Old 23rd April 2010, 13:14   #31
Thanked: 34 Times
Unhappy Fiat Palio temperature issues
Hello guys.
I have bought a 2002 Fiat palio 1.2 ELX in January2010.
Kochi Regn. Which i feel is a good buy considering it has an endorsed LPG kit and scratch free.
I am actually impressed with the car. The interiors are of excellent quality and The steering is divine. Overall driving experience is like a big luxury sedan. compared to our old esteem and even my cousins Swift DDis
But one day my brother (A spirited driver and car fanatic who extracts every bit of performance from the car) was taking my mom to a function in the car and he noticed the A/c is no longer cooling the car. then he noticed the temp gauge was pointing straight up! way beyond the highest marking. He stopped immediately and waited for the hood to cool down enough for him to pen the hood (it was steaming hot) and found the cooling fan was not working. He then waited some more until engine was cool and then limped to a nearby garage, turning off the engine whenever the temp reached 80%(This is the redline according to Palio manual).
The garage guy peeked under the car saw that the fan wire was cut. He reattached it with tape and the fan started working again. He was reluctant to work on a palio and said take it to RF motors (the fiat authorised service center in kochi ) to do a proper job of putting in new wires and the works. he did not even take money!!
On the way back my brother noticed that the engine temp was fluctuating every which way. from 40% mark to 80% Mark.
Soon he noticed a patern to the madness and discovered that when the engine is idle, the temp is shooting up and comes down when it is revved.
So basically if you drive one gear lower and revv at redlights, the temp gauge remains around the 50% mark.
He took it to RF motors the next day and they asked him to leave it with them. He was pretty mad at how they treated him as they were not ready even to listen to the symptoms. just said 'Overheating? we will take care of it sir. dont worry' after three follow up calls that day they examined the car and diagonosed failed head gasket but would not tell how they came to that conclusion. My bro asked this because he had already checked and found no oil film in coolant(water) or no air bubbles if radiator was kept open while engine running, though water is flowing out of the reservoir, even some steam after some time in idling condition.
He took the car back as the price quoted was 6000 and he was not sure about the diagnosis. They did not even hook it up with the ECU scanner.
A local mechanic, who used to take care of our esteem earlier wanted a shot at it but returned it after a day saying he could not find the reason. But he strongly said 'be doubly sure before replacing the head gasket' as he too suspects it is not the problem.
We have been using the car for a month now in that condition, careful to rev in time to keep the temp gauge around the 50% area. The car runs fine otherwise, breathes fire even! pun intended
Now the fan is running at high speeds almost all the time and if i leave the ignition on, it runs forver after the engine is switched off. I am scared it might burn out from over work and want my palio back in pristine shape. (Cos all my family has fallen i love with the car, dad the drivability, bro the attention to detail and handling, me with the quality of parts and solid feel and handling, and mom with the plush ride quality and wonderful A/c)
Has any one else experienced these problems?
Is there a good mechanic in kochi who does good work on palio?
Is it really the head gasket? or something else?
If nothing else is possible , i might just give iit to RF anyway and let them have thieir way. cos i dont want to keep on using it this way.
Will be glad if my fellow BHPians could help.
Btw the car is used very sparingly, when me or my brother is at home (We both work in other cities) hardly 50km a week and especilayy because of the heating problem we are avoiding using the car as much as possiible.
Joe
Joe-Ker is online now   Reply With Quote
Old 23rd April 2010, 13:28   #32
JVH
JVH's Avatar
Thanked: 148 Times
You may want to look at the fan motor. Very often this is the culprit. My fan motor had conked off and this was the experience I had to go through
http://www.team-bhp.com/forum/long-t...78000-kms.html
JVH is offline   Reply With Quote
Old 23rd April 2010, 14:04   #33
Thanked: 34 Times
Thanks JVH.I am reading your thread now, right form the beginning.(The story as far as i read is very similar to mine)
I will get the motor checked, It can be checked using the ECU scanner right?
Can somebody tell me the nornal operating temperature of a palio 1.2.
Now i am beginnning to wonder, is it over heating at all? my cars temp once its warmed up rarely goes below the 50% mark.
Old 23rd April 2010, 14:50   #34
sandeepmohan's Avatar
Thanked: 1,898 Times
The Fiat Palio has a very advanced cooling system for the engine. I don't know in what way but I like the accuracy of the whole system. I will agree that it can be scary at most times.
