Old 13th January 2007, 04:12   #1
chetanhanda's Avatar
Thanked: 43 Times
Default Disconnecting power steering pump..
Guys, is it ok to disconnect the power steering pump ?
Is it as simple as removing the belt which drives the pump ?
Main concern is - will it be even more difficult to drive than a originally "non power steering" version of the same car.. ?
chetanhanda is offline   Reply With Quote
Old 13th January 2007, 04:18   #2
khanak's Avatar
Thanked: 128 Times
uhhm...why would you want to do that in the first place?
khanak is offline   Reply With Quote
Old 13th January 2007, 11:16   #3
Pankaj401's Avatar
Should be. Just that you would loose all the hydraulic assist it provides.
You have to loosen the tensioner bolts and then remove the belt. Done it myself once. Pretty easy to do.
Yes.
Pankaj401 is offline   Reply With Quote
Old 13th January 2007, 11:22   #4
vikram_d's Avatar
Thanked: 937 Times
A disengaged power steering will be a lot more harder to steer than a non power steering version.
Old 13th January 2007, 13:25   #5
flipsyde's Avatar
Thanked: 62 Times
chetanhanda..... its going to make the steering much harder than the non-PS model of the same car. i have driven an esteem where the pump leaked out all the oil in it and it was terrible...... i found it almost impossible to reach the service centre! i would strongly advice aganist driving without the PS.......
flipsyde is offline   Reply With Quote
Old 13th January 2007, 13:43   #6
elf
elf's Avatar
Thanked: 9 Times
Your power steering pump may also drive other hydraulic systems (if any) in your car. Don't think it's very advisable to do this.
elf is offline   Reply With Quote
Old 13th January 2007, 15:32   #7
Thanked: 647 Times
Your car will be almost twice as difficult to drive and your entire steering box will get screwed beyond repair.
jyobeb is offline   Reply With Quote
Old 13th January 2007, 17:01   #8
Pankaj401's Avatar
What are the other systems that you suggested? I couldn't think of any.
Can you please explain how would it damage the steering box?
I think there would not be any damage to any part of steering system except your musvles.
Old 13th January 2007, 17:49   #9
elf
elf's Avatar
Thanked: 9 Times
Well, Pankaj401, in our old Mercedes 123 (OM616), the power steering belt also used to drive the vaccuum system which was used for central locking, the heater & a couple of other things (can't remember now), apart from the power steering itself.
Since chetanhanda hasn't mentioned the vehicle he plans to do this on, I gave him a general note of caution.
Old 13th January 2007, 18:51   #10
Pankaj401's Avatar
Elf you mean that the belt used for power steeing pump might also be used for other systems. What I was talking about was the pump.
Old 13th January 2007, 19:05   #11
In an Indica ( diesel) , I know that the same belt is used to drive and Power steering pump as well as the alternaor. The vacuum pump used for break assist is integrated with the alternor. Hence removing the power steering belt will also result in loss electrical power and breaking .
rejika is offline   Reply With Quote
Old 13th January 2007, 20:40   #12
Mpower's Avatar
Thanked: 1,682 Times
Removing belt only cuts out hydraulic pressure. The rack still has slave cylinder with piston and seals which cause friction.
If you want true non assist steering, you have to change the rack to the new one or modify it by removing the piston and seals.
Vacuum pump is used only on diesels.
Old 14th January 2007, 10:29   #13
Thanked: 43 Times
guys I think I got the point ..
thanks a lot...
I wanted to do that becoz i was planning on a long trip over the long weekend and did not want to leave the car at the dealership for getting the power steering fluid flushed, etc ..didn't have time for that. So I thought I could juist get it disconnected and have a closer look at it later on.
But I managed to get all that pump, fluid flushed belt checked in time.
and hey Pankaj , i have a separate belt driving the power steering only.
the car Im referrring to is a honda
Old 17th January 2007, 05:55   #14
mithun's Avatar
Thanked: 49 Times
Recently I've seen a Zen LXi whose PS was removed at MASS and I found that it drives almost like the Zen LX.
The rack was a new one & piston & seals were removed.
But I don't know whether this modification will create any problem in the future.
Ford Ikon Power Steering Pump Archish Technical Stuff 16 9th July 2013 20:41
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Optra Power Steering Pump Problem jinu_joseph Technical Stuff 6 15th August 2009 09:20
New Honda accord power steering pump problem autozoniac Technical Stuff 3 17th March 2009 01:01
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
