Thread Tools
Old 2nd January 2007, 21:07   #1 (permalink)
mail4ajo's Avatar
Default Booster Brake Adjustment - Is it possible?
My Alto has booster brakes. It has run 6500kms till date. After I drove about 800kms continously, I noticed that the brake pedal has more travel (play) than before. When the car was new, the play was very minimal and the brake bite was very sharp. A small feel of the brakes would stop the car.
I checked with the service center and they said that I can't adjust the brakes for the pedal play. They can only tighten the handbrake to get a better brake effect. The braking is fine, but I just love the sharp bite of the brakes. Is it possible to bring it back like new??
__________________
*2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135*
mail4ajo is offline   Reply With Quote
Old 2nd January 2007, 22:01   #2 (permalink)
Team-BHP Moderator
Mpower's Avatar
Hydraulic reservoir is supposed to compensate for wear so you shouldnt see any play..check the linkages.
as far as bite either clean the pads with sandpaper/grinder to remove dust or get different brand of pads.
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 2nd January 2007, 22:23   #3 (permalink)
harsh87's Avatar
get brake bleeding done or get the hi performance steel braided brake hoses
these things surely work they wont allow any loss of pressure through the steel lines to the caliper
harsh87 is offline   Reply With Quote
Old 2nd January 2007, 22:25   #4 (permalink)
drpullockaran's Avatar
Default Ratchet mechanism
In addition to the oil reservoir playing a role in the auto calibration of the pedal travel there happens to be a ratchet mechanism available for the rear wheels which is so for the PALIO and the Junkindica so it could hold true for the ALTO as well. Please do not I repeat do not allow the mechanic to tighten your handbrake assembly to bring back the bite. You will end up burning rubber(miniscule) and brake pads. You will also see a marked deterioration in pick up and fuel efficiency. As Mpower suggested a different set of pads depending on which seems more glazed(front or back) should do the trick. Do remember the disc brake pads in the front do 80 percent of your braking so give them a looksee before you delve into other aspects. Bye and wear your seat belts.
drpullockaran is offline   Reply With Quote
Old 2nd January 2007, 22:31   #5 (permalink)
If you remove the master cylinder (MC) from the booster you will find a small finger like shaft that actuates the MC. This has a tip which is adjustable (usually). You will need to hold the shaft with a lock plier and loosen the tip. This is usually done on booster that have seen quite a bit of use!!! Remember that the adjustments will have to be made quarter turn at a time or you'll end up with stuck brakes. Anyway this adjustment is usually not recommended. Most people just replace the booster.
__________________
Live Life King Size!
jyobeb is offline   Reply With Quote
Old 2nd January 2007, 22:33   #6 (permalink)
mail4ajo's Avatar
Of late, after a long drive, I see black marks on my front wheels, which I presume is from the brake pads. Is this a fault or normal?
But, what I cant understand is isn't it too early for a change in the pads and the booster itself?? Does the pads wear out so fast?
__________________
Old 2nd January 2007, 22:38   #7 (permalink)
rahul_intlad's Avatar
IS this [Brake booster] what people mean when they have stickers like:
Caution Power Brakes.
Or else what are these Power Brakes
Ps:
Are these articles of any help[taken from google,have absolutely no knowledge about the topic]
Troubleshooting The Brake System
Troubleshooting Power Brakes
rahul_intlad is offline   Reply With Quote
Old 2nd January 2007, 22:39   #8 (permalink)
iraghava's Avatar
Yes that is normal it is brake dust from the brake pads which gets accumulated on the wheels. No need to worry about it.
AFAIK they are usually used on vehicles with Air Brakes like trucks not sure though. Brake boosters though are an integral part of all modern car's braking system and are present in all cars nowadays.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 2nd January 2007, 23:00   #9 (permalink)
Ishan offlately in pune a number of cars[alto,maruti 800,qualis etc] are sporting this sticker[Caution Power Brakes] .