A colleague owns the 1.6 variant and the car behaves the same way as posted in the original thread. It is not over heating at all but does give you something to worry about once the temperature crosses the 60% mark.
The behavior is different for the car running with Air Conditioner and when the Air Conditioning is switched off. The radiator and AC Evaporator cooling fan is common (Some cars have independent fans) so when the Air Conditioning is not running the Thermostat delays the Fan Cut In but this is not a defect. However you must pay attention for the Fan cutting in cause if its not then there is a problem and you will end up with steamy situation.
With the Air Conditioning running and lets say you are cruising on the free way the temperature should not cross even 30%. Yupp. The engine stay very cool on the highway.
The temperature should not cross over 50% mark even in the city cycle with the Air Conditioning running.
Its a mixed bag if you don't have the Air Conditioning working. If there is enough air flow into the engine the temperature stays at some point in the safe range, 50% and below. If poor air flow, stop & go conditions you will easily end up with the needle at a dangerous 80% but the engine won't over heat. This happens due to a very delayed cooling fan start up. Need not necessarily be a sensor failure. The system is just designed in this manner. However make sure the cooling system is intact. There should be no leaks, coolant system liquids should be not be low & make sure the fan works.
A few other cars that suffer from a delayed cooling system Fan Start Up are Fiat Palios, Fiat Petra, Fiat Siena, Ford Ikon & Opel Corsa. These are the one's I know very well and have had experience.
sandeepmohan is offline   Reply With Quote
Old 23rd April 2010, 14:58   #35
Thanked: 18 Times
Joe,
I guess in your case, it must be only two possible things if you can hear the FAN working properly once it reaches the temperature.
1. Thermostat may not be working properly. Need to clean/replace thermostat valve
2. A gone Engine Head gasket. this can set you back by 3-4K. Show it to a good mechanic asap to avoid any further damage to engine.
ravikn is offline   Reply With Quote
Old 23rd April 2010, 14:59   #36
drifter's Avatar
Firstly I'd check all the relays for the cooling fans, that is after the wiring has been sorted. After that I'd check if the thermostat is in proper working order. Also since you said it has the LPG kit, I would check that. If it isn't tuned properly, it can lead to overheating. Also have the radiator serviced. The temperature on my car remains between 1/4 and lower than half even in traffic with the aircon.
Drifter
drifter is online now   Reply With Quote
Old 24th April 2010, 02:41   #37
Thanked: 34 Times
Thanks for the replies guys.
So the head gasket failure that RF motors guys said may be true.
I am facing this issue in both petrol and LPG, so i guess its got nothing to do with the kit.
I may go to kochi next weekend, so i will get them to check the thermostat too.
And RF motors guys quoted 6000 for the head gasket replacement. Is it reasonable?, i have heard that we need to change the head bolts too as they can be torqued only once. is that right?
Old 26th April 2010, 12:24   #38
Thanked: 18 Times
Joe-Ker,
I think if they would be replacing the bolts also, then it might be close to 6K since the head gasket kit price would be around 3.5K-4.0K for the complete set depending on the one being used on your engine.
Old 1st May 2010, 14:39   #39
i had the same problem, but the cause for this problem was obstuction in the coolant pipe, which was rectified immediately. Thanks to Adi on Concorde BBII Unit, Bangalore.
sans_80 is offline   Reply With Quote
Old 18th August 2011, 22:21   #40
vipul_singh's Avatar
Thanked: 256 Times
Default Re: Palio 1.6 Sport Temperature doubt
Here is an update (with reference to post #23)
I got the coolant thermostat changed. Earlier, the coolant temperature with the A/C on or when cruising in cold temperature was 2 mm above the 'C' mark. With the new thermostat, the temp with A/C on is at about 5mm above 'C' mark. Looks like the old thermostat was letting water into the radiator too early.
I hope the heater's performance in peak winter improves considerably
vipul_singh is offline   (1) Thanks Reply With Quote
Palio 1.6 GTX v/s Palio 1.6 Sport - Visible Differences moralfibre The Indian Car Scene 140 21st May 2014 17:21
Palio 1.6 Stile cooling system doubt vidushak Technical Stuff 9 25th July 2008 11:01
palio 1.6gtx doubt pawan Technical Stuff 36 7th May 2007 03:55
help me decide-palio sport or adventure sport 1.6 for city driving premchetan Hatchbacks 46 9th February 2007 17:44
