Old 10th September 2015, 10:44   #31
padmakar.vikas's Avatar
Thanked: 11 Times
Default Re: Booster Brake Adjustment - Is it possible?
Hey Srini, thanks for your response, since I could see it in front of my eyes, it wasn't hard for me to believe what the MASS supervisor cited as the reason why it could not be done. The master cylinder is almost double the size in Wagon R. I have not been able to yet see the booster cylinder of a K10 but I had my share of doubts about the quality of brake pads on the F8. So, if one were to go for a no frills upgrade, would it be to opt for better pads (if so which ones would do the job without burning a hole in the pocket) or upgrade to a bigger booster? Thanks!
padmakar.vikas is offline   Reply With Quote
Old 30th September 2015, 21:31   #32
im_srini's Avatar
Thanked: 399 Times
Post Re: Booster Brake Adjustment - Is it possible?
Originally Posted by im_srini View Post
As far as I know, the Lxi ( F8D ) & Vxi ( F10D ) Altos used the same booster - will confirm the part-numbers for the F8D, F10D, & K10 Altos this weekend.
Hello Vikas, it appears that I was mistaken, the brake master cylinder does appear to be different across the Alto variants ( booster appears to be identical though ).
So, if one were to go for a no frills upgrade, would it be to opt for better pads ( if so which ones would do the job without burning a hole in the pocket ) or upgrade to a bigger booster ?
I don't use fancy brake pads anymore, just using regular MGP ones.
Fake brake pads abound though, just ensure the ones you get are genuine.
Also, with time, the rubber of the vacuum pipe from the throttle-body to the booster can become hard & develop hairline cracks, you could try changing this too.
I would change brake pads first, if not happy, change the rotors, if still not happy, change the vacuum line - basically, consider a booster upgrade only as a last resort.
im_srini is offline   (1) Thanks Reply With Quote
Is it possible to fit seat height adjustment as an accessory/aftermarket? CrAzY dRiVeR Modifications & Accessories 39 12th April 2018 18:24
Swift Diesel - New Brake Booster Design By Maruti humyum Technical Stuff 181 23rd May 2013 17:12
Brake Booster Failure on a New Ford Fiesta 1.6S. Need help/info! capt_rocker Technical Stuff 37 1st November 2011 17:39
Improving Zen MPFI brakes by fitting an Esteem Type II brake booster etc Trust_In_Thrust Modifications & Accessories 26 6th June 2010 12:42
Brake booster Assembly of the Indigo joecherian Technical Stuff 22 9th June 2009 14:27
