Thread Tools
Old 9th January 2007, 17:28   #1 (permalink)
Default Wagon R Gear box problems
Hi Team-bhpn's,
This is my first post here, I got a new wagonr vxi last week . After driving around a bit i feel that the gear box is not very refined. I have problems shifting reverse gear and shifting from first to second at times . I have been driving a santro before this.
I am not sure this problem is specific to my car or its a know issue with the new wagonr's . Is there any body here who is facing the same . I just want to make sure about this before i go and speak to the dealer.
Any help would be appreciated.
Thanks in advance.
prashantk007 is offline   Reply With Quote
Old 9th January 2007, 18:10   #2 (permalink)
extreme_torque's Avatar
@prashant... Its a problem with the car, the gearbox in the new wagon-r is the worst in any maruti, infact the worst in its class.
extreme_torque is offline   Reply With Quote
Old 9th January 2007, 18:11   #3 (permalink)
Sush's Avatar
I sometimes face the same problem in my Xing. Its occurs mostly when the enjine is cold.
You can get the clutch inspected.
Sush is offline   Reply With Quote
Old 9th January 2007, 19:38   #4 (permalink)
CrAzY dRiVeR's Avatar
The wagonR gearbox is not the best in class... However, i feel that the gearbox gets better after some running...
My wagonR has run 28k kms, and the gearbox is good now... Not as good as swift or other cars... But, doesnt gives problems too...
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
CrAzY dRiVeR is online now   Reply With Quote
Old 9th January 2007, 20:01   #5 (permalink)
partypest's Avatar
i belive you shoud take it up with the maruti guys, i had the same issue the gear box was sluggish and would get stuck, would need to release the clutch and try again!!!!!!!!!
partypest is offline   Reply With Quote
Old 10th January 2007, 21:19   #6 (permalink)
Thanks guys for confirming this.
Old 11th January 2007, 04:51   #7 (permalink)
mithun's Avatar
Chill out.....Dude, learn to live with the WR gearbox !!!
The un-refined gearbox is the trademark of all WR's.
But recently I had driven a WR which had cloaked about 44K KMS and the gear-shifts were comparatively better compared to the brand new ones. After about 10,000 KMS your gearbox will become smoother than the current setup.
Other than this, the WR is a perfect car in all respects.
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 17th January 2007, 14:19   #8 (permalink)
ramki067's Avatar
Planning to purchase the New WagonR. This article seems to be a wake up call before buying and being ready for it. Thanks folks. Anyway i love its practicality.
ramki067 is offline   Reply With Quote
Old 17th January 2007, 17:16   #9 (permalink)
Yup... Its a wake up call all right...
The gearbox is not at all perfect, but will get better after sometime...
But, the gear ratios, i feel are the best in any hatch... it just matches the engine nature superbly... I had a ride to the hills last week, and the car pulled steep inclines in fourth gear , at speeds of 40 around... (Where the roads were good)
I was really surprised by the way in which the car handled the hills... We had 7 people in the car including 1 kid. and climbing the inclines in fourth gear was something i never expected...
Only other disadvantage i felt is that the front right A piller is a bit too thick to take the corners aggressively... Other than these two small disadvantages, am totally in love with the car...
__________________
Thats why i'm here!
Old 19th January 2007, 05:56   #10 (permalink)
mithun's Avatar
I've never thought that WR was such a good worker. Pretty impressive !!!
And what was the state of suspension under a load of 7 people ? Does it scrape the ground due to the weight ?
__________________
Old 19th January 2007, 08:59   #11 (permalink)
Team-BHP Moderator
Yes the gear box is a big irritant. I have particular problem with the reverse gear...other than that, its a good car.
__________________
What goes around comes all the way back around
DCEite is offline   Reply With Quote
Old 19th January 2007, 13:10   #12 (permalink)
Its 7 people, including a kid...
The suspension, didnt bottom out cause i took the potholes real carefully... I had recently swapped to tubeless tyres on stock steel rims... The rims could get bend on a big impact... So, i was real careful on potholed roads...
__________________
Thats why i'm here!
Old 20th January 2007, 01:40   #13 (permalink)
hellspawn's Avatar
how DID you manage to squeeze in 7 people in a wagon r.
__________________
If you try,and succeed at first,
try not to look astonished.
hellspawn is offline   Reply With Quote
Old 20th January 2007, 05:08   #14 (permalink)
Well... Its 7 inlcuding a school kid...
Was a real real squeeze (I was the driver... So... I didnt have any problem.. he he)...
__________________
Thats why i'm here!
Old 20th January 2007, 09:43   #15 (permalink)
vid6639's Avatar
Prashanth as everyone has already told that the WagonR gearbox is not very refined. however if it's unusually hard. you could get this checked up.
Also since your car is new and not run in the gearbox hasn't opened up yet and will be on the harder side.
You can wait till the 1000kms service to see if it improves.
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Thread Tools
Gear Box Heating OHC VTEC malcolm Technical Stuff 12 19th November 2007 11:40
HELP...!!! Close-Ratio Gear BOX for RX 135 5spee malvechaitanya Motorbikes 0 1st August 2007 11:15
Your choice of Gear Box: Tall or Short? turbo_c Technical Stuff 37 23rd June 2007 03:06
A few problems with New wagon R. Help needed ! akhilesh Technical Stuff 5 31st May 2007 15:33
3 Box Swift!!!! Wagon R+!!!! And Wat Else speedsatya The Indian Car Scene!! 7 25th July 2005 23:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
