Old 22nd December 2006, 14:00   #1
Default Noise in the car
Dear BHPians
I am the proud owner of a Silver Adventure 1.6.
The car is sleek and is fantastic to drive. Its power is great.
My problem (which i need to confirm with Anuroop Motors) is i feel there is some cranky sound inside the car. I feel this especially when i start the car and i feel as if all the hinges and screws are loose. I feel this comes from the doors/windows and this sound is too irritating.
Does anyone has similar experience.
Thanks.
prakashc is offline   Reply With Quote
Old 22nd December 2006, 21:27   #2
WasavaTyres's Avatar
Thanked: 239 Times
Are you sure it's the door and hinges ?? How many mile shave you clocked and over what kind of terrain ?? Did you check the roof rails ??
WasavaTyres is offline   Reply With Quote
Old 26th December 2006, 11:03   #3
Yeah. The noise comes from under the seats or from the doors.
I drive on the western express highway. The roof rails are perfect. Have clocked in around 350 kms.
Can you please help.
Old 1st February 2007, 14:59   #4
I had a similar problem wid my Zen.
Investigate the problem properly... stop the car, and test each door one by one. With your hands (you can also use the mobile vibrator or anything battery operated which has moving parts), slowly shake each door and try to reproduce the problem.
If the fault is with a door, get the door serviced. They open it and check if the windows, hinges are tight.
If the sound come from the front, your rear-view mirrors cud be loose.
amu1983 is offline   Reply With Quote
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Car/SUV with low cabin noise msdivy SUVs, MUVs & 4x4s 32 3rd May 2008 11:58
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
