Old 18th February 2016, 15:01   #76
prithm's Avatar
Thanked: 493 Times
Default Re: Flaws in Maruti Swift (all generations)
Originally Posted by SupratikDebnath View Post
Hi all,
My friend's Swift DDiS VDi is showing some issues now.
Check Engine light is staying ON even after firing up the engine.
Maruti service center has diagnosed and found two error codes:
P0403 EGR valve controller circuit
P0180 fuel temperature sensor circuit
Even after all options were tried out by them, the issue still exist.
The car is behaving fine and there is absolutely no behavioral change whatsoever.
Please help out and share your views.
Haven't they cleaned EGR valve or replaced the circuit when you reported this issue ? Usually MASS will not clean this, they replace the part if it has reached EOL cycle. Check this with them, both sensors and circuits are replaced if they throw issues.
prithm is offline   (1) Thanks Reply With Quote
Design flaws and cost cutting in Indian cars Meili The Indian Car Scene 261 26th September 2014 12:24
Paint flaws in New car ( VW Polo) manikjeet Technical Stuff 16 20th November 2010 18:13
ABS types and generations sharathjeppu Technical Stuff 23 8th June 2009 13:53
Generations of Alto Technocrat The Indian Car Scene 5 17th November 2004 20:46
Photo : All 4 generations of the M5 GTO The International Automotive Scene 9 15th September 2004 18:38
