Thread Tools
Old 16th January 2007, 14:47   #1 (permalink)
Default 8v esteem engine to 16v dohc
all suzi geeks please help me.
Is it possible to convert the 8v g13a sohc engine to a 16v g13b dohc engine and run it with a carb setup with out hiccups?
please list out the things that would have to be replaced if this is possible.
if the above is not possible can the 16v esteem engine run on a carb setup with out hiccups.
any information about contacts to buy/ship the parts would also help.
finally any information about the pricing would also help.
cheers.
__________________
heavy_foot is offline   Reply With Quote
Old 16th January 2007, 17:26   #2 (permalink)
akshay1234's Avatar
why dont you just buy the g13b engine.. i think a fellow member jesal has put a g13b engine in his zen.. i guess you could contact him for more info.
akshay1234 is offline   Reply With Quote
Old 16th January 2007, 20:50   #3 (permalink)
i think jesal has swapped a g13a sohc 8v..isnt the g13b a dohc engine..correct me if i am wrong guys.
__________________
Old 16th January 2007, 20:53   #4 (permalink)
flipsyde's Avatar
heavy foot i think the best person to talk to in this regard would be viper. if i remember correctly he had dropped a dohc 16v engine into an esteem a while ago....... and it worked without uch to complain about.
PM him for details.
__________________
An architect's most useful tools are an eraser at the drafting board, and a wrecking bar at the site - Frank Lloyd Wright
flipsyde is offline   Reply With Quote
Old 16th January 2007, 20:54   #5 (permalink)
flipsyde's Avatar
also is there any reason for you favouring carb version instead of the MPFI??
__________________
Old 16th January 2007, 23:22   #6 (permalink)
A few amateur queries
1) 8v engine, i guess i'm wrong, but i thought that every cylinder has 4 valves, and esteem engine have 4 cylinders. So how come 8v
2) SOHC and DOHC, i know it has something to do with the cam shafts, but whats the difference and which provides better performance. Which is in the Swift engine?
micraft is offline   Reply With Quote
Old 17th January 2007, 00:42   #7 (permalink)
viper had a twin cam setup in his esteem...i am talking about converting the esteem engine to a dohc...not sure if anyone has done it here or if its possible.
favouring the carb is only because as far as i understand its a lot more simpler and cost effective...and can be tuned and reparied at the local road side garage since the car is going to be used in a small town.
please leave in your valuable inputs.
__________________
Old 17th January 2007, 08:01   #8 (permalink)
viper's Avatar
Yes I had a Twin Cam Carb Setup on my ex Esteem. There are at least 5 Zens running the setup to the best of my knowledge in Mumbai. 2 are running on Carbs while the other 3 are MPFI. Its a fairly straight forward engine swap in either M1000/Esteem/Zen or Swift.
Only thing you need to worry about is the setup and carb matching/jetting & balancing. Other than that its like maintaining a regular car.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 17th January 2007, 11:48   #9 (permalink)
okie guys correction...just found out the sohc is g13b...then what is the dohc engine..is any one running a dohc setup here.
Has any one tried a carb setup with a 16v ? can it be done?
__________________
Old 17th January 2007, 12:49   #10 (permalink)
hey guys has any one here ordered for parts from this website..
Suzuki Swift Racing Parts - Performance Parts by Suzuki Racing Development
__________________
Thread Tools
Enthusiast maintained 2001 16V MPFI Esteem LX for sale turbo_c Shifting gears 0 24th October 2006 13:20
Converting Esteem SOHC to DOHC MustangMan Modifications & Accessories 8 14th December 2005 11:34
Twin Cam 16V Engine 1.3L Suzuki Engine for sale viper Shifting gears 8 6th July 2005 15:58
Twin Cam 16V Esteem viper Modifications & Accessories 19 11th May 2005 19:47
1.3l DOHC 16v Esteem viper Modifications & Accessories 12 21st April 2005 16:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
