Old 16th January 2007, 12:05   #16
Thanked: 157 Times
it depends.. I have done 25k till now and no issues with the clutch yet...in my Uno I changed it around 70k...that too since the mechanic insisted...otherwise the car was running just fine...
If you have no issues with the clutch..if the cosat outside warranty is just 3k or so...maybe you are better of waiting...just my twon cents...no point in getting engine parts opened every now and then...the refitment is nver "factory like"
Buffetfan is offline   Reply With Quote
Old 16th January 2007, 12:33   #17
shuvc's Avatar
Thanked: 287 Times
That exactly was the line I was thinking of .. one of the reasons I went for the VXi was that it did not even need any accessory mods, hence no tampering of factory fittings.
Good .. lemme sit on it .. checked the Nov issue of ACI .. clutch pressure plate for Baleno is the cheapest for its class at around 2.6K.
Old 16th January 2007, 13:15   #18
supremeBaleno's Avatar
Thanked: 1,708 Times
No issues with the clutch in my car.
It would be useful for owners and potential buyers to have a look at this spare comparison sheet that ACI puts out every year. Especially for those of us who do not subscribe to auto-mags. I remember, we discussed last year also about whether it would be proper (copyright infringement issues) to put it up on the forum.
@Mods, is it OK to put up a scanned version of the comparison sheet, with due credit given to ACI ?
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Using clutch and designing clutch... The Wolf 4x4 Technical 55 9th May 2011 11:50
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
