Old 5th February 2007, 02:22   #91
elf
elf's Avatar
Thanked: 9 Times
Thumbs up Good job...
Congrats Sam, on a job well done.
My car spa's gonna happen later - am tied up with life right now & need her to be around, not getting her freakin' toenails buffed at some overpriced salon.
And what's all this negative vibe I'm getting?! People keep talking about shoving me into engines & gearboxes... for the last time,
I AM NOT A LUBRICANT!
elf is offline   Reply With Quote
Old 5th February 2007, 02:29   #92
Sam Kapasi's Avatar
Thanked: 1,473 Times
Originally Posted by vid6639 View Post
Sam, is it possible to give the specs of the mobil1 oil whats the grade? and also the price per bottle.
Also for the gear oil i need the grade. My gearbox is acting funny and want to put the ELF gear oil you have put.
Thanks a lot Sam.
My lancer's car spa this week.
Hey!!
Mobil1 5W40 (or was it 5W50, I will check and tell you tomorrow). I paid 650 odd per 1L bottle. At bangalore you should also easily get OWS and Shell Helix synthetic. Both highly recommended too.
You will need 3.3L for the lancer petrol.
The Elf Gear Oil was not so expensive - I think it was a little over 150 bucks a litre, you will need 3 liters for your lancer.
Don't forget to top up your clutch fluid (should be DOT4, same as the brake oil), one common reason for the gears acting funny.
Sam Kapasi is offline   (1) Thanks Reply With Quote
Old 5th February 2007, 08:52   #93
Vid6639's Avatar
Thanked: 21,060 Times
Oki will do Sam. Will explore Shell helix or Mobil1 to see availability here.
So far have shortlisted out:
1)Engine oil
2)Engine flush
3)gear oil
4)radiator flush
5)clutch fluid
6)Engine coolant
7)brake fluid
Think that should cover all the liquids.
Ps: Elfie we all know your not a lubricant your more like a coolant or actually more like what Sam described in the meet thread. :-)
Old 5th February 2007, 09:45   #94
Sam Kapasi's Avatar
No need to drain the clutch, but definitely do drain your brakes.
Brake oil is hygroscopic, especially DOT3 (red). Drain your brake system, regardless of what brake oil you currently have. Replace all the fluid with DOT4 (White). Ask your guy to bleed it well.
You will need about 0.5L of DOT4 fluid. Both Castrol and TVS-Girling are good enough.
Use as much as the braking will take and use the rest to top up your clutch reservoir.
I leasrned from Floyd on this forum that just saying Shell Helix, isn't enough. There's a helix range it seems. You need the Helix fully synthetic oil.
Old 5th February 2007, 10:04   #95
Vid6639's Avatar
Yeah just saw the Shell site:
Shell in India - Shell Helix Products
There are a few types. I am not sure about the grade I didn't see 5w40/50 only 15w40/50.
I'll ask the HM guys if they have the DOT4 grade with them and get the bleeding done. If not I'll have to get that.
Shell Helix engine oil is available at the Shell pump so no problems in getting that.
Will get all this done in front of me.
Old 5th February 2007, 10:10   #96
Sam Kapasi's Avatar
Shell Helix Ultra 15W50 looks very good to me Vid. Go for it.
Old 6th February 2007, 17:45   #97
condor's Avatar
Thanked: 4,899 Times
Originally Posted by elf View Post
And what's all this negative vibe I'm getting?! People keep talking about shoving me into engines & gearboxes... for the last time, I AM NOT A LUBRICANT!
wondering ... why is elf feeling guilty
Old 5th June 2007, 20:17   #98
Sam Kapasi's Avatar
Default I drove her to Pune!
It was beautiful. The last 5 or 6 drives to pune were in the Verna. Stupid SpeedBoat.
After the entire verna axle incident, I lost my faith and was uneasy to drive it quick. Sooo.... this weekend I took the Lancer to Pune. First long drive after the Spa Treatment.
I fell madly in love all over again.
Not only was I reminded how amazing this car handles all speeds, the treatment and especially the oil change just made the entire experience a complete pleasure.
Revving at 5000 revs per minute, the car felt like Butter. She kept humming to me and I kept falling deeper and deeper in love.
The wheels kept spinning and the 205's held their own through every turn. Never once did I feel uneasy, or unsafe.
The engine revved beautifully, with the new treatment. Smooth responsive and sounded great, just the way i like it.
Old 5th June 2007, 20:20   #99
viper's Avatar
Thanked: 9 Times
Hey Sammy,
Do you have 215's or did you make a typo.
Viper
viper is offline   Reply With Quote
Old 5th June 2007, 20:22   #100
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Where are the speedguns and those topi clad cops when you need them most? Btw, sam congrats on the bravery. Next time when you come down to bangalore I shall teach you to drive slow . Dont thank me, its my pleasure.
Old 5th June 2007, 20:50   #101
vivekiny2k's Avatar
Thanked: 184 Times
Originally Posted by Sam Kapasi View Post
. However, post the radiator flush and the engine spa, the needle refused to go over a quarter mark. The engine is definitely running a lot cooler than it was earlier.
just noticed it today sam, the engine staying cooler than normal may be attributed to the thermostat opened permanently (stuck). common problem after servicing cooling system (flush).
if engine does not reach optimum operating temperature ( around 200 degrees?) , it will not behave properly.
expecting experts to comment.
vivekiny2k is offline   Reply With Quote
Old 5th June 2007, 20:56   #102
Sam Kapasi's Avatar
Originally Posted by vivekiny2k View Post
j
No, strike that overly excited statement off, the one I made earlier about temperature needle not going over the quarter mark. It stays below half which I am told is normal.
Besides in case of themostat failure, the cooling system will not activate, causing overheating.
If the fan stays on at all times, it is most probably an internal shorting of the fan solenoid, thereby staying in NC mode, causing it to stay on regardless of temperature.
Old 5th June 2007, 21:04   #103
Thanked: 35 Times
Yeti talking about engine vengine ? First 180 on the speedo and now this. Times are sure changing.
Old 5th June 2007, 21:19   #104
Sam Kapasi's Avatar
Default Kiss my car!! Kiss her!!
Photo Art by Rudra Sen.
Old 5th June 2007, 21:22   #105
iraghava's Avatar
Thanked: 156 Times
Rudra sir please, please, please visit Delhi sometime soon. Dhanno also wants some artistic shots of her's taken!!!!!! She'll repay the favour with a nice, fast drive!!!!
Two Classics, One Car - 81 year old Packard and 101 year old owner karlosdeville Beyond Borders 5 29th August 2016 00:42
10 year old baby gets new jewellery!- My Zen and it's new white LED cabin light. abhipuru16 Modifications & Accessories 16 5th July 2010 03:35
Hatchback Conundrum: Spoiled for Choice. blackrat Hatchbacks 28 14th July 2009 21:20
96 year old sells 55 year old Italian Fiat for Nano !! emkay456 Shifting gears 14 11th May 2009 14:02
