Old 23rd January 2007, 18:02   #1
Default K & N filter for LPG
Have any body tried fitting a K N filter for a LPG fitted vehicle. If yes what are the remarks??? Heard that for LPG, its better to go for a replacement filter ,,Is it right? Is the filter going to make any changes in the engine conditions since it is an LPG.
thanks
ranjithbalan is offline   Reply With Quote
Old 24th January 2007, 00:45   #2
.anshuman's Avatar
Thanked: 9,159 Times
Yes i have a k&n fipk extreme filter in my accent with lpg,its been working all fine for last 20k kms. , but once you get the filter installed get the mixture adjusted or the car will start bogging and misfiring.
Ikon Fuel Filter : OEM is cheaper than After-Market filter RM2488 Technical Stuff 13 28th June 2012 11:39
Is Oil filter and Fuel filter different? finneyp Technical Stuff 10 25th July 2008 11:45
Palio Extreme Filter + Lpg HAFI Modifications & Accessories 15 26th January 2007 16:10
can k&n air filter be fitted on LPG anku Modifications & Accessories 10 20th July 2006 11:50
