Old 13th September 2007, 13:15   #31
kuttapan's Avatar
Thanked: 12 Times
Originally Posted by akash_m View Post
  1. Are all buses and trucks (especially Indian) fitted with power steering? I mean the driver would otherwise have tough time manuvering these vehicles!
Yes, the current AL and Tata buses/trucks come with power steering. From the mid-90's I guess. Hydraulic only, no EPS for them. But enough for the maniacs to do ballet dances on road.
Just as the hydraulic power sterring would effect the F.E marginally, does the E.P.S put extra load on the car battery? I mean is the battery life shortened...thanx
Actually battery life is better if there is charge/disharge, battery anyway deteriorates if not used at all.
kuttapan is offline   Reply With Quote
Old 13th September 2007, 13:23   #32
Thanked: 252 Times
Originally Posted by vnabhi View Post
Theoretically, this is correct. I have a WagonR lxi for the past 6 years. But when I drove a WagonR without power steering (LX model), I found it had a fantastic pick-up compared to mine. If EPS is not the culprit, then what is to blame?
EPS is DEFINITELY not the culprit for this. Some other factors are responsible. Please have your car checked out at an ASC.
Old 27th September 2007, 23:51   #33
nura's Avatar
What are the symptoms a failing power-steering pump would produce in a Santro?
What tests could be done to confirm that the pump was faulty?
nura is offline   Reply With Quote
Old 29th September 2007, 17:32   #34
nura's Avatar
Bump?
(20 characters)
Old 1st October 2007, 17:27   #35
vnabhi's Avatar
Thanked: 1,240 Times
It has been checked and found to be ok. Even other lxi's have the same pickup as mine. But I cannot forget the monstrous pickup the WagonR without EPS had.
Old 1st October 2007, 20:50   #36
Thanked: 252 Times
Perhaps you need to repeat that test to confirm your earlier experience.
And do confirm that that Wagon was not modded.
Old 29th December 2007, 21:30   #37
I own a WagonR Vxi. It has EPS. I used to find it hard (especially at lower speeds when it is supposed to help) and kept complaining to the service provider. I was told that there is no serviceable setting in the power steering. But, the rack and pinion can be tightened and loosened to give easy or tough steering.
girisanthan is offline   Reply With Quote
Old 30th December 2007, 15:11   #38
yasw_anth's Avatar
what kinda power steering in zen2003 ??
yasw_anth is offline   Reply With Quote
Old 30th December 2007, 17:40   #39
vigsom's Avatar
Thanked: 582 Times
If it is a Lx1 or Vxi,this car has an Electronic Power steering
Old 30th December 2007, 18:12   #40
vintagepoint5's Avatar
Thanked: 40 Times
Contratulations to all the contributors
My experience for last 20 yrs with Japanese & American cars,
the EPS electronic power steering is best and reliable, I owned & used
Honda, Mazda 929, Chevrolet Caprice and Ford Grand Marquis latest.
Problems with Automatic transmission car I faced rarely when the engine
is off it is difficult to move the car to side of the road and steering become very hard. But this problem is due to the engine or battery, EPS
is in American cars is extremely reliable even in high speeds.
But I don't know in India what type of EPS system is fitted in the cars
available in Indian market. I have been in KSA for last 20 yrs, used to
to check Steering Oil once in 2-3 weeks, only if oil leeks steering
will be hard, otherwise it is very good. In the latest cars most of the
functions were controlled by computerized console in the car like in my Ford Mercury Grand Marquis. I think EPS is also controlled by speed
of the car.
I drove my Chevrolet Caprice without difficulty even I have injury to
my left hand few years back.
Ford Mercury Grand Marquis is also one of best luxury car, most of functions were powered, for example even the foot pedal were power adjusted, 8-way seat position power adjusted etc. Power steering in the car makes very confortable driving experience, whether you drive in City or highways.
vintagepoint5 is offline   Reply With Quote
Old 30th December 2007, 19:20   #41
Radnam's Avatar
My Palio GTX has a HPS and the feel is very confident on high speeds as well. I have driven Maruti Esteem and Zen with an EPS but didnt get the "FEEL".
BTW does Palio GTX has a speed sensitive HPS?
Radnam is offline   Reply With Quote
Old 30th December 2007, 23:02   #42
In my Indica even after balancing and aligning the pulling problem has maintained it status quo. The tata motors dealer says tyre tread wear is the cause, is it so?
fiat-jsp is offline   Reply With Quote
Old 25th January 2008, 22:28   #43
avimal's Avatar
Thanked: 45 Times
So if in all matter EPS is better than HPS, then why do we have EHPS in 4WD honda CRV but EPS in 2WD honda crv. Accord/Cedia have EHPS.
EHPS - (electro/power assisted HPS) removes the problem of FE from HPS so how does EHPS compare with EPS?
avimal
avimal is offline   Reply With Quote
Old 26th January 2008, 07:26   #44
mithun's Avatar
Thanked: 49 Times
avimal
Good question !
Tech gurus please reply.
Old 26th January 2008, 11:48   #45
snaronikar's Avatar
Thanked: 23 Times
My Ford ikon has the power steering. It only works when we start the car. This is not the case in my previous vehicle (Wagon R Lxi). The PS used to work even when the engine is switched off. Any particular reasons?
Also, my ford ikon feels a lot sturdy when driving on a highway than the Wagon R when I will be doing 100+ kmph while driving WagonR if a slight turn of steering wheel, the vehicle used to drift sideways.
snaronikar is offline   Reply With Quote
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
Caught off guard!! Know someone well, but don't know the name ? supremeBaleno Street Experiences 25 2nd January 2008 22:06
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
Please suggest - power windows, power steering from one Esteem to another pramodkumar Technical Stuff 4 1st September 2006 09:19
