hot).
The same presenter also explains why rotary engines are not as efficient as we thought they are
navin is offline   (2) Thanks Reply With Quote
Old 11th September 2017, 11:34   #11
extreme_torque's Avatar
Thanked: 1,489 Times
I think this one deserves an altogether new thread because this is a problem that none of the big car makers including the Germans could figure out. I have huge respect for Mazda for their combination of performance, reliability, quality and price. Here is a car maker which punches far above its weight when it comes to engineering stuff.
Last edited by Aditya : 21st October 2017 at 09:16. Reason: Deleting video from quote
extreme_torque is offline   (2) Thanks Reply With Quote
Old 25th September 2017, 05:12   #12
Thanked: 843 Times
+1 I'd just add another virtue to the list - tenacity & perseverance. When the rest of the competition had given up on the Wankel rotary, Mazda persevered & came up with some notable cars & came furthest in sorting out the gas sealing problems. One could also add their relatively recent success in the GDI application.
Old 20th October 2017, 09:21   #13
im_srini's Avatar
Thanked: 399 Times
Thumbs up Re: Mazda to Scrap Rotary Engines
Originally Posted by reignofchaos View Post
This tech is very similar to what Merc and Ferrari ( probably Renault ? not sure ! ) are using in F1 - Homogenous Charge Compression Ignition.
Cool video about F1 plugs
Who would've thought they moved the pre-combustion chamber into the spark-plug !
More likely the last gasp of the Otto 4-stroke gasoline engine, the takeover of the electrics is inevitable...
True, the RX-7 & RX-8 still command high prices in the used-car market, but they do come with huge caveats about their thirst for fuel & major reliability issues.
That said, in my book it's their 4-rotor LMP 787s from the early 90's that're really spectacular, even more than their Wankel engined street cars.
On a side note, Suzuki, yes, very same maker of cars for "unsavvy people (Video: Fake service done on my Baleno RS by Mandovi Motors!)" made a Wankel-engined bike way back in the early 70's !
im_srini is offline   (2) Thanks Reply With Quote
Old 24th October 2017, 05:42   #14
Thanked: 843 Times
Originally Posted by im_srini View Post
On a side note, Suzuki, yes, very same maker of cars.... made a Wankel-engined bike way back in the early 70's !
One more feather in the cap for the Maruti owners club!
Old 29th October 2017, 17:23   #15
Thanked: 44 Times
Default Mazda's 'Holy Grail' Skyactiv-X Engine.
As the majority of the automotive industry continues working toward an electrified future, Mazda appears to be making a bold attempt to save the internal combustion engine.
Mazda unveiled an innovative breakthrough dubbed the Skyactiv-X engine that the automaker claims to have the performance of a traditional gasoline engine as well as the torque and fuel-efficiency of a diesel-powered option. Mazda describes it as “the world’s first commercial gasoline engine to use compression ignition.”
Mazda’s new Skyactiv-X engine runs on gasoline yet functions like a diesel engine by using a technology the automaker calls Spark-Controlled Compression Ignition (SCCI). Essentially, the engine uses compression ignition to burn its fuel, while still relying on a spark plug to initiate this combustion. The engine promises up to 30-percent more torque and a 20-percent improvement in fuel economy, figures that can definitely be appreciated in an industry continuing to be influenced by growing fuel emission regulations.
Source: NY Daily News
Sparky is offline   (2) Thanks Reply With Quote
Ignition, Spark plugs and Plug Wires - Questions? S@~+#0$# Technical Stuff 8 10th December 2017 14:45
Nissan's new gamechanger: VC-T engine with 'variable compression ratios' RavenAvi The International Automotive Scene 17 30th September 2016 11:24
Anybody Using aftermarket ignition coil & plug wires? finetuning Modifications & Accessories 0 27th March 2006 22:41
MSD Spark Plug Wires & Ignition coil Kaizer Sozay Modifications & Accessories 11 16th December 2005 09:12
Heard of duel spark ignition? Shan2nu Technical Stuff 1 15th July 2004 16:25
