Old 9th January 2007, 20:46   #1
men_in_jean's Avatar
Lightbulb Lancer Seat height adjustment????
Hi all,
I Really wanted to know whether Lancer has an adjustable seat height. Read it from specifications that it is there, but I can't find one in my Lancer GLXI or is it not working I don't know. Could anyone help???
men_in_jean is offline   Reply With Quote
Old 9th January 2007, 21:11   #2
Vid6639's Avatar
Thanked: 19,361 Times
it's there on the right side of the front drivers seat. you have to pull it up to increase the height. it's like a lever.
Old 9th January 2007, 21:39   #3
elf
elf's Avatar
Thanked: 9 Times
The height adjustment lever's on the right side of your seat - closer to your knee as opposed to your bum.
It's quite long & tends to get in the way when you seat yourself. It may be quite tight & you may have to exert considerable force to move it if you've never done so before.
elf is offline   Reply With Quote
Old 9th January 2007, 22:46   #4
wolfinstein's Avatar
I don't think GLX had the option to raise driver seat, it was only there in SLX or SFX..at least when we bought the car 2001
wolfinstein is offline   Reply With Quote
Old 10th January 2007, 01:11   #5
devarshi84's Avatar
Thanked: 118 Times
If I remember correctly there was a version of lancer which had roll down windows and no seat height adjustment.
But for all other lancers the seat height adjust is there. I somehow dont like the lever though. It feels as if it will break.
devarshi84 is offline   Reply With Quote
Old 10th January 2007, 18:12   #6
My car has power windows. Yes there's a lever which is vertical but not able to pull it up. I feel it'll come with my hands.. I am able to move it front or back. I think that is the one and the problem is with the lever itself.
Old 10th January 2007, 20:35   #7
Vid6639's Avatar
Are you by any chance a little on the heavier side? no offence but that could be the reason the lever doesn't move. try getting up from the seat and lifting the lever.
horizontal means fully low and vertical means fully high.
Old 11th January 2007, 00:36   #8
devarshi84's Avatar
Thanked: 118 Times
Let me try to help you out here. AS far as I remember you need to pull the lever out and pull it up to raise the seat. try it. it wont break but then dont exert too much pressure.
Old 11th January 2007, 14:25   #9
Ho.. Im a total of 60 Kg
Is it possible to fit seat height adjustment as an accessory/aftermarket? CrAzY dRiVeR Modifications & Accessories 38 26th March 2016 20:24
Low seat height virgopal Technical Stuff 9 15th October 2012 16:16
Height adjustable head-rest for rear seat Podilam Modifications & Accessories 4 14th December 2009 16:16
My Height and Driver's seat distance webjunk Technical Stuff 8 6th March 2007 21:46
