| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #17 (permalink) |
| BHPian | Prasanth, I had a Wagon R which used to face the same problem. 1 st to 2nd was always tough, gradually I got used to the gears. When ever any of my friends drive my Wagon R, they always had the same problem. Once you get used, you can change the gears with a couple of fingers. Also On highways I face the problem thay the gears get slipped when I hit a speed breaker very fast. Usually when i drive Corsa/Accent I ignore the small rumblers, but if I do that in Wagon R the gear gets slipped and the RPM hits high ! Guys anyone faced the same problem with the Wagon R? |
| | #18 (permalink) |
| Newbie Join Date: Dec 2006 Location: bangalore
| hey abhilash , you are absolutely right i had experience this problem of gear getting slipped once when i hit a speed breaker .. Regarding the gear box of my car its getting better i took it to the dealer and he had the same feed back that after 2 nd service it will get better. After driving around bit i got used to gear box . other than that car is awesome ...perfect value for money. |
| | #19 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| I use an almost brand new Wagon R from my office and it takes a lot of effort to a) Shift into 1st gear when the car is still, irrespective of whether the engine is running or not. It goes smoothly only when you you are decelerating in second gear, and shift into 1st. b) Shift into reverse gear As if that wasn't enough, now the newest problem is that whether the aircon is on or not, there is a belt screeching noise which comes and goes. Goes usually when I depress the clutch fully. This is damn irritating and embarassing (it's louder than the music system! ). Any ideas? In my older car, this used to happen when the bloke washing my car put some water on the fan or ac belt, but it would go away after some running. This doesn't.
__________________ Operator! Give me the number for 911! |
| | #20 (permalink) |
| Newbie Join Date: Mar 2007 Location: New Delhi
| [COLOR=black]I have been driving the new wagon r vxi for 10 months now, gears felt a bit notchy earlier. Got it checked from various service centers they said the gears would settle once I have clocked enough kms on my odo. Now after nearly 10000 kms they seem to be fine now. I don’t know whether it is me getting used to the gear shift or what. I suggest not to fiddle with the gearbox or the clutch.[/COLOR] [COLOR=black] [/COLOR] [COLOR=black]Bass&trouble : Yes I have the same problem of screeching belt noise, but it is when the engine is cold and I turn on the A/C. But as the temperature increases the noise is gone. Anyways would get it checked once I go for 3rd free service which is due. Would tell you what explanation the mechanics give for this noise.[/COLOR] [COLOR=black] [/COLOR] [COLOR=black]Another problem that I face is the vulnerability of the bonnet getting dented. The front face of the bonnet I lacking strength and is getting small dents. [/COLOR] [COLOR=black] [/COLOR] [COLOR=black]Also, as i have the VXi version with electric door mirrors somebody tried to steal it, although was not able to do so but in an attempt broke the cover below the mirror (which covers the nut bolt) . I'm not able to find it anywhere as it is different in LXi model and maruti guys tell me the whole assembly will have to be changed costing 7500 /- :( No clues what will I do now. Ant suggestions would be a help.[/COLOR] |
| | #21 (permalink) | |
| Newbie Join Date: Feb 2008 Location: Bangalore
| Quote:
My first post here, if any mistakes please excuse me. As mentioned above, regarding the shifting problem, I have noticed a some what similar problem after starting the vehicle in the morning, run for a few kilometres and there is no problem. shifting as mentioned in the new wagon r, is perhaps similar with all wagon r vehicles sold till now. mine is lx 2005 model bought 4 months back from a true value outlet. A minor suggestion from me. Whenever you first take your vehicle out, try shifting first to reverse and then the first gear to proceed. it worked in my vehicle. just give a check. even though its like compromising with problem, but what can be done when all the vehicles are having the same. if not satisfied drop in to the dealership and have your vehicle checked and please let us know what are the results. | |
| | #22 (permalink) | |
| Super-Admin | Quote:
__________________ GTO Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
| | #24 (permalink) |
| BHPian Join Date: Apr 2007 Location: Hyderabad
| Problem#1: My 16-month old Wagon-R complted 25000 km. Last month, I drove to Chittor from Hyderabad to attend my friend's marriage and returned almost same day (total 1300 km in 30 hours). When I almost reached Hyderabad, the gears were not engaging at all. After one hour, I tried to engage the reverse gear, and was able to do with a hard push, and was able to slot the gears with very difficulty. Drove the rest of 50 km without changing the gears much. The next day (after 20 hours), I drove the car without any gear-shifting problems for a distance but again the problem occured while taking the car to the Service Station. The problem did not occur at the service station, and they told me everything was fine. When I asked what could be the problem, is there any problem with gear box, they said nothing, and if the pressure plate wears out, the problem should persist, which is not the case with my car. They said every thing will be fine, and if the problem recurs we will check the gearbox then. I drove the car in the city for almost a month, and never faced the problem again, though the gearshifting is a bit rought than previous. Now I am planning to go for a long-drive next month, I am skeptical that this problem may recur and what if it occurs in the drive? I would like the experts to give me a vlauble suggestion. ![]() Problem #2: I have changed the rear axle once due to slight bend in the rear axle. Now the car sways a lot, like a boat on water, with even slight uneven surfaces. The service people say everything is fine, but I know something is not exactly right with the suspension (I have checked wheel-balancing as well as wheel alignment). Would like to know why this is happening. ![]() Thanks in advance.
__________________ '03 HH Splendor - 28,000km '06 Kinetic Blaze - 10,700km '07 Kinetic Flyte - 3400km '06 HH Zma - 18,700km '07 WagonR Lxi - 24,900km |
| | #25 (permalink) |
| BHPian Join Date: Dec 2007 Location: Gurgaon
| Sorry I am using your thread to address my "problem" as my also revolves around the gear box. I have a Dec 2006 WagonR completing 32000kms. I notice that to engage the gears I really have to almost shove the stick hard. Otherwise sometimes it doesn't engage properly which is accompanied by the horrible mechanical grinding noise. Also when I try to engage the reverse gear after the car has been parked (i.e. parked in neutral and switched off) it is always accompanied by that grinding noise as if it's being told to do what it's not supposed to do?? I have been driving (legally) for more than 12 yrs and this car is the only one which gives this "problem". Dont remember this problem which my old Zen or my dad's OHC VTEC which has done more than 100000kms.
__________________ WagonR Vxi 2006 (2nd hand) Zen Lx 2002 (2nd hand - sold) Honda Prelude Si 1992 (2nd hand - sold) |
| | #26 (permalink) | |
| Quote:
__________________ '03 HH Splendor - 28,000km '06 Kinetic Blaze - 10,700km '07 Kinetic Flyte - 3400km '06 HH Zma - 18,700km '07 WagonR Lxi - 24,900km | |
| Thread Tools | |
Similar Threads | ||||
| Gear Box Heating OHC VTEC | malcolm | Technical Stuff | 12 | 19th November 2007 11:40 |
| HELP...!!! Close-Ratio Gear BOX for RX 135 5spee | malvechaitanya | Motorbikes | 0 | 1st August 2007 11:15 |
| Your choice of Gear Box: Tall or Short? | turbo_c | Technical Stuff | 37 | 23rd June 2007 03:06 |
| A few problems with New wagon R. Help needed ! | akhilesh | Technical Stuff | 5 | 31st May 2007 15:33 |
| 3 Box Swift!!!! Wagon R+!!!! And Wat Else | speedsatya | The Indian Car Scene!! | 7 | 25th July 2005 23:06 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
how DID you manage to squeeze in 7 people in a wagon r.
