Old 30th November 2006, 20:17   #16
kailashnj's Avatar
Thanked: 275 Times
Originally Posted by Kaizer Sozay View Post
Thanks it was sure nice to meet aTeam -bhpian in nagpur....
Not a great city for car fans but it has great road.
Grooves are the way to go.
Just started adding a new concotion of Acetone + xylene+ 2t into petrol
Will post the results soon
Kaizer I am lost at the new concotion that you are using. I have started using the Acetone + 2t and it does make feel a difference as per your advice. But I would certainly need to know what is the above combination that you have suggested.
kailashnj is offline   Reply With Quote
Old 30th November 2006, 22:40   #17
Thanked: 9 Times
I forgot to mention about my engine temparature......this time when I got FE of 17 my engine temp was still 5% less.............after grooving it was already showing 10 to 15 less compared to my earlier setting....but to my surprise it shows still 5% less even after consistant an hour of driving.........so I think engine is running very smooth & not heating up much which translates into greater FE....now if boric acid trated lubricant gives such benefit and also if my engine...gear box....wheels are having very less friction then really I m getting benefited.......this can be easily felt as after certain acceleration car just moves on without touching the pedal very smoothly......also noted that there is no need to press hard as car is moving so effortlessly.....
I never imagined that such experiment will pass on such wonderful result without affecting my pocket.....
Now how to measure friction in car engine & gear box?......how to measure friction in tyres?....
finetuning is offline   Reply With Quote
Old 1st December 2006, 12:03   #18
Kaizer Sozay's Avatar
Again thanks to finetuining,
I used to add 2 ml acetone & 0.8 ml 2t oil. Now i have added 2ml acetone + 2 ml 2t + 2ml xylene so its a total of 6ml per litre of petrol.
Xylene add a lot of pep into the drive.
call me if you need anything more
Kaizer Sozay is offline   Reply With Quote
The latest fashion from Nokia - new Nokia 8800 khanak Gadgets, Computers & Software 29 26th March 2008 00:56
Drool on the latest and greatest Petra manishk13 The Indian Car Scene 170 9th April 2007 16:21
Mercedes Benz SLR - Jay Lenos latest acquisition GTO The International Automotive Scene 10 28th October 2005 01:57
The latest mods on your Ride Team Fiat Modifications & Accessories 39 5th June 2004 17:38
