Thread Tools
Old 11th January 2007, 03:48   #1 (permalink)
Default Esteem handling issues.
Hi Guys,
Whenever my esteem goes beyong 160 (speedo readings), car's handling goes for a toss. To be precise, it sticks to road, it doesn't waver but the steering gets weighless.
Is this is a normal Esteem behaviour?
What can I do to rectify it?
Stig is offline   Reply With Quote
Old 11th January 2007, 10:10   #2 (permalink)
willy's Avatar
That is very normal in the Esteem, you can actually try upgrading the rubber and the alloys. I am yet to do that.
willy is offline   Reply With Quote
Old 11th January 2007, 10:32   #3 (permalink)
esteem_lover's Avatar
What is your tyre size ? if it is stock, try upgrading to 175/70. what model is your esteem ?
__________________
Advertisements contain the only truths to be relied on in a newspaper. - Mark Twain
Old 11th January 2007, 10:42   #4 (permalink)
Team-BHP Moderator
theMAG's Avatar
The Esteem has a nervous chassis. Its not well weighted enough to handle high speeds comfortably. Upgrading rubber would help to an extent, but dont expect any rally-style road holding.
__________________
If you lose your temper, you’ve lost the argument
Old 11th January 2007, 10:56   #5 (permalink)
But seriously, for your own safety, do not push the esteem beyond 140.
__________________
Old 11th January 2007, 11:16   #6 (permalink)
vikram_d's Avatar
Add a strut brace for your front suspension along with slightly heavier alloys. Should solve the problem. I did this on my esteem and absolutely no problems whatsoever. A set of stiffer springs will also help in the front.
__________________
To be or not to be...that is the question.
vikram_d is online now   Reply With Quote
Old 11th January 2007, 12:41   #7 (permalink)
narayan's Avatar
160!!!!! shocked to hear u tested it all the way to 160 ...i owned an esteem before i bought a ohc1.5
never had the guts to push beyond even 130...have felt the lightness ur mentioning even at those speeds..
160 is insane on the esteem..for ur own safety - pls do try this !!
narayan is offline   Reply With Quote
Old 11th January 2007, 12:42   #8 (permalink)
narayan's Avatar
pls read that as "DONT try this "
Old 26th January 2007, 09:23   #9 (permalink)
abhaybakshi's Avatar
Stig,
Request you not to drive your Esteem over 110. You may be best driver in the world and Esteem may handle this speed easily..but tyres can burst at such speed and that is the biggest problem. Actually indian roads are not meant for 110 + speeds....
__________________
- Abhay
You truly love your car if ...
You visit her frequently just to check if she is sweating in the sun
I do...
abhaybakshi is offline   Reply With Quote
Thread Tools
Esteem AC Issues (Now Resolved) esteem_lover Technical Stuff 54 14th July 2008 12:53
Some issues with my esteem amohit Technical Stuff 4 27th November 2007 13:03
do alloys effect handling?? noidaboy Tyre & Alloy wheel Section 20 15th March 2007 15:30
Change in mileage and Handling msk_kapoor Technical Stuff 6 23rd April 2006 22:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
