Old 14th December 2006, 20:31   #1
Thanked: 127 Times
Default Swift : Cold Engine, with higher RPM
My new Swift, with ~300Kms on odometer, when start in the morning (cold engine) has idling RPM of 1500-1700RPM, however after driving for nearly 3-4 KMs, the idle RPM will be around 800. Is it normal and expected? During high RPM, the engine noise is clearly noticeable in the cabin, with all windows rolled up. Appreciate any info on this.
Also I am hearing rattling sound from front left and rear right doors, even on a decent roads. Any suggestion to fix this issue will be appreciated.
regards,
-manju
manjubp is offline   Reply With Quote
Old 14th December 2006, 23:47   #2
first of all congrats for your new car. the rpm range is kinda normal for your car. so enjoy. just talk to the maruti guys about the rattles in the 1st service nd they will fix it. they did the same for my baleno
chocoguy4u is offline   Reply With Quote
Old 15th December 2006, 00:23   #3
Ferrarimaniac's Avatar
Its absolutely normal for the engine to idle at a higher rpm during cold starts till the engine reaches its normal operating temperature. You will notice it idles at a high rpm after a cold start in summers also but the rpm will fall back to its normal level much faster than in winters as the engine heats up faster in summers. Hope it helps
Ferrarimaniac is offline   Reply With Quote
Old 15th December 2006, 04:46   #4
hellspawn's Avatar
Infractions: 0/1 (10)
the increased idling is normal.its the mpfi system trying to warm the engine.as you drive for a few kms,the idle stabilises around 800rpm as the engine has warmed up.
well a lot of swift owners face this issue.get it rectified in the first service.its nohing serious.
and btw congrats on your new ride.
hellspawn is offline   Reply With Quote
Old 15th December 2006, 10:44   #5
vikram_d's Avatar
Thanked: 940 Times
There was a rattling problem in the Swifts which were manufactured before May 2006 but I am assuming that your vehicle is very new maybe October or November manufactured.
The rattling might be because of two things. One is that there might be an OEM assembly defect which can very easily be corrected by the service centre guys free of cost. Second if you have speakers fitted in the doors then there might be a fitting problem which the service centre guys will not repair free of cost. So if there are speakers in the doors then I recommend that you first go to the accessory shop from where you got them fitted. He will be able to do it for free.
PS: I bought my Swift in July and I have no rattling problems in the car whatsoever.
Old 15th December 2006, 11:39   #6
ajitkommini's Avatar
Thanked: 109 Times
A slightly elevated RPM during cold start is normal. Since your car is new, it's probably advisable to wait for the engine to reach its operating temperature and take off only after engine revs stabilise at 800.
ajitkommini is offline   Reply With Quote
Old 15th December 2006, 13:27   #7
esteem_lover's Avatar
Thanked: 451 Times
this is not just in the swift. it applies to all mpfi cars. it is absolutely normal & good for the car. dont worry about it. try to get the rattle fixed though.
cheers
Old 15th December 2006, 14:15   #8
Thanked: 127 Times
Hi All,
Thanks for the reply. The car was brought on 8th Dec, 06. Below car bonnet it has marked as L06, which sales men told me as Dec'06 as manufacturing month. (A-Jan, B-Feb...L-Dec). Front speakers are on door and rear ones are on parcel tray.
This saturday I will take my car to MASS and see if they can fix it.
Once again thanks for enlighting me on cold start and RPM dependence.
regards,
-manju
RPM drops after cold start, and engine shuts off DCEite Technical Stuff 13 28th May 2017 01:33
Common Rail : Why is cold start tougher at higher altitudes tsk1979 Technical Stuff 144 9th August 2014 15:46
Fiat siena 1999 model - Higher RPM's while driving wolverinchandru Technical Stuff 1 2nd March 2009 17:22
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
