Old 12th January 2007, 10:42   #1
Default Streeing problem in Santro.
Hi Everyone,
I own a first generation Santro (1L Year 2000 model) which has done almost 45 K. For a few days I am having a problem with the steering of the car.
If I drive car with the streeing in the straight position, car tends to move to the left. (I have got down and cheked the tyre and they are pointing to the left even with the streeing at the centre straight position)
Is this the problem with the whell allignment or someting more serious?
BHpians please advice.
Thanks,
Amit.
F1amit is offline   Reply With Quote
Old 12th January 2007, 10:58   #2
Jaggu's Avatar
Thanked: 8,693 Times
get the car steering system checked at a dealer and get ur wheel alignment checked.
did this symptom started one fine day or was gradual, any garage work done just before?
is it a slight pull or heavy?
should be just alignment or worse cum worse one of ur tie rod ends gone kaput, best give to a dealer or garage and checked
Old 12th January 2007, 12:37   #3
rks
rks's Avatar
What exactly do you mean by "with the steering in the straight position"? Looks to me like you would like the car to go straight if the steering wheel is in a certain position, but the car is going to the left. So what I suggest is to straighten out your wheels so that the car is going straight, and then get the steering wheel fixed in the position that you want (I think you can remove the wheel and then fix it back in the new position that you want). The play should also be adjusted correctly -- maybe you have too much play.
Or else simply note the position of your steering wheel when the car is going straight -- that is your "straight position" of the steering wheel, if you can live with it. Maybe the steering wheel is not screwed on tight enough and so the position is slowly changing -- you can get this checked.
Old 12th January 2007, 19:46   #4
Shan2nu's Avatar
Thanked: 89 Times
Don't worry, it's a simple prob (have it on my Vtec). All you need to do it remove the steering and move it into the left grove (depending on the degree of misallignment). The steering bolt is usually found under the manufacturers logo, on the steering. If it still doesn't straight'n up, you'l have to allign the wheels to get an accurate result.
BTW, does your car move to the left if you take your hands off the steering? If so, get the wheels alligned.
Shan2nu
Old 16th January 2007, 23:50   #5
I had the same problem that occured on my santro recently. Came up after I got the wheel alignment done. The steeering was perfectly aligned before, after the wheel alignment, the steering centre position was not in sync with the front wheels.
The mechanic turned the steering to get the wheels in the straight position and then removed the steering and fixed it back with a couple of degrees turn to get it straight. Should take more than a few minutes to get it done.
autoenthusiast is offline   Reply With Quote
A story of 3 workhorses: 2 Santro's and a Manza, Edit: Santro sold, Manza at 100k+ amit1234singla Long-Term Ownership Reviews 115 10th August 2014 21:53
Santro Eco or Santro GL (Any Review/Comments Eco) ForeRunner Hatchbacks 4 11th December 2008 18:56
One question about tyres of Old Santro and New Santro Xing DDGuy Tyre & Alloy wheel Section 5 12th November 2008 13:35
Old Santro Vs New Santro eRLX: Worth a change? ms_rana Hatchbacks 20 5th July 2006 16:22
