Old 12th December 2006, 23:30   #1
ECM
ECM's Avatar
Default Spark Plugs in Baleno..
This thread I wanted to post yesterday and when today I was searching net just few minutes back saw a post from Samurai on this thread in google http://www.team-bhp.com/forum/techni...t-mileage.html (How does spark plug gap affect mileage?)
Well my Baleno is 2002 make and old timers know how much FE it gives me(I proved it to maruti people when they came to replace my Cam shaft sensor and that thread of mine is already exists in this very forum).Y'day I decided to change my spark plugs as I thought it is the time to change them though I had no probs what so ever in my car.I hence told my MUL Mass to provide me 4 nos.of original SGP Denso make plugs for replacement.While they were replacing them I was present and I saw that they were adjusting the gap in plug.Recommended gap is .7-.8 mm as per the service book given with the car(just open yours and check this) but before they plugin the plug into my car I asked them to give me my old plugs to see what gap they were having and to my very surprise I saw a narrow gap in all 4 plugs(old ones)and it was .4!!! I insist that I want the same gap in my all new plugs and not the one advised by MUL because I am getting super FE in my car.THey first told me sirji,use the gap advised by officials I told them no sirji I want .4 mm only.They agreed and put new plugs, I shall post results of this new change of plugs in next week as far as FE goes after having say 200-300 kms run with these new spark plugs with old gap.Right now car is running like before,no visible changes.Only one thing I did and that was I cleaned all cables connections- connecting to the caps and 2 boxes given above plugs as a routine.
Samurai I am repling to your post on 27th Dec.2005 here(check the link I posted above) I do feel that one should try this .4 mm gap and check the results for FE.btw my tyre pressure is ALWAYS 30psi recommened by MUL for my Baleno and I shift to 5th gear when my speedo shows 40-45 Kms/Hour.
Spark plug gap:-
The spark plug gap is set for various reasons. The larger the gap, the more time the spark spends in the combustion chamber and offers that much more time for the mixture to ignite. When the hi-tension voltage is low for some reason, then the temporary remedy is to reduce the gap so that the spark can jump the gap.
Last edited by ECM : 12th December 2006 at 23:33. Reason: Editing to throw some lights different gap in spark plugs
ECM is offline   Reply With Quote
Old 14th December 2006, 21:06   #2
Thanked: 9 Times
Dear ECM,
When I fitted my LPG gas kit my dealer too narrowed spark plug gap......he said by this it will improve Fe as well as performance in LPG........this they tested in hundreds of vehicles & found useful.......even when someone new who has not done retrofitting from his workshop comes with any problem.these people simply first used to check the plug gap.....
Also when I used ngk iridium plug with normal gap I didnt found much difference but then I made gap narrower & found good result......I also checked that with too much narrow gap firing is not good.....
Infact narrowing the plug gap is the one of the technique to improve FE.....
Check Point no. 4 ....http://www.lubedev.com/smartgas/ultra5.htm
Enjoy......
finetuning is offline   Reply With Quote
Old 15th December 2006, 11:14   #3
shuvc's Avatar
Thanked: 283 Times
Does this have any effect on throttle response and performance ?
Old 15th December 2006, 12:33   #4
ECM
ECM's Avatar
shuvc
Though you addressed this query to F.T but I feel no difference in my Baleno and get THE BEST FE(check my old msgs of how much I get )without ANY prob what so ever.Try this narrowing gap,disconnect battery for for 2-3 mins,have a run for say atleast 200 kms and then refill the tank because your ECM/ECU will set itself with new datas and on next refill count FE and see the difference.This you can do if you are not satisfied with FE you get.
Dear FT thanks onceagain for providing one more useful link from your library,have added it to my favs.
Note:-I never used LPG in any of my car till this date.
Old 18th June 2007, 02:42   #5
shuvc's Avatar
Thanked: 283 Times
Was leafing through the Baleno manual. These are the spark plug specs.
Champion - RC8YC, MICO - FR6DC4 - BSIII
Champion - RC8YC, NGK - BKR6E - BSII
Why mention BSII & BSIII separately ? What would be the difference between the MICO & the NGK ? Is this NGK platinum ?
I had a brief discussion with the service engineer. He said they normally use MICO / Champion - costs around Rs. 50-60 each. But they also have a NGK option for around Rs. 260 each.
Old 18th June 2007, 03:27   #6
.anshuman's Avatar
Thanked: 9,005 Times
@ECM exact opposite happened with me,my CNG installer reduced the gap on the the spark plugs in my car he said it is done on all CNG cars.
This time when i visited my mechanic(not CNG installer)i asked him to increase the gap to oem specs and the effect was visible on first drive now on the same tune the car runs better on CNG,the mileage on CNG and Petrol (it was a big issue after gap was reduced)is better.
The car now returns 10+kmpl in same conditions under which it returned 8.XXkmpl.
Are NGK spark plugs for Baleno not available in Bangalore? kaushik_s Technical Stuff 31 3rd July 2014 22:31
Pulstar plugs! Are the spark plugs obsolete? Is it a scam? Sankar Technical Stuff 8 4th October 2009 01:58
NGK Spark Plugs Tom Modifications & Accessories 7 23rd July 2009 17:11
Better spark plugs -- Worth it? v1p3r Technical Stuff 1 26th June 2005 14:59
Spark plugs for the Vtec ajmat Technical Stuff 5 22nd May 2004 08:01
