Old 19th January 2007, 15:10   #1
Default Higher Oxygen %age in the exhaust gas
Hi! Techies, I own a 1997 carb zen.The mixture screw is turned for lean.Yesterday i went for pollution check,the guy there told me that my exhaust is showing higher O2 %age (2.93). He told that it should be near zero and he also told that it will damage my engine in long run.
Kindly give some expert comments.
P.S. My car is giving an average of 16kmpl in city and 21kmpl on highway.
buddy is offline   Reply With Quote
Old 19th January 2007, 20:57   #2
gd1418's Avatar
Thanked: 656 Times
And they are ever trying to reduce the emission to reduce pollution..!! Strange.., I thought CO2 or CO caused pollution. But Oxygen causing trouble is something unheard off.
Govt. must ask and encourage Maruti/Suzuki to revive the '97 carb Zen so that more O2 is pumped in the atmosphere resulting in cleaner air. What is a little harm to the engine. It is for national/global betterment..
Old 19th January 2007, 21:41   #3
Psycho's Avatar
Thanked: 95 Times
What he actually meant to say ws that you are running extremely lean and it might cause your engine to knock / sieze. Better get it retuned.
Old 24th April 2007, 22:55   #4
nura's Avatar
Although it seems illogical, it is true that pollution check guys will not issue a certificate if oxygen content in exhaust gas is too high. High oxygen levels may indicate a leak in the exhaust system & it might be a good idea to get this checked out.
nura is offline   Reply With Quote
Old 25th April 2007, 03:59   #5
Mpower's Avatar
Thanked: 1,687 Times
Well your leaning efforts are really working then. When there is not enough fuel to burn with the air, o2 comes out unburnt.
Keep an eye on the temp gauge. As long as you are not operating under high loads you should not overheat.
Of course, pumping out O2 is not bad for teh environment, but your Nox might be high also due to the leaning.
Old 25th April 2007, 04:37   #6
chetanhanda's Avatar
Thanked: 44 Times
If there is a leak worth bothering about the exhaust note may change to indicate this..
If I saw more oxygen content I would say you are running lean and running to hot and have a more critical problem than a leaking exhaust.
Yours is a carb fuel delivery system so you wont have to worry about too many sensors etc, suggest you get your carb retuned to run slightly more richer to avoid running a lean AFR.
chetanhanda is offline   Reply With Quote
Maximum Temperature For Exhaust Gas anarchy_99 Technical Stuff 15 15th April 2013 11:18
WANTED: Oxygen sensor (Lambda probe) for OHC VTEC gbpscars Modifications & Accessories 5 7th July 2009 14:30
Whats the maximum exhaust gas temperature for a Diesel turbo scorpio MB-Sting Technical Stuff 0 24th March 2009 17:25
Read about how Oxygen Sensors work Rehaan Technical Stuff 2 13th March 2006 02:51
Oxygen Sensor - Malfunction Need Help Firestarter Technical Stuff 15 23rd February 2006 07:06
