Old 9th December 2006, 10:08   #1
tsk1979's Avatar
Thanked: 16,420 Times
Default Tata Indica alternator voltage query
I have observed a peculiar thing.
Just after starting the engine when I put a voltmeter to the battery terminals, I get around 12.5V at idle.
If I immediately switch on the headlights too, it drops to around 11.8 volts for some time. After around 30 seconds or so i hear a distinctive "click" and the voltage jumps to 12.5V with headlights on and 13.2-13.5 V with headlights off.
So my observation is that after 30 seconds or so of idling, there is a click which leads to a boost in alternator voltage.
What is this click? There is a very very slight change in engine note too after the click.
Old 9th December 2006, 10:26   #2
nitrous's Avatar
Thanked: 285 Times
IF ur alternator voltage is over 12.8-12.9 at any point of time, the regulator needs replacement.
Old 9th December 2006, 10:40   #3
theMAG's Avatar
Thanked: 1,572 Times
We've heard this sound particularly when the AC is on. The sound is always accompanied by a dip in engine performance. And the engine note changes too.
Apparently Prerana Motors have told my colleagues (the diesel Indica owners) that its something to do with the compressor regulation and is a common trait to all diesel Indicas.
Old 9th December 2006, 10:55   #4
Ram
Ram's Avatar
Thanked: 149 Times
The engine's idling rpm is usually adjusted to be as low as possible, but above the stalling threshold.
When you load the engine, as in shifting into gear and pulling away, you take care to keep the rpm up by pressing the accelerator,
However when the air-conditioning compressor (or in this case the alternator) loads an idling engine, an automatic feedback control mechanism needs to open the throttle to prevent the engine from dropping the rpm below the stall threshold.
That system kicking-in would account for the rise in engine note. Additionally when the battery voltage has dropped below a threshold, the replenishing circuits must hook-up the alternator output (in the old days this was a DC generator aka dynamo) to the battery. A heavy relay (colloquially called the "cut out" in the dynamo days) will snap on, and this is the click that you hear.
Ram
Ram is offline   Reply With Quote
Old 9th December 2006, 12:15   #5
tsk1979's Avatar
For the indica in case of new alternators also I have seen that the voltage is around 12.8V at idle amd 13.5-14V with revving hard.
As for this click, the AC was not turned on. It was just the headlights.
Old 9th December 2006, 12:45   #6
nitrous's Avatar
Thanked: 285 Times
A month back, the indigo(non-intercooled) in which i was driving to bangalore blew its headlights.I knew it was the regulator.
I went to this Tata authorised service centre and they checked its voltage.It was hovering around 12.3 and hard revving sent it to 12.6-12.7. Once,it crossed 12.8 and the mech said it was the regulator which costs 950 bucks.
So, i was assuming ur Indica works the same way.
Battery / Alternator / Voltage Regulator problem? babe_on_wheels Technical Stuff 109 10th June 2018 21:36
Car Battery / Alternator Capacity Query jinu_joseph Technical Stuff 41 29th January 2013 13:37
PS3 from US - do i need a voltage transformer?? jassi Gadgets, Computers & Software 85 15th January 2013 01:46
Tata Indica V2 DLS customized vs Tata Indica V2 DLX karikrishni Hatchbacks 20 12th November 2009 10:59
