Old 25th January 2007, 07:37   #1
Thanked: 279 Times
Default Rust in fuel tank of Accent CRDI
Hi friends,
I have recently discovered this problem while getting the diesel topped up in my Accent viva crdi. The pipe which connects the inlet to the diesel tank has developed some rust. It has not yet spoilt the pipe fully but when I ran my finger over the surface some rust particles came out.
Now I know that the CRDI pump and injectors are very sensitive to the fuel quality and dust or rust in fuel is very bad for them. I showed it at an authorised service centre and was surprised to know that the pipe costs Rs3000 plus labour. Nevertheles I told the service advisor to go ahead and change it but he replied that he has seen quite a few accents with this amount of rust and it is quite safe as there is a filter in the tank and another one before the fuel pump.
I was also advised that the pipe can be painted and put back. Now, I know that this service advisor was being very helpful but I want to be on safe side.
Please let me know your experiences with this kind of issue and also suggest me if I should replace the pipe or paint it with anti corrosive paint and put it back. Should I also get the diesel tank cleaned?
This is very surprising for me as I live in Bangalore and not in a coastal city and the car is just about 2 years old
Badri
badri is offline   Reply With Quote
Old 25th January 2007, 11:48   #2
tsk1979's Avatar
Thanked: 16,422 Times
Get it painted with anti corrosive paint and get the fuel tank cleaned. Rust will get caught in the diesel filters, and will cause premature clogging.
No need to get it replaced though, paint(anti corrosive) is enough.
Old 26th January 2007, 19:27   #3
Thanked: 279 Times
Thanks for the advice. With all these bad diesel and rust issues, is it advisable to change the fuel filter earlier than the suggested 10000 KMs?
Right now I change oil once every 5000Kms and fuel,air filters at 10000 Kms
Fuel-tank Rust Removal (by Electrolysis) & Rust Proofing H3LIOS Motorbikes 30 19th May 2014 14:26
Rust inside Bullet's Fuel tank. What are my options? Sudipto-S-Team Motorbikes 27 10th December 2013 10:31
Accent CRDi or Accent Viva CRDi Looks abhibh The Indian Car Scene 4 8th November 2005 17:43
Accent CRDi or Accent Viva CRDi abhibh Sedans 16 8th November 2005 05:58
