| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | The temperature gauge of my Palio 1.6 reaches the halfway mark in city driving. The optimum running temperature for the engine is around 98 degree C. While on a recent trip to Alibaug we stopped for lunch after driving for about 100kms continuously and the AC blowing at full blast. The needle pointed about 1mm above the half way mark on the gauge when we stopped. After about 45 mins of break I turned on the ignition switch and was shocked to see the needle going up to 80% of the gauge. After turning the engine ON, it settled to 50%. Am I having a problem with the cooling system OR the gauge is faulty? I have confirmed that the radiator fan is operating at both speeds and also remains ON for 1 min after the engine is shutdown as usual. The engine bay shows no signs of overheating or leakage. There is no smoke seen anywhere and there is no flaw in the performance of the engine whatsoever. The AC operates efficiently and cools the cabin without any issues. Can Palio 1.6 users tell me the exact position of the needle on the gauge when their engines come upto the optimum operating temperature please? What should I be looking for? Please help. Edit: My previous cars always showed the needle at 1/4th mark at optimum temp. this is my first car to point the needle halfway.
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) Last edited by moralfibre : 25th November 2006 at 09:03. |
| | #2 (permalink) |
| BHPian Join Date: Oct 2004 Location: Hyderabad
| There may be a problem with the sensor. I'd say the optimum operating temperature while the car is in motion is at about 1/4 of the range. Slightly higher temperatures in stop/start traffic. Stopping the car and switching off the engine after having driven for some distance (say over 15km) sometimes pushes the needle up to 1/2 but never beyond in my experience. I'd suggest you get it looked at. |
| | #3 (permalink) |
| Senior - BHPian | for the palio 1.6 the optimum range is 1)with AC on it never goes above the 40% mark while standstill in traffic and is at 25% when driving. 2)with AC off and standing still in traffic the temp goes upto 55% then the fan speed 2 kicks in and lowers the temp to about 35%.while driving it is between 30-40%. the palios cooling system is very dynamic in functioning and changes the fan behaviour acc to outside temp,ac operation and speed of driving,but it never ever goes above 60% in any circumstance. according to me your fan speed relay has packed up,i suspect your fan speed 2 does not come in at 55%.if it does then your sensor may be damaged.
__________________ No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz Last edited by merve_extreme : 25th November 2006 at 10:20. |
| | #4 (permalink) | ||
| Senior - BHPian | Quote:
Thanks Airfoil and Merve!
__________________ "As long as there are short, balding, middle-aged men, there will always be a market for the Porsche 911." - A BMW Owner. :) | ||
| | #5 (permalink) |
| Newbie Join Date: Mar 2005 Location: Hyderabad
| Hi, I have exactly similar problem with GTX. But i noticed that Sometimes the fan doesnt start off after it crossed the 50% mark. And when you start the car yes it goes up to 80%, so as per below comments i think i have a problem here. Well let me get this checked in my next service. bulleteer |
| | #6 (permalink) | |
| | #7 (permalink) |
| BHPian | I dont think it is a problem. It happens in my car too. Normal running its about the half mark. with AC, it is less than half mark. But when you stop after a long run, it rises a bit because the water pump stops with the engine and the fan keeps running for a few seconds. This effectively brings down the temp of the coolant but the engine block with its latent heat continues to heat the coolant which is now not moving like it was before. So the coolant starts heating up further and gradually takes place vacated by the cool coolant due to the fan. Next time you switch on the key (not start the engine you will see a high reading. However what looked unusual to me is after 45 mins it should be cool. say 5 - 10 mins my theory hold good.
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! |
| | #8 (permalink) |
| Senior - BHPian | Next time I turn the key to ignition without cranking the engine, the temperature needle goes up to 80% BUT, the needle settles down to 50% immediately after I crank the engine.
| | #10 (permalink) |
| Senior - BHPian | as soon as u crank the engine the fan will start,does it,if so then everything is ok.actually if the engine is too hot sometimes the fan starts even if the engine is not cranked but the ignition key is moved to on position.
__________________ No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz |
| | #11 (permalink) | |
| BHPian | Quote:
The point is the coolant pump is coupled to the engine which start circulating the coolant when you crank it. Other wise it becomes stagnant and rises its temp to high. Cooling happens only through cconvection f the coolant. Hence the higher temp.
__________________ _____________________ Stand on your head, upside down.. The world does not look any different, but you sure will look different! | |
| | #12 (permalink) | ||
| Senior - BHPian | Yes it does. Quote:
| | #13 (permalink) |
| Senior - BHPian | I assume you checked to see whether there is enough coolant, right? This happened to me (Palio 1.2) a while back. The tem went up to 80% while driving and the A/C shut off by itself. When I checked, I found that the coolant level was real low. I topped it up, and the temp went back to normal, and the A/C went back to normal.
__________________ Coming soon: Balls of STEEL! Last edited by hydrashok : 28th November 2006 at 07:27. |
| | #15 (permalink) | |
but say you switch off the car and the fan keeps running for 1min and then stops,if after sometime say 5-10 mins you move the key to on position again and the engine is still very hot,the fan will start again without cranking the engine.
__________________ No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz Last edited by merve_extreme : 28th November 2006 at 19:59. | |
| Thread Tools | |
Similar Threads | ||||
| Palio 1.6 Stile cooling system doubt | vidushak | Technical Stuff | 9 | 25th July 2008 11:01 |
| Palio 1.6 Sport Vs Palio MJD- pure economics | zaks | The Indian Car Scene!! | 11 | 17th March 2008 14:22 |
| Palio 1.6 GTX v/s Palio 1.6 Sport - Visible Differences | moralfibre | The Indian Car Scene!! | 103 | 19th February 2008 10:26 |
| palio 1.6gtx doubt | pawan | Technical Stuff | 36 | 7th May 2007 03:55 |
| help me decide-palio sport or adventure sport 1.6 for city driving | premchetan | Hatchbacks | 46 | 9th February 2007 16:44 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
