| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #17 (permalink) |
| BHPian Join Date: Mar 2007 Location: Sindelfingen/Stuttgart-Germany
| Power brakes are nothing, but a common term for "power assisted brakes", usually a booster is employed to reduce pedal effort by driver, which serves the purpose. It is a round thing having a diaphgram inside, which work on pressure difference principle.It may be either, vaccum boosted or pressure boosted depending upon the design. This is the story of power brakes, i guess M800 is the only car in india without a booster.
__________________ Arun |
| | #18 (permalink) | |
| Senior - BHPian | Quote:
Maruti has made enough and more money on this car. Hate to hear that they still dont have the Booster brakes yet.
__________________ *2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135* | |
| | #19 (permalink) | |
| Quote:
you have to replace complete kit including master cylinder & have to make arrangments to fit booster+master cyl. assy. in cramped hood space of M800, going to be a costly affair & doesnt makes sense. I think using hight performance brake pads/liners makes more sense here in case of M800. EDIT: not to mention a vaccum pump/compressor driven by engine to feed the booster diaphgram.
__________________ Arun Last edited by arunforu1 : 8th June 2007 at 14:26. | |
| | #20 (permalink) | |||
| Newbie Join Date: Feb 2004 Location: Mumbai
| I think the funda given is not all correct! Quote:
PS My gypsy was modded with a booster brake -By Maruti! | |||
| | #21 (permalink) | |
| BHPian | Quote:
Thanks for all the replies guys, but Oh! I am confused now...somebody please help meee... ![]() I will go in for it if it makes (in the least) 25% improvement in the braking efficiency,. | |
| | #22 (permalink) | |
| Quote:
I dont know about vaccum from intake manifold being sufficent to boost(i may be wrong), but have practically seen a vehicle with a separate vaccum pump to store boosting diffrential pressure in vaccum tanks. Master cylinder & servo combo simply multiplies the foot effort by hydraulic means(simple physics). now effort augmentation is achieved using a booster, means booster is pushing same fluid from master cylinder under much more pressure(foot effort+booster effort), so pressure inside brake pipes increases & hence chance of failure of hoses which were designed to handle lesser pressure(i.e. from foot effort augmented by master+servo combo). I am not sure about smaller vehicles, but bigger vehicles do have a dedicated vaccum pump(or compressor) to feed booster & not brake fluid directly. i hope this clears everything, there is a reservoir to hold vaccum/pressure which supplies the vaccum or compressed air to booster when pedal is actuated by driver. You may be correct that smaller vehicles might use intake vaccum for boosting(as i am not aware of this thing), but what mechanism is there to tackle: 1. variation in intake vaccum due to variation in enigne rpm under different driving conditions? 2. in case of engine shut off, all boosting must go at once, where as it doesnt happens, you loose boosting only after 2-3 pedal depressions ?
__________________ Arun | |
| | #23 (permalink) | |
| I not very technical but if my understanding is right - What you are talking applys to Quote:
I would like to quote from somewhere I read a long time ago!(May be How Stuff Works) Generally four types of power brakes exist. These can be categorized under vacuum suspended; air suspended; hydraulic booster, and electro-hydraulic booster. The first being, the most preferred kind in power brakes. In cars with vacuum booster type system, the brake pedal pushes the pushrod connected to the pistons within the master cylinder. Simultaneously, the pushrod opens the vacuum-control valve so that it closes the vacuum port and seals off the forward half of the booster unit. The engine vacuum line then creates a low-pressure vacuum chamber. Atmospheric pressure in the control chamber then pushes against the diaphragm. The pressure on the diaphragm forces it forward, supplying pressure on the master cylinder pistons. When the brake pedal is released, outside air supply is sealed off and vacuum valve is reopened. This restores vacuum to both sides of the diaphragm, allowing everything to return to its original position. Unquote To the best of my knowledge - A Maruti uses a vaccum booster type. | |
| | #24 (permalink) | |
| BHPian Join Date: Apr 2006 Location: chennai
| Quote:
| | #25 (permalink) | |
| Quote:
It should cost anywhere around 4000 rs . But , I personally feel its a waste of time and money would be better spent on better wheels or tyres . "Adding a booster does not help braking ,it just lowers the energy required to pump the master cylinder . " FInally ,you need to have the engine switched on when you have a brake booster ,otherwise the brakes would not work ,but , with a manual brake , even if the engine is switched off the brakes would still work. | |
| | #26 (permalink) | |
| Quote:
A word of caution here. Steel braided hoses which I have seen in the market are not really of good quality and the inner rubber will get punctured under high pressure . So please use the genuine brake hoses. | |
| | #27 (permalink) |
| Distinguished - BHPian ![]() | Have you checked Fluid Level variations lately. Are you sure there isn't any minute leak in the lines. Get Bleeding done and then drive around for a few days and check if the condition returns. The Lack of bite can be due to a lower pressure int he lines. However it can also be brake fade.
__________________ ________________________ Every Ferrari is always a Fiat |
| | #28 (permalink) |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| You can try the following IMO * Check if the pressure is being lost due to some leakage in the master cylinder. * The brake oil may have trapped air bubbles. Try bleeding the oil and then fill in afresh. * Check the pads for having gone smooth. Make them coarse. The grip will increase. |
| Thread Tools | |
Similar Threads | ||||
| Disk Brake to normal brake change? | ramki067 | Motorbikes | 10 | 7th August 2008 14:19 |
| Sprint Booster | Sahil | Modifications & Accessories | 0 | 18th March 2008 19:35 |
| Power Booster!!!! | stevie | Modifications & Accessories | 2 | 10th January 2008 23:43 |
| Paint for disc brake pads & rear brake drums | VC12 | Modifications & Accessories | 6 | 20th August 2007 16:45 |
| STP octane booster?? | panky12345 | Technical Stuff | 1 | 7th April 2006 03:51 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
