| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Sep 2006 Location: Bangalore-Mumbai
| Hi Auto Gurus, I am a newbie to TBHP and am already in love with it. I'm just back from my overseas assignment. I've been following various forums and threads regularly now. I've searched all the forums/threads before posting this one. Pardon me if i have missed something. I need your help on this one... My Indica (V2 DLS 2003 model) has started showing signs of aging! 3 months back we faced a peculiar problem. After few long trips (Mumbai-Pune couple of times), the coolant level went down. To the extent that i had to top it up with 1-1.5 lit. of water. I could also see the engine heating a little bit with the temp. gauge going beyond 75%, just short of danger mark. We checked everything from the Fan to any leakages in cooling system, but nothing. There were no "visible" signs of leakages (like no leakages seen under the car, after accelerating). I stay in Chembur, so i went to Wasan. As per me Wasan is worst when it comes to servicing, with their "I dont care" attitude (atleast for the Tata section..no idea about Ford). Wasan gave me appointment which was like 1 year later! Since the problem was acute, i went to Fortune, Nerul. Fortune guys are nice and they really care. They checked everything and found that the coolant pump (or some pump in the cooling system) was leaking slightly. So they replaced it with a new one and checked the pressure in the cooling system. There was no pressure loss. After that there was not much of a problem (may be because we did not do any long trips). My dad again went for a long trip last month....and the problem re-appeared. I have absolutely no idea what is causing this problem! Is it engine overheating or something? Or the coolant is happy to just disappear in thin air! I am going to Fortune again today... I would appreciate any leads on this as i dont want to spend all my vacation chasing the service center! Ciao, Ajay |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | The problem is evaporation. Ask them to check the rubber joint which connects the coolant resevoir to the system. That joint has tendency to develop micro leak due to which evaporation takes place. Its an often overlooked fault.
__________________ Reclaiming.....! |
| | #4 (permalink) |
| BHPian | Hey ajay.. in worse case scenario there could be a problem with ur cylinder head/gasket, does the car smoke more than normal on hard revving in neutral? also check if there is any coolant mixed with the engine oil.. this u can do by checking the oil dipstick.. if so then there is leakage from the cylinder head, causing the coolant level to go down.. how many kms has the car done? Regards, Mav.
__________________ Live to ride.. Ride to live.. Ladakh.. Been there done that!! Forever Michael Schumacher Fan!! |
| | #5 (permalink) |
| Hey Mav. Fortunately my car doesnt spew black smoke! It has done almost 32,000 Kms. I got my car back from Fortune...they said there was a leakage in cooling system somewhere ![]() Hope that they are right now! PS: Fortune guys also flushed the engine with some additive and added new engine oil + additive (as i had to change the engine oil anyway). I dont know if its really beneficial or just a trick from the DW's to extract money! |
| | #6 (permalink) |
| Components changed to plug the leak: 1. Pump in the coolinng system changed, as a minor leak was found. 2. Rubber hose between radiator and engine replaced. Problem solved.
__________________ Indica V2 DLS- 2002 /ICE - BLAUPUNKT, JBL Splendor- 1997 My next drive is gonna be 100+ horses... |
« Turbo emits lot of smoke and top speed has gone down
Indica V2 DLS - Engine overheating/AC issues »
| Thread Tools | |
Similar Threads | ||||
| Old Indica LEi / New Indica DLS / New Alto LXi | shuvc | Hatchbacks | 20 | 19th February 2008 16:31 |
| Indica DLS / DLS TURBO / DICOR?.....What BUY? | musicmanaman | Hatchbacks | 18 | 11th August 2007 19:38 |
| K & N for my Indica DLS | nikunj_cal | Modifications & Accessories | 4 | 25th May 2007 15:23 |
| Indica NA DLS vs Turbo DLS vs Turbo DLG | greenhorn | Hatchbacks | 10 | 5th May 2007 17:20 |
| Indica DLS vs Palio 1.9D EL - help !!! | hkanitkar | Hatchbacks | 36 | 23rd September 2005 23:54 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
