Old 14th December 2006, 17:54   #1
lancer_maniac's Avatar
Thanked: 15 Times
Default problem with my lancer
Just yesterday after a week when i started my lancer it showed a problem...ie when i press the clutch the rpm goes lower to zero and the engine stopes....also the oil indicator is glowing in start mode which i think is not right....plz tell me what to check as im not good in technical stuffs of the car.....hope its not a major prob(im able to drive the car with minimal use of clutch).....
lancer_maniac is offline   Reply With Quote
Old 14th December 2006, 18:52   #2
Sideways's Avatar
Thanked: 18 Times
I am ssuming you have this problem of the engine stalling when you are driving i.e. engine stalls when you depress the clutch to shift into the next gear ? Is this correct ? Or does this happen even when the car is stationary? Please clarify.
With regards to oil lamp - You mean the oil lamp glows even after engine has been started ? If thats the case, please avoid driving the car and get in touch with the nearest authorised service station.
Sideways is offline   Reply With Quote
Old 14th December 2006, 20:23   #3
theMAG's Avatar
Thanked: 1,574 Times
Suspect the freewheel disengaging when the clutch is pressed is stalling the car.
As far as the oil indicator goes, as Sideways said, if its ON after the engine starts, tow the car to the garage to have it checked - do not run/rev the engine. The last thing you need is your engine seizing up due to engine oil starvation.
Old 15th December 2006, 11:17   #4
vikram_d's Avatar
Thanked: 940 Times
Before towing your vehicle to workshop please open the bonnet remove the dip dtick and check the oil level. The light normally glows when the oil is less. Also the oil being less can be caused by a lot of other things like leakeage of oil. etc etc.
Old 15th December 2006, 11:28   #5
Vid6639's Avatar
Thanked: 21,085 Times
Also, not much sense in towing the car. get a small amount of oil from HM service. pour it in. drive till the service centre and get the engine oil flushed out and topped up.
I dont like towing the car as it does more damage.
Old 27th June 2007, 21:01   #6
Thanked: 15 Times
It was indeed the problem with engine oil
Old 27th June 2007, 21:36   #7
Sam Kapasi's Avatar
Thanked: 1,473 Times
Well then, tell us what the problem was! You started a thread, for others to share their experience with you. Now share your experience with us. Tell us what happened to the Lancer and how you fixed the oil problem.
These are the things that make a forum
Old 27th June 2007, 22:17   #8
esteem_lover's Avatar
Thanked: 451 Times
Good advice vikram. There is no need to tow the vehicle if the oil levels are ok & even if they are not, you can always top up & drive to the nearest service station.
Whenever there is a lancer in trouble, please dial 1800samkapasi. If that does not work out, please dial 100_samkapasi or kasapi. You are bound to be lucky the third time.
cheers
Old 27th June 2007, 23:28   #9
Sam Kapasi's Avatar
cheers
Me??? Are you crazy? I came to this thread to learn, not to teach, lol.
Lancer SLX 2002 Model Electrical Problem harikr Technical Stuff 30 29th November 2015 22:36
Lancer.ized got his Lancer.iCED Lancer.ized In-Car Entertainment 46 4th May 2009 12:14
lancer power steering & speedometer problem trashishh Technical Stuff 3 13th May 2008 19:19
Bonnet holder problem in Lancer rajivanoj Technical Stuff 10 8th April 2008 21:54
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 12:02
