Old 6th January 2007, 12:06   #1
navdeep's Avatar
Post M800 : Sound from rear
Posting from original thread :
Firstly,
Its freezing cold here in my City somewhere around 9 degrees. I am getting a sound from rear left side ( or left tyre - fuel inlet side) of M800 ( atleast it seems to my ears ).
The sound is kadd .. kadd .. kadd. I am feeling it from last 20 days. Its not very loud but yes very much noticeable. I get the sound when I press accelerator. As soon as I release it , the car runs smoothly without sound. Its more noticeable when I start in the morning. What
can be the problem. Can I ignore this or should I visit service centre.
Secondly,
From the same side I get vibration sound when I reverse my car. Are both these problems interlinked ?
From the same side, I got my car repaired in Oct. The brake fluid was leaking infact at the time of repair there was no fluid. So he replaced something on that wheel ( I don't recall what it is called ). And In the morning days sound of engine has increased from the last few days ( when idle ).
This is all info I can provide at this moment. Please help.
navdeep is offline   Reply With Quote
Old 7th January 2007, 09:51   #2
navdeep's Avatar
can anyone help me out here
Old 7th January 2007, 16:48   #3
CrAzY dRiVeR's Avatar
Thanked: 19,930 Times
Are you sure its the left rear???
If its left front, must be the shaft... I had a damaged shaft sometime back, and it used to give thud thud sounds on reversing and turning, and accelerating...
Did you check with the service centre???
Old 7th January 2007, 17:45   #4
navdeep's Avatar
yes 90% its rear left ( petrol inlet side).
It has something to do with winters. Usually I drive in the morning 9:00AM the sound is quite audible and back home around 7:00 PM. But I did'nt not noticed at all when I went to market aroound 12:00 noon. Th problem was not there neither while reversing nor while driving.
Old 7th January 2007, 17:48   #5
Vid6639's Avatar
Thanked: 21,086 Times
get your brake liners in the rear checked. could be due to cold the brake liners expanded a little and are fouling. is the sound like something rubbing?
else get the suspension checked. which model is your 800 leaf springs or the independant ones?
Old 7th January 2007, 18:19   #6
navdeep's Avatar
its sep 2004 E-II model.
]get your brake liners in the rear checked. could be due to cold the brake liners expanded a little and are fouling.
I get a sound ( sometime ) when I release parking brakes ( hand brakes ). It sounds like "Kadak" when a release. Just one sound.
its like kat kat kat .. not loud but still audible
Is it something serious ?
Old 18th January 2007, 16:21   #7
navdeep's Avatar
Update : I got it checked. The sound is from bearing of axle. He said continue to drive as long as you can, it need to be replaced with new one. There no harm in driving in same condition.
Old 18th January 2007, 21:40   #8
flipsyde's Avatar
Thanked: 62 Times
i dont think driving with a bad axle bearing is a good thing..... firstly your tyre will start wobbling slightly in higher speeds and secondly depending on the bearing damage it will unevenly wear out your tyres.
its not too expensive to replace.....i suggest your get them replaced soon.
flipsyde is offline   Reply With Quote
Old 19th January 2007, 09:20   #9
navdeep's Avatar
sound is heard only for 2-3 kms intially then its fine. he said its just begining. Replacement cost was around 2300/- . How much did u pay ?
Rear Jack placement in M800 ? lurker Technical Stuff 7 26th June 2008 00:43
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
EPS and Rear Wiper for M800 sureshshanmugam Modifications & Accessories 9 1st October 2007 17:38
FREE: Wooden Rear Parcel Shelf For Speakers - M800 gopz Shifting gears 0 9th July 2007 15:37
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
