Old 15th December 2006, 17:34   #16
katalyst's Avatar
Thanks Guys
Looks like a visit to the friendly neighbourhood Lancer dealer is inevitable :|
katalyst is offline   Reply With Quote
Old 15th December 2006, 21:03   #17
gd1418's Avatar
Thanked: 656 Times
Default Cold start
I used to experience in my Amby of 1973 vintage and that too only in the cold climate of Delhi. I used to start it with the choke pulled on and without touvhing the accelarator it used to revv at high rpm. Then slowly after about a minute or so, I used to push the choke back and then slowly move forward after engaging the gear.
I do not know about the MPFi engines coz the last petrol car was a carb esteem of 1999 and it too used to require the choke assist in the winters. The diesels never posed this problem for me. Half self start the first thing in the morning and just vroom ahead..!!!
Old 18th December 2006, 11:08   #18
katalyst's Avatar
After a clean up of the fuel injectors - a 60 seconds warmup and the car is ready to move
whew!
Thanks guys...
Old 18th December 2006, 20:37   #19
Sivia's Avatar
Thanked: 23 Times
Originally Posted by katalyst View Post
Every morning when I start my Lancer (2000 Petrol GLXi), I have to wait for a good 4-5 minutes before the engine starts responding to the throttle. Is this normal?
If I do not wait, the car jerks like crazy and hardly moves. I have no experienced this with the Wagon R - which is ready to go almost immediatly.
I keep my lancer petrol (2000 SLXi) idle for 30 secs & Lancer diesel (2003 GLXd) for 10 mins every morning
Sivia is offline   Reply With Quote
Old 10th September 2008, 18:35   #20
sumeethaldankar's Avatar
Thanked: 1,153 Times
Default 800 idles at < 1000 rpm at start.
I have a 97 carb 800 ,contrary to what is mentioned here in some of the posts when i start it idles at < 1000 rpm and then after sometime
it idles at 1000 rpm.I have a autoguage tacho.Is this normal.
sumeethaldankar is online now   Reply With Quote
Old 10th September 2008, 20:58   #21
trrk's Avatar
Thanked: 13 Times
Hi sumeet,
What you saw reported were for cars with fuel injection. In a fuel injected system, the ECU runs the engine at a higher RPM when started and then it settles to the correct idling RPM.
In a carb engine, there is a manual choke for assisting cold starts. If you use the choke, the engine will start in a higher RPM.
But still, I feel your idling at 1000RPM is higher than needed. It should be closer to 800RPM. get it adjusted. It should improve your fuel efficiency.
trrk is offline   Reply With Quote
Low engine temperature - Engine isn't getting warm enough anish5225 Technical Stuff 38 9th November 2015 19:17
Knocking noise on a Mach 500 LB only in a warm engine Karlitoz Motorbikes 9 7th September 2011 01:24
A Warm Hello To All Of You hiphopdoc Introduce yourself 6 18th January 2007 17:39
My introduction and warm greetings Debasischatterj Introduce yourself 3 13th August 2006 17:57
a very warm hi to everyone anku Introduce yourself 15 22nd January 2006 05:53
