Old 18th January 2007, 15:30   #16
bhavit46's Avatar
Originally Posted by himanshugoswami View Post
I have htis problem as well with my Palio 1.2 ELX.
Took it to Concorde and Manipal but htese guys could not figure out why there is a problem.
Now they have told me to get the ECU changed !!!!!
Hi! Himanshu. I don't think there is any need to change the ECU. I would recommend getting you car's injectors cleaned and use System-G (petrol additive) every time you tank up.
You will notice a considerable difference in two-three tank fulls.
I have done a lot of trials using System-G and and many other additives such as Stp, Sonax but i found System-G to be most cost effective as well as working well.
bhavit46 is offline   Reply With Quote
Old 18th January 2007, 16:17   #17
Try Resetting the ECU by disconnecting the battery for a Short duration.
arun_moorthy is offline   Reply With Quote
Old 18th January 2007, 16:38   #18
moralfibre's Avatar
Thanked: 6,144 Times
I knew this problem was there with the GTX and the S10 but never heard of this happening to the 1.2. They have fixed the problem in the new 1.6 Sports.
Dont fall for the ECU change. Its not an ECU problem!
Old 18th January 2007, 17:45   #19
himanshugoswami's Avatar
Thanked: 1,018 Times
I always use HP Power for my car- do I still need System G? I guess not.
Even I did not fall for that ECU crap. SO I am in observation mode as of now.
himanshugoswami is offline   Reply With Quote
Old 18th January 2007, 21:20   #20
bhavit46's Avatar
Yes you do. I have always used either BP speed or IOC premium or HP power, but still i have to use system-G to solve the problem. I would recommend you to try it out...even if you use high octane fuels.
Revving the engine.. How often do you do it araje Technical Stuff 53 19th March 2012 18:32
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
Over revving MPFI Zen Engine( revv limiter doesnt cut at 6000 rpm!!) speedsatya Technical Stuff 4 30th October 2010 15:21
Getz problem - Revving on its own ? Tarun Technical Stuff 24 14th April 2010 10:53
