Old 6th January 2007, 16:13   #1
Shan2nu's Avatar
Thanked: 89 Times
Default Weird "Engine Management" probs & TIP on how to check Honda engine codes yourself !!
While driving the Vtec today, i suddenly noticed the engine management signal light up. But somehow, there was no diff in engine performance.
I immediately took it to a known local service station. The guy checked all the cables and hooked the car to an ECM data module.
The module checked for any errors in the ECM but found no trouble code.
Then we noticed engine oil dripping from under the car. Put the car on a ramp and found that the oil filter had suffered a puncture. The filter will be replaced on monday.
But what id like to know is, is this the reason why the ECM light has come on and if so, how come it ain't showing any trouble code when connected to a data module?
Can any of you ECM guys help explain this?
Shan2nu
Shan2nu is offline   (1) Thanks Reply With Quote
Old 6th January 2007, 17:37   #2
nitroxx's Avatar
Thanked: 26 Times
shan2nu i wouldnt be able to pin point the reason why this is happening but would also bring to your notice that sometimes there are problems and the light doesnt come on too for e.g. ny check light doesnt show but my vtec has an issue after 5000rpm it loses power tremendously and need to tune it over..infact hooked mine upto a x431 scanner at the workshop and showed no errors on mine either bro
nitroxx is offline   Reply With Quote
Old 6th January 2007, 17:45   #3
Pankaj401's Avatar
For some fault conditions it takes multiple occurrences / drive cycles before a fault is logged in the memory.
Pankaj401 is offline   Reply With Quote
Old 6th January 2007, 17:59   #4
Rehaan's Avatar
Thanked: 25,038 Times
Good save man!
Would have been quite a disaster if you drove around with no oil.
As for why it didnt show up on the scanner...
cya
R
Old 6th January 2007, 20:40   #5
Shan2nu's Avatar
Thanked: 89 Times
Hmmm, but atleast you know something is wrong with the way the engine is performing, but thats not the case with my car, the engine revvs like nothing has happened.
Good save man!
It prob happened a few moments before the light came on. As i've never seen any oil dropping in our garage. We also checked the engine oil level, it was above the 2nd marking on the dip stick (which is good).
Do you think the light has something to do with the oil pressure? Since a certain percentage of oil is squirting out, maybe the ECM sees a diff in the amount of oil being pumped to the engine.
Anyway, once the filter is changed we'l know if the light had anything to do with it.
Shan2nu
Old 6th January 2007, 22:30   #6
Rudra Sen's Avatar
Thanked: 4,289 Times
Strange!! In fact last evening, we (me and N_C) saw the same in another Honda. It was not a VTEC though.
Old 7th January 2007, 00:39   #7
Pankaj401's Avatar
Isn't low oil pressure indicated by a seperate malfunction lamp? Only the low VTEC oil pressure in indicated by MIL.
Old 11th January 2007, 17:37   #8
Pankaj401's Avatar
Any updates on this?
Old 12th January 2007, 01:26   #9
Domnic's Avatar
first thing u guys dont need a scanner etc to check the codes, the most simple thing to do is near the ecu there is a green plastic holder with two couplers, usually hanging. The one with 2 wires is the one we need. Just short both the terminals and put the ignition on, if there is any codes the mil light will flash. If no codes are there it remains lit. Simple...
Yes as pankaj pointed out it would have recorded an error from the vtec pressure switch as honda (indian type 1 type 2) dont send a reading of oil pressure to the ecu.
here are a few error codes for you guys to self diagnose... the type 1 honda and type 2 vtec are obd 1...
example: __ = blink
__ .5 secs __ __ 1 sec __ .5 secs __ __
the above is error code 12...
0 Engine Control Module
1 HO2S Or O2S
2 HO2S Or O2S{2}
VSS{1}
3 MAP Sensor
4 CKP Sensor{2}
Vacuum Switch{1}
5 MAP Sensor
6 ECT Sensor
7 TP Sensor{2}
M/T Clutch Switch Signal{1}
A/T Shift Position Signal{1}
8 TDC{2}
Ignition Coil Signal{1}
9 No. 1 Cylinder Position Sensor
10 IAT Sensor
12 EGR System
13 BARO Sensor
14 IAC Valve{2}
EACV{1}
15 Ignition Output Signal
16 Fuel Injector System
17 VSS
19 Lock-Up Solenoid Valve
20 Electric Load Detector
21 VTEC Solenoid Valve
22 VTEC Pressure Switch
23 KS
30 A/T FI Signal A
31 A/T FI Signal B
41 HO2S Heater
43 Fuel Supply System
48 HO2S{3}
above are a few common honda codes
cheers
Domnic is offline   Reply With Quote
Old 12th January 2007, 10:52   #10
Shan2nu's Avatar
Thanked: 89 Times
Theres no update, as had to leave for Blore on Sunday night and i don't think my dad has taken the car for the filter replacement (god save the Vtec)!!!
The Honda guys should be in Hubli (service camp) around the 20th of this month. Planning to go there on a weekend and get the whole thing resolved. Anyway, i've asked my parents not to use the car unless the filter has been replaced.
Will give a complete update after the car gets serviced.
Shan2nu
Old 12th January 2007, 20:04   #11
Rehaan's Avatar
Superb info Domnic,
I have renamed the thread and rated as 5*s.
cya
R
Old 21st January 2007, 16:21   #12
Shan2nu's Avatar
Thanked: 89 Times
UPDATE :
Finally got the car checked by Honda today. It was the O2 Sensor that had a prob and needed to be replaced.
Only prob, Honda says it'll cost 16K!!!
I've been told that an O2 Sensor costs around 8K in the market, is that right?
Which company would you guys suggest (Honda uses Denso i guess).
When picking up the Sensor, should i be looking at something in specific or will mentioning the car model be enuf? The sensor on the Vtec has 4 wires going into it.
PS : The oil leakage prob was solved with a new oil filter.
Shan2nu
Old 21st January 2007, 22:29   #13
RJK
RJK's Avatar
Thanked: 16 Times
Shan,
Same problem with my Honda. O2 sensor conked off, was told 17k to replace and the service advisor himself said that it needn't be replaced immediately. So I put it off as my car moves once in a month. Do let me know if you find the sensor for a cheaper price. Anyone has any idea if I could get the sensor here in US ?
RJK is offline   Reply With Quote
Old 21st January 2007, 23:08   #14
ported_head's Avatar
Denso 4-wire O2 sensors go for about $75 online, and is Honda OEM I think. Doesn't the non-VTEC 1.5L run a single wire O2 sensor? Then it should only be about $30 or so.
Looney dealer workshops, for 15K you can get a complete Wideband O2 kit.
ported_head is offline   Reply With Quote
Old 21st January 2007, 23:13   #15
Shan2nu's Avatar
Thanked: 89 Times
The Honda chap did that and told be it was the O2 Sensor. He then fixed a new Sensor to confirm.
Somehow, at full throttle, the engine is performing extremely well. Is the busted sensor causing the engine to run richer than normal? I've been told to expect a slight drop if FE and driveability.
Shan2nu
"Check Engine" light also indicates ECU "relearning" ? anandpadhye Technical Stuff 28 19th August 2017 09:54
Suspension Prob+some more probs humyum Technical Stuff 8 16th September 2006 02:12
Engine oil probs ?? khaadu75 Technical Stuff 9 2nd July 2005 05:44
