| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: May 2006 Location: Chennai
| Hi, The automatic climate control air conditioning in my Swift ZXI doesnt seem to work if the temp is set at 18C - it runs continuously at full power. However, if I set it to any other temp 18.5 upwards, it works fine. Any ideas why this is happening? I'm planning to take it across to the service centre to have a look but just wondering if theres a simple solution to this. Thanks! |
| | #2 (permalink) |
| BHPian Join Date: Feb 2005 Location: New Delhi
| Your climate control doesn't seem to work at 18 degrees is because it will not go beyond that temp. setting or will show cool as a lowest setting , so it works on full blast to keep ur car cool. Same is the case with my corolla also. However, when you increase the temp, it will lower the blower settings as soon as you approach about 20 deg. as after all it is an automatic climate control system ![]() |
| | #4 (permalink) |
| ok let me rephrase that. previously when I set the temp on 18C, the fan goes to full until the internal temp starts lowering, after which the fan speed gradually decreases. in the daytime this can take a while (im in chennai), and in the night this usually starts lowering within 10 minutes. Now however, the fan speed does not lower at all even after running it at 18 for 40 minutes in the night (thats as much as I tested before i gave up). The moment I take it up a notch to 18.5 the fan speed automatically lowers drastically, which means the sensor is working. so how come its not working at 18? |
| | #5 (permalink) |
| Can any other ZXI owner let me know if I've got this wrong? I can swear that the automatic control used to work at 18C as well, gradually lowering the temps, but I'm starting to wonder. If any other ZXI owner can let me know if the fan always stays on max at 18C that should put my mind at ease! Thanks! |
| | #6 (permalink) |
| BHPian | There are two sensors inside the cabin which check temperature. Check if anything is blocking or obstructing these sensors. I faced this problem when I kept a cloth on the sensor near the windhield by mistake. Removed the cloth and everything went back to normal.
__________________ One piece at a time. |
| | #7 (permalink) |
| BHPian Join Date: Nov 2005 Location: Bombay
| Yes my Zxi does the full blower thing for a few minutes, after which it reduces the blast. I'll check again on the way to dinner tonight. I think your sensor might be damaged. The sensor is just to the right of the place where the music system head unit goes. There are two or three slots in the dashboard right there.. Might have gotten damaged by water etc. Try starting the AC with the temp set at 18.5 or 19 and see if it behaves normally then. Cuz usually as soon as you adjust the temp upwards the blower reduces. Overall I think you're quite fortunate. Now you can cool your car to way below 18 C if you want to. |
| | #10 (permalink) |
| BHPian | Ok This thing happens in my car also. So I called up my friendly neighbourhood Maruti Technical guy and he told me that this is the way the system functions. At both the outer extremeties of the temperature range that is 18 deg & 32 deg C in the case of the Swift the fan will always run at full blast and will not slow down. Also he mentioned that all climate control systems in all cars work like this. Can somebody with any other climate controlled car besides Swift please clarify this?
| | #11 (permalink) |
| BHPian Join Date: Feb 2006 Location: Bangalore
| Well.. in a Baleno, the lowest you can set is 19.. and I avoid 19 as I hate the aircraft engine style noise it results in! Never had it on 19 and auto for longer than 10 mins. And the blower does slow down after a while! |
| Thread Tools | |
Similar Threads | ||||
| AC vs climate control | LandCruiser | Technical Stuff | 27 | 5th July 2008 13:59 |
| Can you make a climate control system | tsk1979 | Modifications & Accessories | 22 | 1st October 2007 16:24 |
| Climate Control Unit for the Verna CRDi | tallkat | Modifications & Accessories | 12 | 17th August 2007 11:01 |
| Swift ZXi Climate control_improve fuel efficiency | pranil | Technical Stuff | 21 | 13th March 2006 17:16 |
| Climate control Baleno VXi ! | shuvc | Sedans | 30 | 23rd January 2006 14:55 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
