Old 28th December 2006, 11:08   #1
tsk1979's Avatar
Thanked: 16,422 Times
Default Indica V2 DLS missing problem
From past couple of days I have noticed that after few minutes of running, the car starts missing at certain RPM which corresponds to 30-40kmph in second gear. Also the idle RPM increases on its own.
The car does not have an ECU, so I am suspecting either clogged diesel filters or water in fuel. Any other causes? Right now Fuel pump problem seems remote as the FP went through an overhaul 20K kms ago after an accident.
Old 28th December 2006, 11:30   #2
Sideways's Avatar
Thanked: 18 Times
Tanveer, you are on the right track. Also have the "o" ring in the hand plunger checked. Sometimes this gives way and sucks in air, leading to a miss.
Sideways is offline   Reply With Quote
Old 28th December 2006, 11:51   #3
tsk1979's Avatar
Even I am suspecting Air now because there is also "surging" RPM problem.
Found this excellent link
Diesel Engine Troubleshooting
This link has some common problems with solutions.
This is the second time this problem has come.
The first time this came right after service, before Narkanda trip.
The service guys said that pump timing was out of place and adjusted it. The car ran for a good 1500kms and this problem came again.
The inablity of tata guys to diagnose even simple problems is really irritating.
Old 28th December 2006, 14:01   #4
Sideways's Avatar
Thanked: 18 Times
Nice link. Should be made a sticky in the tech section for further reference.
Old 28th December 2006, 17:40   #5
tsk1979's Avatar
Got the problem fixed no missing now, did extensive testdrive.
Problem : Hand Primer leaking fuel. They said due to the leak the fuel line was taking in air. They checked the entire fuel line and filters(diesel) and they are clean. So air was the culprit
Bill : 544rs(350 for Parts(Hand Primer pump) and rest labour)
Washed the car and cleaned it for inside too. Guess this is standard practice for all repair jobs now.
Old 3rd January 2007, 15:08   #6
Sideways's Avatar
Thanked: 18 Times
You are very welcome TSK.
Old 4th January 2007, 21:49   #7
Deeps's Avatar
Thanked: 68 Times
And do mention where you got this work carried out please.
Deeps is offline   Reply With Quote
Old 5th January 2007, 00:05   #8
tsk1979's Avatar
I get almost all the work from Automobile Sterling, Sector 8, Noida
Indica V2 DLS -Indica V2 DLS - Electricals falling apart - 57,000 km update cyberwhizs Long-Term Ownership Reviews 5 25th April 2013 13:04
Indica DLS / DLS TURBO / DICOR?.....What BUY? musicmanaman Hatchbacks 20 8th May 2010 19:05
Only Indica DLE & DLS to continue. All other Indica (Disel) varients phased out. Bouncer The Indian Car Scene 27 25th December 2008 09:34
Old Indica LEi / New Indica DLS / New Alto LXi shuvc Hatchbacks 20 19th February 2008 17:31
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
