| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Mar 2006 Location: Ahmedabad
| Hi! I am an owner of Elanta CRDi which was bought on April, 2005 and since then it has clogged 52000 kms. But during its life span it has encountered numerous problems. Whenever i drive it at around 170kmph, engine check light switches on and the engine looses its power. At first the problem was traced to the exhaust system and it was replaced. Then the same problem happened again, this time the car refused to go over 40kmph in the second gear, 60kmph in the third, 80 in the fourth and 120kmph in the fifth gear. The problem of engine loosing power was now traced to failed turbo. So the turbo was replaced. Since then the car was running fine. And once suddenly the problem cropped up once again and this time there was thick Grey gas coming out of the exhaust whenever the car is running or idle. I contacted the dealer and gave my car for troubleshooting, but this time they also traced the problem to a fault turbo charger. The turbo which have been fitted earlier had failed in just 6 months and 10000kms!!! And after fitting the second turbocharger, though the car is under warranty, the car is still loosing its power at high speeds and still continues to emit dark Grey exhaust gas. Please help.....What could be done about this problem. Is there any way to solve it... |
| | #2 (permalink) | |
| Team-BHP Support ![]() | Quote:
__________________ I love the whoosh, but i miss the bellowing | |
| | #3 (permalink) | |
| BHPian | Quote:
![]() Even for a car like Elantra???........ even after paying 10lakhs??? Is that the case with the all the turbocharged cars?? or is it only for the deisels?? And what about cars like MB, BMW,.....???
__________________ kkr, unofficial hyd tbhp meet co-ordinator ....HINDUISM ........JAINISM .......BUDDHISM ......SIKHISM ........ISLAM CHIRSTIANITY | |
| | #4 (permalink) | |
Note - smokey turbo - poor seals, no power - failed bearings
| | #5 (permalink) |
| Distinguished - BHPian ![]() | Typically this would be because of non supply of oil for lubrication of the turbine bearings, or excessive exhaust temps which I do not think is true in your case. best way to check would be to remove the oil supply line to the turbo and check for oil flowing out and its pressure on idle.
__________________ Learning is a continuos job that keeps me busy. |
| | #8 (permalink) | |
__________________ The difference between the men and the boys....................is the speed of their toys. | |
| | #10 (permalink) |
| Newbie Join Date: Jan 2007 Location: Greenville, SC , USA
| yes its a clogged oil feed line to the turbo, normally when at a dealer replaces the any part in your case the turbo tries to just keep the cost low so i'm pretty much sure that the turbo was only replaced not the hoses or feed lines try replacing the feed lines and try flushing your engine oil will some kind of cleanin agent ment for your car that should take care of the shaving and the dirt that is in the crank case and oil pump area and will stop the feed lines to get clogged i hope this helps hit me up and let me know how it goes |
| Thread Tools | |
Similar Threads | ||||
| Elantra Petrol vs Elantra CRDi | palani81 | Sedans | 1 | 24th October 2006 13:59 |
| Elantra GT vs Elantra Crdi(Was skoda vs elantra) | azifali | Sedans | 39 | 17th August 2006 12:56 |
| elantra crdi gtd vs elantra crdi (leather pack) | super_700a | Sedans | 3 | 10th August 2006 07:38 |
| Suggest me, Elantra CRDi or Elantra GLS | hsmraj | Sedans | 16 | 11th April 2006 02:28 |
| Elantra CRDi v/s Used Elantra CRDi v/s New Ford Fiesta 1.4 TDCi | lamborghini | Sedans | 36 | 29th January 2006 23:03 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
