Old 14th January 2007, 00:06   #1
Thanked: 54 Times
Default How does one find a vaccum leak in a carburettor?
Hi Everyone,
I have a carb'ed m800, and I suspect the carburettor has got a vaccum leak somewhere which is making the mixture lean and the engine knock when revved. It makes the idling kind of rough and the car jerks when the accelerator is released.
I did inspect the pipes that are connected to the carburettor but coudnt find any that was obviously looking cut/broken.
How do i check and find out where the carburettor is leaking ?
Thanks in Advance,
Amit
techn0l0gist is offline   Reply With Quote
Old 14th January 2007, 00:54   #2
tsk1979's Avatar
Thanked: 16,418 Times
Vaccum leak could be anywhere in the fuel system, not just the carb. I suggest you take it to a good mechanic and they can try to find it.
The easiest way is to use Smoke machine, but I doubt its done in India.
Some sites to help your out:
http://peugeot.mainspot.net/tips/diag_proc.shtml
Engine Vacuum Leaks
Fuel leak from the carburettor (Royal Enfield CI) 8090guy Motorbikes 9 24th October 2016 11:45
Which Black & Decker Vaccum Cleaner for Car lambuhere1 Modifications & Accessories 1 27th November 2007 13:48
Portable Vaccum Cleaner...is it worth? raja748 Modifications & Accessories 22 17th October 2007 13:27
Petrol leak from Carburettor - Mach 500 Ketan Technical Stuff 5 12th July 2007 13:19