Old 2nd January 2007, 23:57   #10 (permalink)
iraghava's Avatar
Well Rahul let me put it you this way - The car most often seen with this sticker is the Amby & you & I both know about the Amby's braking abilities now don't we??
__________________
Old 3rd January 2007, 01:58   #11 (permalink)
rr_zen's Avatar
Rahul, if you want to experience the difference between an ordinary brake and a booster brake, try driving a Maruti 800 manufactured say in 1995 or 1996 and then drive a new one. You can locate the booster under the bonnet close to the area where you find the brake fluid reservoir and it is usually circular in shape and black in colour.
__________________
Ships are safest in harbour. But thats not what ships are made for !!
rr_zen is offline   Reply With Quote
Old 3rd January 2007, 11:05   #12 (permalink)
humyum's Avatar
Except for the 5 speed maruti 800 and to be more specific the 5 speed 800 DX model.No other 800s have brake booster.Even the current lot 800 dont have a brake booster.800 is the only car being manufactured in india which does not have a brake booster
__________________
Its not the age,Its the mileage
Old 5th January 2007, 19:42   #13 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Mail4ajo,
On one of my first trips to america i was greatly puzzled by the fact that all the cars i would see had dirty front wheels and clean rear wheels , then i realised that since they do not have watchmen and others who wash their cars every morning, the brakedust just accumulates (and there is more of it on the front wheels, since they do more of the braking + sometimes the rear is drums).
As for your spongy brake pedal, the first thing you should do is get your entire braking system bled, and filled with some new brakefluid.
Try that out and see if it makes a difference.
cya
R
Old 10th January 2007, 15:08   #14 (permalink)
Default Xeta - Sound while Braking
Hi Guys
My Indica Xeta is about 6200 kms (5 month old) driven now and every time I apply brakes there is a sound that comes. Like the one we hear in movies..... crank' crank' dont know if its a normal phenomenon but feels as if I am driving a car which is over 2 years old. Got my servicing done about a fortnight ago, though.
Also in the mornings the car does not start up at the first instance, need to turn the key atleast 3 times post which it runs. Is this because of the winters here in Mumbai?
Havent done teflone / polishing or anti rust of the body, should I wait till monsoons that is about May June or should I get it done right away. Have read the thread on wax polishing, so is pre monsoon a better time to get it done.
Hope to hear from you guys soon!
saildrive is offline   Reply With Quote
Old 10th January 2007, 15:55   #15 (permalink)
vezj420's Avatar
Let me summarize a few points:
a) Brake noise (front): Get your pads and rotors checked. Most of the time, changing the pads will help get rid of the noise and improve brake feel. However, check your rotors also to ensure that they are smooth and even. If not, replace rotors too.
b) Brake noise (back): Sadly, I'm facing this problem now , although it's not very pronounced since back drums are almost never solely used (no I don't do any handbrake turns either!). However, I'm thinking a cleaning of the drums and possibly a change of shoes should help.
c) Brake feel/bite: Okay, there's several things one can do to improve braking performance, but the small/maintenance work could include:
Bleeding and replacing brake fluid. Brake fluid can also be 'upgraded' to a higher DOT rate/equivalent, although this shouldn't be necessary for your daily driver cars!
I see someone's already mentioned getting steel-braided brake lines. This is actually a big contributor to brake feel.
__________________
The Edge...the only people who really know where it is are the ones who have gone over.
- Hunter S. Thompson
vezj420 is offline   Reply With Quote
Thread Tools
Camber Adjustment query & Camber Adjusting Bolts? hell_rider Technical Stuff 17 11th April 2008 12:12
Power Booster!!!! stevie Modifications & Accessories 2 10th January 2008 23:43
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 6 20th August 2007 16:45
Hydro Octane Booster HAFI Modifications & Accessories 1 25th December 2006 01:28
STP octane booster?? panky12345 Technical Stuff 1 7th April 2006 03:51
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
