Thread Tools
Old 3rd January 2007, 14:51   #1 (permalink)
arctic's Avatar
Default Questions i would like cleared!!
hi all,
i have a honda city 1.3exi 1999 currently have 4-1 header and a kn high flw filter(conical) from frk......
1. the 1st and 2nd gear have to be forced in sometimes and reverse grinds when shifting at rest.... cause??
2. the tyre size is showing 175/70/13 ..are these stock???
3. are potenza g3 or es100 available in 195 /60/13 if so will my stock rims do??
4. how often does the filter need to be cleaned (indian roads)???
5. can the steering sensitivity be increased??
6. can the steering wheel be changed ???(to something sporty like the m3 kind of steering)
7. anybody know where i can learn the basics of rally driving ?? (wanted to ask anyways)
thank you for your time....
i just finished watching 5 seasons of topgear (sigh 3 more to go)....and i have to say jc,hammond and may are just awesome.... heard the new season is starting in feb..
arctic is offline   Reply With Quote
Old 3rd January 2007, 15:14   #2 (permalink)
iraghava's Avatar
Could be a weak clutch or could be that you're not depressing it properly. Get the clutch & gearbox checked up from a good garage.
Yes these are stock sizes.
G3's are available in that size but I would not recommend fitting a tyre that wide on stock rims. You should stick to 185/65 R13 as it is a good upsize & will fit fine on your stock wheels.
I think somewhere between 5-10k depending on dust & driving conditions in your city.
Minor difference can be made by switching to good tyres but it would be a very miniscule difference. No other ways are there to increase sestivity and why would you want to do it anyways?
Yes it can be changed.
In India I don't think there are any schools. There are some in the UK & you can google it for more information.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 3rd January 2007, 20:17   #3 (permalink)
arctic's Avatar
thank you for the reply... steering play is too long i feel, i want to be able to turn more with less rotations (i have to turn the wheel quite a bit just to switch lanes) i guess it will be better at higher speeds...
why on earth would honda put smaller tires (13inch, one onch smaller) for a car thats basically the same as 1.5,vtec....
anybody here got an greddy emanage here??? if so is it any good??
Old 3rd January 2007, 22:04   #4 (permalink)
killjoy's Avatar
hi all,
1. the 1st and 2nd gear have to be forced in sometimes and reverse grinds when shifting at rest.... cause??..
1. might be the synchroniser rings in the gearbox
2. i think 175 are stock for the honda city 1.5, not sure about the 1.3
3. potenza is available, stock rim should be fine
4. regular filter, maybe once in 2000 or 3000 kms, go for k&n
5. not sure, dont think so
6. yes definetly
7. there are plans to conduct a rally school but i think that this is on hold for now, will keep you posted if there is something happening.
__________________
Profession: IT
Career: Motorsports
killjoy is offline   Reply With Quote
Old 3rd January 2007, 22:26   #5 (permalink)
binz's Avatar
Smaler tires have larger side walls and hence you get a better ride quality(you already know this)
Why you ask,does the car have these even though its basically is the same as the 1.5/v-tec.The same reason why the M3 has a one inch upsize on the standard 3 series.Blah blah...The 1.3 is more of a family vehicle whle the v-tec is driver oriented.
OTher reason-fuel efficiency
__________________
HAhaha
Old 4th January 2007, 01:54   #6 (permalink)
arctic's Avatar
any idea how much a set of 5 stock bridgestone tires with medium wear will sell for???
Old 4th January 2007, 06:32   #7 (permalink)
Rudra Sen's Avatar
That depends on your tyres condition.
Old 4th January 2007, 07:52   #8 (permalink)
manveet's Avatar
As per his first post, he already has an FRK conical filter.
__________________
Ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?
manveet is offline   Reply With Quote
Old 4th January 2007, 09:28   #9 (permalink)
killjoy's Avatar
FRK conical filter? anybody got a link to this?
__________________
Profession: IT
Career: Motorsports
Old 4th January 2007, 12:22   #10 (permalink)
arctic's Avatar
lol...kn konical filter part no 4550.. fitted by frk!!!! sorry for the ambiguity
Old 4th January 2007, 15:18   #11 (permalink)
arctic's Avatar
some more questions....
8. whats the ecu specification in the 1.3 city????
9. what is obd???
10. i hear city has a de-tuned d15 engine....in what way is it detuned???( didnt think it was possible to de-tune 1.5l to 1.3l)
Old 4th January 2007, 17:42   #12 (permalink)
iraghava's Avatar
That's not possible without expensive modifications.
1.3/1.5 came with the same tyres i.e. 175/70 R13 only difference was the brands & wheelcaps. VTEC came with 14" for a multitude of reasons not limited to - More cost of 14" tyres, more ride comfort with 13", diffrentiating factor to make the extra cost of the VTEC reasonable etc. etc.
What do you mean by that?
It is detuned to compensate for our poor fuel quality. And no the 1.5 is not detuned to a 1.3, they are two different engines.
__________________
Old 4th January 2007, 21:24   #13 (permalink)
arctic's Avatar
whoa thanks for the info.....
by ecu specs i wanted to know if obd 1 or 2, various functions the ecu controls apart from the obvious spark/injector timings etc.
Old 4th January 2007, 22:50   #14 (permalink)
iraghava's Avatar
I think its OBD II .
__________________
Thread Tools
New Civic 1.8V AT. Questions questions... ImmortalZ Sedans 6 12th June 2008 09:49
Many questions chvvkumar Motorbikes 26 13th January 2008 01:44
Massive traffic jam on Vashi Toll bridge - Now cleared Venkat Street Experiences 22 22nd August 2006 09:42
Some questions serious ones...? S350L-E240 Technical Stuff 33 7th May 2004 19:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
