Old 6th December 2006, 19:09   #1
Default External Noise comming inside the passenger cabin
Hi Friends,
I have been using Baleno for the last 1+ years. Recently one mad guy in bike hit the bumber and I had to do fix the bumper with a local tinker.
Now I realised that the external noise started comming inside the passenger cabin especialy from behind . I took the car to Bimal Auto the mechanic checked the door beeding and told me everything is fine. But this problem is irritating me.
Any thoughts on this ??
Sachin
Sachin is offline   Reply With Quote
Old 7th December 2006, 12:09   #2
esteem_lover's Avatar
Thanked: 451 Times
Bumpers are tricky to fix by the local tinker. he might have left some loose ends. check the beading in the boot also. Are you getting the traffic noise outside or is it a rattling sound from outside ?
Old 7th December 2006, 14:20   #3
rjstyles69's Avatar
Thanked: 795 Times
Hey Sachin, Bimal really s***k's with service. My colleague also had a pretty bad experience. If you havent been able to get that sorted out through your dealer let me know. I would suggest you try RNS Yeshwanthpur, PM me and I can put you through to the right person there.
Old 26th December 2006, 14:50   #4
Thanks everybody. The noise is comming from outside.
regards
Sachin
Tyre Noise inside the cabin - Can we minimize it? akshay4587 Tyre & Alloy wheel Section 76 3rd August 2017 11:11
Noise of gushing fluid inside the car cabin ff1609 Technical Stuff 24 2nd January 2012 14:08
Heat from the Engine compartment reaching the Passenger cabin !! Need Help xenxer Technical Stuff 13 10th February 2010 15:08
