Thread Tools
Old 9th January 2007, 23:57   #1 (permalink)
BunnyPunia's Avatar
Default Disengaging hand-brake / gears from underneath the car
I have heard that the car lifting guys, who come with the cops in truck cranes to lift illegally parked cars are able to disengage the handbrake and/or gears in a matter of seconds from underneath the car and then lift it and take it away to the station. Is it true? If yes, then even thieves can do the same, right? I now pull the handbrake all the way up, lock the steering to one way and slot the gear in reverse when parking in a new/unfamiliar area.
BunnyPunia is offline   Reply With Quote
Old 10th January 2007, 09:22   #2 (permalink)
mclarenracer's Avatar
yes it is true, i have seen it done in delhi, areas like gaffar market and kamla nagar and all the car it is done on are maruti- 800, alto and zen atleast from what i have seen. it was shocking when i saw it for the first time around 10 years ago in karol bagh.
mclarenracer is offline   Reply With Quote
Old 10th January 2007, 10:40   #3 (permalink)
I am not sure they can disengage the gear from underneath. They usually circumvent that by towing the car from the front end. Most cars are front-wheel drive and the rear wheels rotate freely.
Bomi is offline   Reply With Quote
Old 10th January 2007, 11:10   #4 (permalink)
Jaggu's Avatar
they cut the hand brake cable and tow lifting front wheel
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 10th January 2007, 12:30   #5 (permalink)
normally_crazy's Avatar
Cutting the cable is legal ?? Maan this is scary.....how can they do that ? That can amount to robbery.
TOTALLY O T
I heard if a towing van is taking away your car , you can stop it if the number plates are in white background as only vehicles with yellow background on number plates are allowed to tow the cars. Is this true ?
normally_crazy is offline   Reply With Quote
Old 10th January 2007, 13:08   #6 (permalink)
drifter's Avatar
They use the handbrake in the cabin...the cars are unlocked first using various means. So no cutting of handbrake cables...if that were the case, many people would be dragging them to the courts.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 10th January 2007, 15:51   #7 (permalink)
Default Starting vehicle with steering turned to one end
Starting a car that has power steering with the steering turned to one direction is harmful for the vehicle, puts extra load whilst starting.
autoenthusiast is offline   Reply With Quote
Old 10th January 2007, 20:53   #8 (permalink)
gd1418's Avatar
Infractions: 0/1 (4)
Amby & fiat's gear could be disengaged from underneath since they used linkages as they used side levers for engaging gears. The floor shift version sits right on top of the gear box, hence no linkage. So, it is not possible to disengage the gear from underneath.
On the contrary, since most of the recent vehicles are front wheel drive, they are towed with their nose up..!!
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Old 12th January 2007, 06:19   #9 (permalink)
mithun's Avatar
So what about Omni, which is a rear-wheel drive ?
__________________
Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly.
Old 12th January 2007, 09:40   #10 (permalink)
Jaggu's Avatar
bangalore atleast twice i have seen these private guys cut the cable, once in koramangala and once near cmh road :(
if u park in toe zone, dont apply hand brakes
__________________
Thread Tools
i10 hand brake issue Ajaybiz Technical Stuff 25 28th January 2008 13:37
Is it possible to release the hand brake from outside the car? Stig Technical Stuff 33 15th September 2007 22:06
Hand Brake - Do you use it everytime ? mithun Technical Stuff 107 13th September 2007 18:09
Hand Brake issues Knight Rider Technical Stuff 17 28th March 2007 11:11
Hand Brake Operation revharder Technical Stuff 15 1st June 2006 01:23
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
