| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Apr 2006 Location: kerala
| Hi guys, i had noticed a burning smell on my swift vxi, even after a small ride. I believe that the petrol was adulterated. Could that be the reason? Also recently i drove for like 2 km with the handbrake on, it was a horrible road, i might there wasn't a road, just shifting b/w 1st and 2nd. And there was a burning smell, what kind of damage could this have done. The earlier mentioned smell was there before this handbrake incident. |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | There had been a smell-diagsnostic thread here before. Anyway hope this helps Troubleshooting by Smell | Advance Auto Parts
__________________ If you lose your temper, you’ve lost the argument |
| | #3 (permalink) | |
| Senior - BHPian Join Date: Aug 2006 Location: Pune
| Quote:
| | #4 (permalink) | |
| Senior - BHPian | Quote:
I believe you have burnt your clutch plate. Viper
__________________ NO ONE DARES COME CLOSE | |
| | #6 (permalink) |
| no jkdas, i never complained about pickup problem with my swift. " Hi, I believe you have burnt your clutch plate. Viper " With the handbrake on how do i burn my clutch plates. I'm usually very caerfull with the clutch, but unfortunately not with the hand brake. Another thing, while engaging the hand brake, which brake is engaged front disk or rear drum or both. Another thing, the smell was there before i used the hand brake, now i filled speed, and now i believe there is a different problem. And another thing, my engine gets awfully hot, even after use for just a couple of minutes. But the heat indicator will always be at the centre, i have never even seen it at quarter, alway at half, it this normal. |
| | #7 (permalink) | ||
| Quote:
| | #8 (permalink) | |
| BHPian Join Date: Mar 2006 Location: Phoenix, US
| Quote:
The tyre would be ok unless the side walls got pierced against something sharp or banged against something blunt. In anycase the damage should be visible. Bad road mostly lessens the life of the suspension. If you slip clutch then include that also. Rattling is another concern! | |
| | #9 (permalink) |
| Newbie Join Date: Aug 2006 Location: Bangalore
| Hi The burning smell has been confirmed by many swift owners and is a problem till first service @1000 km. I too had that burning smell but now it has faded away. The heat indicator for me also remains at center even when i drove for around 150 kms at a stretch, so i guess it's normal but i'll confirm it again with the maruti guys tommorow. |
| | #10 (permalink) |
| Newbie Join Date: Dec 2006 Location: Bombay
| Same problems here. I get a slight burning smell my Swift's just done 200Kms. Also the temp indicator remains fixed at the center of the dial??? irrespective of the distance travelled. I chkd all the wheels after a long drive they werent hot or something??? The smell thing kind of bugs me and is a bit scary??? |
| | #12 (permalink) |
| BHPian Join Date: Dec 2006 Location: Bangalore
| Hi, Responding to "Engine Temperature" questions. When ever the engine temperature increase beyond some upper limit, the fan kicks in, thus cooling the engine. Once the temperature falls below the lower limit, fan is turned off. Thus the temperature is maintained. Specifically, if you are driving on highway, above 40kmph, then there is unlikey that engine will get overheated, as the air temperature is sufficient enough for heat transfer, unless it is too hot outside. In my previous Indica, I have driven almost 400+kms, without turning off the engine (for AC purpose) even during breaks, no problems what so ever. regards, -manju |
| | #13 (permalink) |
| [SIZE=2]I had given my car to AVG, thiruvalla following the same problem, smell coming from the exhaust. I had given it to them like three weeks ago. One service guy like spend like a couple of minutes near the exhaust smelling the fume and told me that the smell was from the catalytic converter. Then he popped the hood, pulled the acceleration cable on the engine slowly, listening to the engine carefully, and he told me that there was no missing. I asked them to check the timing and they said that there was no need for that. There explanation was that the petrol in my tank gets old and leads to improper burning. Earlier i would fill a full tank it stays like that for a month, till the next fill up to the brim. After i gave them the car that day, i had filled up twice and consumed the whole petrol, and still that problem persists. So i again i had gone to AVG yesterday and they finally checked the timing and told me that there was variation and they took it for a test drive and told me there was a small loss in pickup, and its a one day work minimum, and i had to take the car back, since i needed the car urgently. Now i'm giving my car tomorrow morning, if anyone can pinpoint the problem or had similar problems, please help out, since i need the car back urgently. I'm just afraid that running my car like this for the last 3 months, would have had any ill effects on my engine? Another thing, since day one on purchasing this car i have had occasional problems with the gear, first the reverse gear would be very stubborn to fall, sometimes when i move to 3rd gear it just falls back to neutral, and sometimes after switching on the engine, and shift to first, the car would jerk like in buses, when they shift to first the whole bus will jerk with the gear. Everytime i give the car for service, they adjust the clutch, but still the problem persists. Hope to see some inputs on this one. Thanks. [/SIZE] |
| | #14 (permalink) |
| C'mon guys, how come no reply, i'm spacing my reply for u guys. I'm going to give my car to AVG now. I had given my car to AVG, thiruvalla following the same problem, smell coming from the exhaust. I had given it to them like three weeks ago. One service guy like spend like a couple of minutes near the exhaust smelling the fume and told me that the smell was from the catalytic converter. Then he popped the hood, pulled the acceleration cable on the engine slowly, listening to the engine carefully, and he told me that there was no missing. I asked them to check the timing and they said that there was no need for that. There explanation was that the petrol in my tank gets old and leads to improper burning. Earlier i would fill a full tank it stays like that for a month, till the next fill up to the brim. After i gave them the car that day, i had filled up twice and consumed the whole petrol, and still that problem persists. So i again i had gone to AVG yesterday and they finally checked the timing and told me that there was variation and they took it for a test drive and told me there was a small loss in pickup, and its a one day work minimum, and i had to take the car back, since i needed the car urgently. Now i'm giving my car tomorrow morning, if anyone can pinpoint the problem or had similar problems, please help out, since i need the car back urgently. I'm just afraid that running my car like this for the last 3 months, would have had any ill effects on my engine? Another thing, since day one on purchasing this car i have had occasional problems with the gear, first the reverse gear would be very stubborn to fall, sometimes when i move to 3rd gear it just falls back to neutral, and sometimes after switching on the engine, and shift to first, the car would jerk like in buses, when they shift to first the whole bus will jerk with the gear. Everytime i give the car for service, they adjust the clutch, but still the problem persists. Hope to see some inputs on this one. Thanks. |
| | #15 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| catcon smell is common and its stinking not burning smell timing a little bit of retarding or advance wouldn cause big harm gear clash clutch adjustment and yes swift stories with clutch problems are loads in tbhp, so maybe refer to them
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| Thread Tools | |
Similar Threads | ||||
| The Segway - Burning Rubber @ 10 kmph | Steeroid | The International Automotive Scene | 46 | 3rd July 2008 23:21 |
| Santro -- engine burning stench? | clark_kent | Technical Stuff | 7 | 25th June 2008 16:13 |
| burning smell in car cabin | harry2223 | Technical Stuff | 9 | 28th January 2008 16:50 |
| Wagaon R Duo Eyes burning | shivkumar19 | Technical Stuff | 11 | 16th August 2007 16:40 |
| Burning sensation in eyes while in the car | Sush | Shifting gears | 10 | 21st April 2005 22:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
